1 | package usb;
2 |
3 | import gnu.io.*;
4 |
5 | import java.io.IOException;
6 | import java.io.InputStream;
7 | import java.io.OutputStream;
8 | import java.util.Enumeration;
9 | import java.util.TooManyListenersException;
10 |
11 | //import OeffnenUndSenden.serialPortEventListener;
12 |
13 |
14 |
15 | public class Main implements Runnable {
16 |
17 | /**
18 | * @param args
19 | */
20 | public static void main(String[] args)
21 | {
22 | Runnable runnable = new Main();
23 | new Thread(runnable).start();
24 | System.out.println("main finished");
25 | }
26 |
27 | /**
28 | *
29 | */
30 |
31 | CommPortIdentifier serialPortId;
32 | Enumeration enumComm;
33 | SerialPort serialPort;
34 | OutputStream outputStream;
35 | InputStream inputStream;
36 | Boolean serialPortGeoeffnet = false;
37 |
38 | int baudrate = 460800;
39 | int dataBits = SerialPort.DATABITS_8;
40 | int stopBits = SerialPort.STOPBITS_1;
41 | int parity = SerialPort.PARITY_NONE;
42 | int fluss = SerialPort.FLOWCONTROL_NONE;
43 | String portName = "/dev/ttyUSB0";
44 |
45 | int secondsRuntime = 60;
46 |
47 | public Main()
48 | {
49 | System.out.println("Konstruktor: EinfachSenden");
50 | }
51 |
52 | public void run()
53 | {
54 | Integer secondsRemaining = secondsRuntime;
55 | if (oeffneSerialPort(portName) != true)
56 | return;
57 |
58 | while (secondsRemaining > 0) {
59 | System.out.println("Sekunden verbleiben: " + secondsRemaining.toString() );
60 | secondsRemaining--;
61 | try {
62 | Thread.sleep(2000);
63 | } catch(InterruptedException e) { }
64 | sendeSerialPort("@128001disc;&");
65 | }
66 | schliesseSerialPort();
67 |
68 |
69 | }
70 |
71 | boolean oeffneSerialPort(String portName)
72 | {
73 | Boolean foundPort = false;
74 | if (serialPortGeoeffnet != false) {
75 | System.out.println("Serialport bereits geöffnet");
76 | return false;
77 | }
78 | System.out.println("Öffne Serialport");
79 | enumComm = CommPortIdentifier.getPortIdentifiers();
80 | while(enumComm.hasMoreElements()) {
81 | serialPortId = (CommPortIdentifier) enumComm.nextElement();
82 | if (portName.contentEquals(serialPortId.getName())) {
83 | foundPort = true;
84 | break;
85 | }
86 | }
87 | if (foundPort != true) {
88 | System.out.println("Serialport nicht gefunden: " + portName);
89 | return false;
90 | }
91 | try {
92 | serialPort = (SerialPort) serialPortId.open("Öffnen und Senden", 500);
93 | } catch (PortInUseException e) {
94 | System.out.println("Port belegt");
95 | }
96 |
97 | try {
98 | outputStream = serialPort.getOutputStream();
99 | } catch (IOException e) {
100 | System.out.println("Keinen Zugriff auf OutputStream");
101 | }
102 |
103 | try {
104 | inputStream = serialPort.getInputStream();
105 | } catch (IOException e) {
106 | System.out.println("Keinen Zugriff auf InputStream");
107 | }
108 | try {
109 | serialPort.addEventListener(new serialPortEventListener());
110 | } catch (TooManyListenersException e) {
111 | System.out.println("TooManyListenersException für Serialport");
112 | }
113 | serialPort.notifyOnDataAvailable(true);
114 | try {
115 | serialPort.setSerialPortParams(baudrate, dataBits, stopBits, parity);
116 | serialPort.setFlowControlMode(fluss);
117 | } catch(UnsupportedCommOperationException e) {
118 | System.out.println("Konnte Schnittstellen-Paramter nicht setzen");
119 | }
120 |
121 | serialPortGeoeffnet = true;
122 | return true;
123 | }
124 |
125 | void schliesseSerialPort()
126 | {
127 | if ( serialPortGeoeffnet == true) {
128 | System.out.println("Schließe Serialport");
129 | serialPort.close();
130 | serialPortGeoeffnet = false;
131 | } else {
132 | System.out.println("Serialport bereits geschlossen");
133 | }
134 | }
135 |
136 | void serialPortDatenVerfuegbar() {
137 | try {
138 | byte[] data = new byte[150];
139 | int num;
140 | while(inputStream.available() > 0) {
141 | num = inputStream.read(data, 0, data.length);
142 | System.out.println("Empfange: "+ new String(data, 0, num));
143 | }
144 |
145 | } catch (IOException e) {
146 | System.out.println("Fehler beim Lesen empfangener Daten");
147 | }
148 | }
149 |
150 | void sendeSerialPort(String nachricht)
151 | {
152 | System.out.println("Sende: " + nachricht);
153 | if (serialPortGeoeffnet != true)
154 | return;
155 | try {
156 | outputStream.write(nachricht.getBytes());
157 | } catch (IOException e) {
158 | System.out.println("Fehler beim Senden");
159 | }
160 | }
161 |
162 |
163 | class serialPortEventListener implements SerialPortEventListener {
164 | public void serialEvent(SerialPortEvent event) {
165 | System.out.println("serialPortEventlistener");
166 | switch (event.getEventType()) {
167 | case SerialPortEvent.DATA_AVAILABLE:
168 | serialPortDatenVerfuegbar();
169 | break;
170 | case SerialPortEvent.BI:
171 | case SerialPortEvent.CD:
172 | case SerialPortEvent.CTS:
173 | case SerialPortEvent.DSR:
174 | case SerialPortEvent.FE:
175 | case SerialPortEvent.OUTPUT_BUFFER_EMPTY:
176 | case SerialPortEvent.PE:
177 | case SerialPortEvent.RI:
178 | default:
179 | }
180 | }
181 | }
182 | }
