Forum: Compiler & IDEs Warnung nach Neuinstallation
Autor: wolf4124 (Gast)
Hallo
ich habe meinen Rechner neu aufgesetzt.
GCC die gleiche Version installiert.
Danach die alten Projekte kopiert.
Es hat sich nur der Pfad der Installation geändert.
Nun bekomme ich bei der Comilierung einen Haufen Fehlermeldungen.
Kann mir jemand weiterhelfen?
Compiling: main.c
avr-gcc -c -mmcu=atmega128 -I. -gdwarf-2 -DF_CPU=8000000UL  -Os
-funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall
-Wstrict-prototypes -Wa,-adhlns=main.lst  -std=gnu99 -MD -MP -MF
.dep/main.o.d main.c -o main.o
In file included from main.c:20:
PCF8593.h: In function `Get_Time':
PCF8593.h:151: warning: implicit declaration of function `sprintf'
main.c: At top level:
main.c:276: warning: initialization from incompatible pointer type
main.c:277: warning: initialization from incompatible pointer type
main.c:278: warning: initialization from incompatible pointer type
main.c:279: warning: initialization from incompatible pointer type
main.c:280: warning: initialization from incompatible pointer type
main.c:299: warning: initialization from incompatible pointer type
main.c:300: warning: initialization from incompatible pointer type
main.c:301: warning: initialization from incompatible pointer type
main.c:302: warning: initialization from incompatible pointer type
main.c:303: warning: initialization from incompatible pointer type
main.c:304: warning: initialization from incompatible pointer type
main.c:305: warning: initialization from incompatible pointer type
main.c:306: warning: initialization from incompatible pointer type
main.c:307: warning: initialization from incompatible pointer type
main.c:308: warning: initialization from incompatible pointer type
main.c:325: warning: initialization from incompatible pointer type
main.c:326: warning: initialization from incompatible pointer type
main.c:327: warning: initialization from incompatible pointer type
main.c:328: warning: initialization from incompatible pointer type
main.c:329: warning: initialization from incompatible pointer type
main.c:330: warning: initialization from incompatible pointer type
main.c:379: warning: initialization from incompatible pointer type
main.c:379: warning: initialization discards qualifiers from pointer
target type
main.c:380: warning: initialization from incompatible pointer type
main.c:380: warning: initialization discards qualifiers from pointer
target type
main.c:381: warning: initialization from incompatible pointer type
main.c:381: warning: initialization discards qualifiers from pointer
target type
main.c:382: warning: initialization from incompatible pointer type
main.c:382: warning: initialization discards qualifiers from pointer
target type
main.c:383: warning: initialization from incompatible pointer type
main.c:383: warning: initialization discards qualifiers from pointer
target type
main.c:384: warning: initialization from incompatible pointer type
main.c:384: warning: initialization discards qualifiers from pointer
target type
main.c:385: warning: initialization from incompatible pointer type
main.c:385: warning: initialization discards qualifiers from pointer
target type
main.c:386: warning: initialization from incompatible pointer type
main.c:386: warning: initialization discards qualifiers from pointer
target type
main.c:387: warning: initialization from incompatible pointer type
main.c:387: warning: initialization discards qualifiers from pointer
target type
main.c:388: warning: initialization discards qualifiers from pointer
target type
main.c:388: warning: initialization from incompatible pointer type
main.c:389: warning: initialization from incompatible pointer type
main.c:389: warning: initialization discards qualifiers from pointer
target type
main.c:425: warning: initialization makes pointer from integer without a
cast
main.c:425: warning: initialization from incompatible pointer type
main.c:426: warning: initialization makes pointer from integer without a
cast
main.c:426: warning: initialization from incompatible pointer type
main.c:427: warning: initialization makes pointer from integer without a
cast
main.c:427: warning: initialization from incompatible pointer type
main.c:428: warning: initialization makes pointer from integer without a
cast
main.c:428: warning: initialization from incompatible pointer type
main.c:429: warning: initialization makes pointer from integer without a
cast
main.c:429: warning: initialization from incompatible pointer type
main.c:430: warning: initialization makes pointer from integer without a
cast
main.c:430: warning: initialization from incompatible pointer type
main.c:477: warning: initialization from incompatible pointer type
main.c:477: warning: initialization discards qualifiers from pointer
target type
main.c:477: warning: excess elements in struct initializer
main.c:477: warning: (near initialization for `TAB_UNTERDISPLAY[0]')
main.c:478: warning: initialization from incompatible pointer type
main.c:478: warning: initialization discards qualifiers from pointer
target type
main.c:478: warning: excess elements in struct initializer
main.c:478: warning: (near initialization for `TAB_UNTERDISPLAY[1]')
main.c:479: warning: initialization from incompatible pointer type
main.c:479: warning: initialization discards qualifiers from pointer
target type
main.c:479: warning: excess elements in struct initializer
main.c:479: warning: (near initialization for `TAB_UNTERDISPLAY[2]')
main.c:480: warning: initialization from incompatible pointer type
main.c:480: warning: initialization discards qualifiers from pointer
target type
main.c:480: warning: excess elements in struct initializer
main.c:480: warning: (near initialization for `TAB_UNTERDISPLAY[3]')
main.c:481: warning: initialization from incompatible pointer type
main.c:481: warning: initialization discards qualifiers from pointer
target type
main.c:481: warning: excess elements in struct initializer
main.c:481: warning: (near initialization for `TAB_UNTERDISPLAY[4]')
main.c:482: warning: initialization from incompatible pointer type
main.c:482: warning: initialization discards qualifiers from pointer
target type
main.c:482: warning: excess elements in struct initializer
main.c:482: warning: (near initialization for `TAB_UNTERDISPLAY[5]')
main.c:483: warning: initialization from incompatible pointer type
main.c:483: warning: initialization discards qualifiers from pointer
target type
main.c:483: warning: excess elements in struct initializer
main.c:483: warning: (near initialization for `TAB_UNTERDISPLAY[6]')
main.c:484: warning: initialization from incompatible pointer type
main.c:484: warning: initialization discards qualifiers from pointer
target type
main.c:484: warning: excess elements in struct initializer
main.c:484: warning: (near initialization for `TAB_UNTERDISPLAY[7]')
main.c:485: warning: initialization from incompatible pointer type
main.c:485: warning: initialization discards qualifiers from pointer
target type
main.c:485: warning: excess elements in struct initializer
main.c:485: warning: (near initialization for `TAB_UNTERDISPLAY[8]')
main.c:486: warning: initialization from incompatible pointer type
main.c:486: warning: initialization discards qualifiers from pointer
target type
main.c:486: warning: excess elements in struct initializer
main.c:486: warning: (near initialization for `TAB_UNTERDISPLAY[9]')
main.c:487: warning: excess elements in struct initializer
main.c:487: warning: (near initialization for `TAB_UNTERDISPLAY[10]')
main.c:488: warning: excess elements in struct initializer
main.c:488: warning: (near initialization for `TAB_UNTERDISPLAY[11]')
main.c:489: warning: excess elements in struct initializer
main.c:489: warning: (near initialization for `TAB_UNTERDISPLAY[12]')
main.c:490: warning: excess elements in struct initializer
main.c:490: warning: (near initialization for `TAB_UNTERDISPLAY[13]')
main.c:491: warning: excess elements in struct initializer
main.c:491: warning: (near initialization for `TAB_UNTERDISPLAY[14]')
main.c:492: warning: excess elements in struct initializer
main.c:492: warning: (near initialization for `TAB_UNTERDISPLAY[15]')
main.c:493: warning: excess elements in struct initializer
main.c:493: warning: (near initialization for `TAB_UNTERDISPLAY[16]')
main.c:494: warning: excess elements in struct initializer
main.c:494: warning: (near initialization for `TAB_UNTERDISPLAY[17]')
main.c:495: warning: excess elements in struct initializer
main.c:495: warning: (near initialization for `TAB_UNTERDISPLAY[18]')
main.c:496: warning: excess elements in struct initializer
main.c:496: warning: (near initialization for `TAB_UNTERDISPLAY[19]')
main.c:497: warning: initialization from incompatible pointer type
main.c:497: warning: excess elements in struct initializer
main.c:497: warning: (near initialization for `TAB_UNTERDISPLAY[20]')
main.c:497: warning: excess elements in array initializer
main.c:497: warning: (near initialization for `TAB_UNTERDISPLAY')
main.c: In function `init_avr':
main.c:591: warning: passing arg 1 of `eeprom_read_byte' from
main.c:592: warning: passing arg 1 of `eeprom_write_byte' from
main.c: In function `Display_ausgabe':
main.c:1439: warning: passing arg 1 of `eeprom_read_byte' from
main.c:1442: warning: passing arg 1 of `mcp2515_read_register' makes
integer from pointer without a cast
main.c:1408: warning: unused variable `IntTemp'
main.c: In function `Taster_auswertung':
main.c:1623: warning: passing arg 1 of `eeprom_read_byte' from
Linking: main.elf
avr-gcc -mmcu=atmega128 -I. -gdwarf-2 -DF_CPU=8000000UL  -Os
-Wstrict-prototypes -Wa,-adhlns=main.o  -std=gnu99 -MD -MP -MF
.dep/main.elf.d main.o --output main.elf -Wl,-Map=main.map,--cref    -lm
Creating load file for Flash: main.hex
avr-objcopy -O ihex -R .eeprom main.elf main.hex
Creating load file for EEPROM: main.eep
avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" \
--change-section-lma .eeprom=0 -O ihex main.elf main.eep
Creating Extended Listing: main.lss
avr-objdump -h -S main.elf > main.lss
Creating Symbol Table: main.sym
avr-nm -n main.elf > main.sym
Size after:
main.elf  :
section            size      addr
.data              3276   8388864
.text             15414         0
.bss                660   8392140
.noinit               0   8392800
.eeprom              11   8454144
.debug_aranges       20         0
.debug_pubnames    3917         0
.debug_info        9507         0
.debug_abbrev       641         0
.debug_line        6374         0
.debug_str         4015         0
.debug_ranges        24     15414
Total             43859
AVR Memory Usage:
Device: atmega128
Program:   18690 bytes (14.3% Full)
(.text + .data + .bootloader)
Data:       3936 bytes (96.1% Full)
(.data + .bss + .noinit)
-------- end --------
> Process Exit Code: 0
Autor: Simon K. (simon) Benutzerseite
Wie soll man das wissen ohne die .c Dateien und Makefile?
Vermutlich einfach nur unsauber programmiert und das rächt sich bei der
neuen Version jetzt.
Das sind aber auch nur Warnungen alles. Aber trotzdem: Mit 96%
Auslastung des RAMs nur durch statische/globale Variablen ist es mutig,
das Programm irgendwo zu benutzen ;)
Autor: R. Freitag (rfr)
heisst doch, dass der Compiler sprintf nicht gefunden hat und deswegen
irrtümlich einee implizite Deklaration annimmt.
Oder?
Gruss
Robert
Ja, der Prototyp fehlt.
Autor: Rolf Magnus (Gast)
Du hast irgendwas initialisiert, aber der Initialisierer ist vom
falschen Typ.
> target type
Du hast irgendwo ein const oder volatile bei einem Zeiger vergessen.
> cast
Du hast versucht, einen Integer-Wert in einen Zeiger-Wert zu
konvertieren. Wenn du das tatsächlich willst, mußt du dem Compiler das
mit einem Cast signalisieren.
Du hast irgendwo in der Nähe der Initialisierung von TAB_UNTERDISPLAY[0]
versucht, Elemente einer Struktur zu initialisieren, die sie gar nicht
hat.
Du übergibst eeprom_read_byte nicht den Zeigertyp, den es erwartet.
Hier versuchst du, einen Zeiger-Wert als Integer-Wert zu interpretieren.
Wenn du das tatsächlich willst, mußt du das mit einem Cast dem Compiler
mitteilen.
Du hast die Variable IntTemp definiert, aber nirgends verwendet.
Die restlichen Warnungen sind alle von einer der oben beschriebenen
Arten. Wodurch die genau hervorgerufen werden, kann man mangels
Quellcode nicht sagen.
