1 | #include "../main.h"
2 | #include "lanDriver.h"
3 |
4 | typedef struct enc{
5 |
6 | volatile unsigned char current_bank;
7 | volatile unsigned int next_packet_ptr;
8 | unsigned char revision;
9 |
10 | }enc28j60_t;
11 |
12 | char initSequence[] = {
13 | // Address, Value
14 | //setup bank0 (config stored in progmem, see above)
15 | //tx buffer:
16 | ENC28J60_REG_ETXSTL, lo8(ENC28J60_TX_BUFFER_START), //start lo
17 | ENC28J60_REG_ETXSTH, hi8(ENC28J60_TX_BUFFER_START), //start hi
18 | ENC28J60_REG_ETXNDL, lo8(ENC28J60_TX_BUFFER_END ), //end lo
19 | ENC28J60_REG_ETXNDH, hi8(ENC28J60_TX_BUFFER_END ), //end hi
20 | //rx buffer
21 | ENC28J60_REG_ERXSTL, lo8(ENC28J60_RX_BUFFER_START), //start lo
22 | ENC28J60_REG_ERXSTH, hi8(ENC28J60_RX_BUFFER_START), //start hi
23 | ENC28J60_REG_ERXNDL, lo8(ENC28J60_RX_BUFFER_END ), //end lo
24 | ENC28J60_REG_ERXNDH, hi8(ENC28J60_RX_BUFFER_END ), //end hi
25 | //rx ptr:
26 | //ENC28J60_REG_ERDPTL, lo8(ENC28J60_RX_BUFFER_START+1),
27 | //ENC28J60_REG_ERDPTH, hi8(ENC28J60_RX_BUFFER_START+1),
28 |
29 | //setup bank2: (see microchip datasheet p.36)
30 | //1.) clear the MARST bit in MACON2.
31 | ENC28J60_REG_MACON2, 0x00,
32 | //2.) mac rx enable, activate pause control frame support
33 | ENC28J60_REG_MACON1, ((1<<ENC28J60_BIT_MARXEN)|(1<<ENC28J60_BIT_RXPAUS)|(1<<ENC28J60_BIT_TXPAUS)),
34 | //3.) setup MACON3: auto padding of small packets, add crc, enable frame length check:
35 | ENC28J60_REG_MACON3, ((1<<ENC28J60_BIT_PADCFG0)|(1<<ENC28J60_BIT_TXCRCEN)|(1<<ENC28J60_BIT_FRMLNEN)),
36 | //4.) dont set up MACON4 (use default)
37 | //5.) setup maximum framelenght to 1518:
38 | ENC28J60_REG_MAMXFLL, lo8(1518),
39 | ENC28J60_REG_MAMXFLH, hi8(1518),
40 | //6.) set up back-to-back gap: 0x15 for full duplex / 0x12 for half duplex
41 | ENC28J60_REG_MABBIPG, 0x12, //half duplex
42 | //7.) setup non-back-to-back gap: use 0x12
43 | ENC28J60_REG_MAIPGL, 0x12,
44 | //8.) setup non-back-to-back gap high byte: 0x0C for half duplex:
45 | ENC28J60_REG_MAIPGH, 0x0C, //half duplex
46 | //9.) dont change MACLCON1+2 / MACLCON2 might be changed for networks with long wires !
47 |
48 | //setup bank3:
49 | //10.) programm mac address: BYTE BACKWARD !
50 | ENC28J60_REG_MAADR5, NIC_MAC0,
51 | ENC28J60_REG_MAADR4, NIC_MAC1,
52 | ENC28J60_REG_MAADR3, NIC_MAC2,
53 | ENC28J60_REG_MAADR2, NIC_MAC3,
54 | ENC28J60_REG_MAADR1, NIC_MAC4,
55 | ENC28J60_REG_MAADR0, NIC_MAC5
56 | };
57 |
58 |
59 | static char read_LAN(char adr);
60 | static char write_LAN(char adr, char data);
61 | static void select_bank(char bank);
62 | static char cmd_LAN(char cmd, char data);
63 | static void write_phy_LAN(char adr, unsigned int data);
64 | void cmd_write_LAN(char hi, char lo);
65 |
66 | enc28j60_t enc;
67 |
68 | /**
69 | * This function initiates the lan chip
70 | * @return Errorcode LANINIT_
71 | */
72 | char init_LAN(){
73 |
74 | char str[12];
75 | // to force bank update
76 | enc.current_bank=0xff;
77 |
78 | // Reset ENC 28 J 60
79 | PORTC &=~(1<<LAN_RST);
80 | _delay_ms(10);
81 | // Release
82 | PORTC |=(1<<LAN_RST);
83 |
84 |
85 | // Wait for Startup (at least 50 us)
86 | _delay_us(60);
87 | // To prevent bad requests wait again at least 5 ms
88 | _delay_ms(10);
89 |
90 | sendStringRS232("vor while\r\n");
91 |
92 | itoa((int)read_LAN(ENC28J60_REG_ESTAT),str,2);
93 | sendStringRS232("Statusregister: 0b");
94 | sendStringRS232(str);
95 | sendStringRS232("\r\n");
96 |
97 | // Waiting until chip is ready
98 | while(!(read_LAN(ENC28J60_REG_ESTAT) & 0x01)){};
99 |
100 | sendStringRS232("nach while\r\n");
101 |
102 | itoa((int)read_LAN(ENC28J60_REG_ESTAT),str,2);
103 | sendStringRS232("Statusregister: 0b");
104 | sendStringRS232(str);
105 | sendStringRS232("\r\n");
106 |
107 | sendStringRS232("vor for\r\n");
108 |
109 | /*
110 | for(int i=0; i<(2*22);i += 2){
111 | write_LAN(initSequence[i], initSequence[1+1]);
112 | }
113 | */
114 |
115 |
116 |
117 | write_LAN(ENC28J60_REG_ETXSTL,lo8(ENC28J60_TX_BUFFER_START));
118 |
119 | itoa((int)read_LAN(ENC28J60_REG_ETXSTL),str,16);
120 | sendStringRS232("\r\nb0 ETXSTL: 0x");
121 | sendStringRS232(str);
122 | sendStringRS232(" sollte 0x00 heisen !!!!!!!!!!!!!!!!!!!!!!!!!!!!\r\n");
123 |
124 | write_LAN(ENC28J60_REG_ETXSTH,hi8(ENC28J60_TX_BUFFER_START));
125 |
126 | itoa((int)read_LAN(ENC28J60_REG_ETXSTH),str,16);
127 | sendStringRS232("\r\nb0 ETXSTH: 0x");
128 | sendStringRS232(str);
129 | sendStringRS232(" sollte 0x1a heisen !!!!!!!!!!!!!!!!!!!!!!!!!!!!\r\n");
130 |
131 |
132 |
133 | write_LAN(ENC28J60_REG_MAIPGL, 0x12);
134 |
135 | itoa((int)read_LAN(ENC28J60_REG_MAIPGL),str,16);
136 | sendStringRS232("\r\nb2 MAIPGL: 0x");
137 | sendStringRS232(str);
138 | sendStringRS232(" sollte 0x12 heisen !!!!!!!!!!!!!!!!!!!!!!!!!!!!\r\n");
139 |
140 | write_LAN(ENC28J60_REG_MAADR5, NIC_MAC0);
141 |
142 | itoa((int)read_LAN(ENC28J60_REG_MAADR5),str,16);
143 | sendStringRS232("\r\nb3 MAADR5: 0x");
144 | sendStringRS232(str);
145 | sendStringRS232(" sollte 0xac heisen !!!!!!!!!!!!!!!!!!!!!!!!!!!!\r\n");
146 |
147 | sendStringRS232("nach for\r\n");
148 |
149 | //no loop back of transmitted frames
150 | //write_phy_LAN(ENC28J60_PHY_PHCON2, (1<<ENC28J60_BIT_HDLDIS));
151 |
152 | sendStringRS232("nach loop while\r\n");
153 |
154 | //enable interrups
155 | //enc28j60_write_address(ENC28J60_REG_EIE, (1<<6)|(1<<7));
156 |
157 | //enable rx
158 | //enc28j60_write_address(ENC28J60_REG_ECON1, (1<<ENC28J60_BIT_RXEN));
159 | //enc28j60_spi_write_word(ENC28J60_OP_BFS|ENC28J60_REG_ECON1, (1<<ENC28J60_BIT_RXEN));
160 |
161 | // Set 16 Bit LED Register to configure LEDs
162 | // LEDA: link status, LEDB: RX&TX activity
163 | //write_phy_LAN(ENC28J60_PHY_PHLCON,0x0472);
164 | sendStringRS232("nach led enable\r\n");
165 |
166 |
167 |
168 |
169 | return LANINIT_FAILD;
170 | }
171 |
172 |
173 | /**
174 | * This function prints out the Errorcodes from Laninit
175 | * @param err Errorcode
176 | */
177 | void printLanInitErrors(char err){
178 | switch (err){
179 | case LANINIT_FAILD:{
180 | sendStringRS232("fail (unknown reason)");
181 | break;
182 | }
183 | case LANINIT_SUCCESSFULL:{
184 | sendStringRS232("successfully");
185 | break;
186 | }
187 |
188 | }
189 |
190 | }
191 |
192 |
193 | /** PROTECTED
194 | *
195 | * Reads from the config register
196 | */
197 | static char read_LAN(char adr){
198 |
199 | // Select bank
200 | select_bank(adr);
201 | // Add Command
202 | adr = adr | LAN_RCR;
203 | // read
204 | return cmd_LAN(adr,0);
205 | }
206 |
207 |
208 | /**
209 | * This function writes to the PHY Registers
210 | *
211 | * @param ard address of the Register
212 | * @param data data to be write to tha PHY register
213 | *
214 | */
215 | static void write_phy_LAN(char adr, unsigned int data){
216 |
217 | //see microchip datasheet p.21
218 | //set address to MIREGADR:
219 | write_LAN(ENC28J60_REG_MIREGADR,adr);
220 |
221 | // Send data
222 | write_LAN(ENC28J60_REG_MIWRL, data&0xff);
223 | write_LAN(ENC28J60_REG_MIWRH, data>>8);
224 |
225 | // wait until phy reg is written
226 |
227 | char str[12];
228 | sendStringRS232("read phy REG_MISTAT\r\n");
229 | itoa((int)enc.current_bank,str,10);
230 | sendStringRS232("bank: ");
231 | sendStringRS232(str);
232 | sendStringRS232("\r\n");
233 |
234 | while(read_LAN(ENC28J60_REG_MISTAT) & (1<<ENC28J60_BIT_MISTAT_BUSY))
235 | {
236 |
237 |
238 |
239 |
240 | _delay_ms(10000);
241 |
242 | /*
243 | itoa((int)read_LAN(ENC28J60_REG_MISTAT),str,2);
244 | sendStringRS232("Statusregister1: 0b");
245 | sendStringRS232(str);
246 | sendStringRS232("\r\n");
247 |
248 | itoa((int)read_LAN(ENC28J60_REG_ESTAT),str,2);
249 | sendStringRS232("Statusregister2: 0b");
250 | sendStringRS232(str);
251 | sendStringRS232("\r\n");
252 | _delay_ms(10000);
253 | */
254 | }
255 | }
256 |
257 |
258 | /**
259 | * Writes to the config registers
260 | */
261 | static char write_LAN(char adr, char data){
262 |
263 | // Select bank
264 | select_bank(adr);
265 | // Add Command
266 | adr = adr | LAN_WCR;
267 | // Write
268 | return cmd_LAN(adr,data);
269 | }
270 |
271 |
272 | /**
273 | * Select a bank of config registers
274 | */
275 | static void select_bank(char bank){
276 |
277 | if((bank & 0x60) != enc.current_bank){
278 | sendStringRS232("switch from bank ");
279 |
280 | char str[12];
281 |
282 | itoa((int)enc.current_bank>>5,str,10);
283 |
284 | sendStringRS232(str);
285 |
286 |
287 | enc.current_bank = (bank & 0x60);
288 |
289 | sendStringRS232(" to bank ");
290 |
291 | itoa((int)enc.current_bank>>5,str,10);
292 |
293 | sendStringRS232(str);
294 |
295 | sendStringRS232(" \r\n");
296 |
297 |
298 |
299 | // release old bank select
300 | cmd_write_LAN((LAN_BFC|ENC28J60_REG_ECON1),((1<<ENC28J60_BIT_ECON1_BSEL0) | (1<<ENC28J60_BIT_ECON1_BSEL1)));
301 | // Set new one
302 | cmd_write_LAN((LAN_BFC|ENC28J60_REG_ECON1),enc.current_bank>>5);
303 |
304 | char bk = (cmd_LAN((LAN_RCR | ENC28J60_REG_ECON1),0)) & ((1<<ENC28J60_BIT_ECON1_BSEL0) | (1<<ENC28J60_BIT_ECON1_BSEL1));
305 | //(read_LAN(ENC28J60_REG_ECON1)&((1<<ENC28J60_BIT_ECON1_BSEL0) | (1<<ENC28J60_BIT_ECON1_BSEL1)));
306 | if(bk == enc.current_bank>>5){
307 | sendStringRS232("bankset ok ");
308 |
309 | sendStringRS232("bank ");
310 | itoa((int)enc.current_bank>>5,str,10);
311 |
312 | sendStringRS232(str);
313 |
314 | sendStringRS232("\r\n");
315 | }else{
316 |
317 | sendStringRS232("Error while bankset ");
318 | sendStringRS232(" to bank ");
319 |
320 | itoa((int)enc.current_bank>>5,str,10);
321 |
322 | sendStringRS232(str);
323 |
324 | sendStringRS232(" anstatt ");
325 |
326 | itoa((int)bk,str,10);
327 |
328 | sendStringRS232(str);
329 |
330 | sendStringRS232("!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!\r\n");
331 | }
332 |
333 | }
334 | }
335 |
336 |
337 | /**
338 | * This function sends a command with data or without data if data = 0
339 | *
340 | */
341 | static char cmd_LAN(char cmd, char data){
342 |
343 | char ret=0;
344 | char str[12];
345 |
346 | // Release CS SD Card (low active)
347 | PORTB &=~(1<<LAN_CS);
348 |
349 | SPI_SEND(cmd);
350 |
351 | // Write
352 | if(data)
353 | SPI_SEND(data);
354 |
355 |
356 | //if MAC* or MI* is read a second dummy read is neccesary
357 | if(cmd & 0x80){
358 | ret = SPI_RECEIVE_0x00();
359 | /*
360 | itoa((int)ret,str,2);
361 | sendStringRS232("Statusregister-: 0b");
362 | sendStringRS232(str);
363 | sendStringRS232("\r\n");
364 | sendStringRS232("data & 0x80\r\n");*/
365 | }
366 |
367 | ret = SPI_RECEIVE_0x00();
368 |
369 | // set CS LAN (low active)
370 | PORTB |=(1<<LAN_CS);
371 |
372 | return ret;
373 | }
374 |
375 | void cmd_write_LAN(char hi, char lo){
376 | // Release CS SD Card (low active)
377 | PORTB &=~(1<<LAN_CS);
378 |
379 | SPI_SEND(hi);
380 | SPI_SEND(lo);
381 |
382 | // set CS LAN (low active)
383 | PORTB |=(1<<LAN_CS);
384 | }
