1 | /// Includes //////////
2 | #include <avr/io.h>
3 | #include <avr/interrupt.h>
4 |
5 | /// Data Types /////////
6 | typedef unsigned char u8;
7 | typedef unsigned int u16;
8 | typedef struct task
9 | {
10 | // pointer to a function
11 | void (*pfunc) (void);
12 | // delay before the first call
13 | u16 delay;
14 | // interval between subsequent runs
15 | u16 period;
16 | // flag indicating time to run
17 | u8 run;
18 | }task;
19 |
20 | struct USART
21 | { unsigned char empfangen;
22 | unsigned char wert;
23 | }
24 |
25 | /// Defines ///////////
26 | // 25msec period 256-180
27 | // 7.3728MHz and /1024 prescaler
28 | #define StartFrom 76
29 | // maximum number of tasks
30 | #define MAXnTASKS 20
31 |
32 | /// Globals ///////////
33 | volatile task TaskArray[MAXnTASKS];
34 |
35 | /// Prototypes ////////
36 | void InitUART (u16 baud);
37 | void TransmitByte (u8 data);
38 | void InitScheduler (void);
39 | void UpdateScheduler(void);
40 | void DeleteTask (u8 index);
41 | void AddTask (void (*taskfunc)(void), u16 taskdelay, u16 taskperiod);
42 | void DispatchTask (void);
43 |
44 | void TestA (void);
45 | void TestB (void);
46 | void TestC (void);
47 |
48 | /// Main //////////////
49 | int main(void)
50 | {
51 | InitUART (23);
52 | InitScheduler();
53 |
54 | // populate task array
55 | AddTask (TestA, 0, 3);
56 | AddTask (TestB, 1, 4);
57 | AddTask (TestC, 4, 0);
58 |
59 | // enable interrupts
60 | sei();
61 |
62 | while (1)
63 | {
64 | DispatchTask();
65 | }
66 | }
67 |
68 | void InitUART (u16 baud)
69 | {
70 | UBRRH = (u8)(baud>>8);
71 | UBRRL = (u8)baud;
72 | UCSRB = (1<<RXEN)|(1<<TXEN);
73 | UCSRC = (1<<URSEL)|(1<<UCSZ1)|(1<<UCSZ0);
74 | //hier ist noch der Recieveinterrupt zu aktivieren
75 | }
76 |
77 |
78 |
79 | void InitScheduler (void)
80 | {
81 | u8 i;
82 |
83 | // timer prescaler clock/1024
84 | TCCR0 |= (1<<CS02)|(1<<CS00);
85 | // clear pending interrupts
86 | TIFR = 1<<TOV0;
87 | // enable timer0 overflow interrupt
88 | TIMSK |= 1<<TOIE0;
89 | // load timer0
90 | TCNT0 = StartFrom;
91 |
92 | // clear task array
93 | for (i=0; i<MAXnTASKS; i++) DeleteTask(i);
94 | }
95 |
96 | void DeleteTask (u8 j)
97 | {
98 | TaskArray[j].pfunc = 0x0000;
99 | TaskArray[j].delay = 0;
100 | TaskArray[j].period = 0;
101 | TaskArray[j].run = 0;
102 | }
103 |
104 | void AddTask (void (*taskfunc)(void), u16 taskdelay, u16 taskperiod)
105 | {
106 | u8 n=0;
107 |
108 | // find next available position
109 | while ((TaskArray[n].pfunc != 0) && (n < MAXnTASKS)) n++;
110 |
111 | // place task
112 | if (n < MAXnTASKS)
113 | {
114 | TaskArray[n].pfunc = taskfunc;
115 | TaskArray[n].delay = taskdelay;
116 | TaskArray[n].period = taskperiod;
117 | TaskArray[n].run = 0;
118 | }
119 | }
120 |
121 | SIGNAL(SIG_OVERFLOW0)
122 | {
123 | u8 m;
124 |
125 |
126 |
127 | // load timer
128 | TCNT0 = StartFrom;
129 |
130 | for (m=0; m<MAXnTASKS; m++)
131 | {
132 | if (TaskArray[m].pfunc)
133 | {
134 | if (TaskArray[m].delay == 0)
135 | {
136 | TaskArray[m].run = 1;
137 | TaskArray[m].delay = TaskArray[m].period;
138 | }
139 | else TaskArray[m].delay--;
140 | }
141 | }
142 | }
143 | ISR(USART_RECv_vect)
144 | {
145 | USART.empfangen=1;
146 | USART.wert=UDR;
147 | }
148 | void DispatchTask (void)
149 | {
150 | u8 k;
151 |
152 | for (k=0; k<MAXnTASKS; k++)
153 | {
154 | if (TaskArray[k].run == 1)
155 | {
156 | // run task
157 | (*TaskArray[k].pfunc)();
158 | // clear run flag
159 | TaskArray[k].run = 0;
160 | }
161 | }
162 |
163 | }
164 |
165 | void TestA (void)
166 | {
167 |
168 | }
169 |
170 | void TestB (void)
171 | {
172 |
173 | }
174 |
175 | void TestC (void)
176 | {
177 | //Abfrage, ob was Empfangen
178 |
179 | if(USART.empfangen){
180 | // hier geschieht die Verarbeitung
181 |
182 |
183 | //Ende der Verarbeitung
184 | USART.empfangen=0;
185 | }
186 | }
