Forum: Mikrocontroller und Digitale Elektronik PHILIPS VP5500 VoIP Telefon bei Pollin
von R. H. (snapper)
@ karloheinzo
fritz.box:5060    !!!!!!!
von Jörn (Gast)
ist das VP6500 baugleich mit dem VP5500?
Vor allem interessiert mich ob im VP6500 auch das Marwell WLAN Modul
verbaut ist?
Gruß Jörn
von Joost R. (Firma: Nederland Live) (joost_r)
Hi All,
Regarding imx21 platform simulation:
http://sourceforge.net/projects/softgun/ seems like good simulation
software for ARM devices in general, on top of that it has a lot of
simulation build in especially for the imx21 devel-board.
Regarding Qtopia 2.1.0 PDA:
I've tryed to compile 2.1.0 last night, but this is a whole different
ballgame then 2.2.0 (which includes alle dependencies already). So far
compiling is thus without any luck. I also doubt if we should put much
effort in compiling the qtopia 2.1.0 stuff.. it wont help us much
further i think. There have been more attempts in the past to build up
on qtopia2.x, Opie (http://opie.handhelds.org) is the biggest example of
this (targeting palmtop and zaurus pda's), but development recently
stopped (so it seems).
For future development for these the devices i think it's probably
better to focus on qtextended4.4 (lots of apps: http://qt-apps.org/)
or qtmoko (http://activationrecord.net/radekp/qtmoko/ ,based on
qtextended4.4 / 2.6 kernel). Maybe also good would be Ångström
(http://www.angstrom-distribution.org/ ,based on 2.6 kernel/X11) or
Chumby (http://www.chumby.com/, 2.6 kernel, imx21 platform). All of
these bring a lot of work with them, running it on full on these
devices.
The question to be asked i guess, is: what do we want from these
devices?
They are made for voip video calling.. they are excellent for that, so
if that's what we want.. i think it's best to leave them as they are.
But there's of course a whole lot more potential, but that would likely
mean the complete firmware should be changed by something more recent
(like e.g. the ones mentioned above). Especially the tv-out function
would become very welcome then, because most of these dists are build
for bigger screens (PDA and likes) ;)
How do you all see this?
Cheers,
Joost
von Star K. (starkeeper)
Jörn schrieb:
> Hi,
> verbaut ist?
> Gruß Jörn
Weiter Oben steht, dass im VP6500 das WLAN direkt auf der Hauptplatine
drauf ist. Also kein extra WLAN-Modul. Kann das ein Besitzer des VP6500
bestätigen?
von Gert D. (gert_d)
Christian H. schrieb:
> Ob man den einsetzen kann, weiß ich noch nicht.
> Weiß da jemand genaueres?
> USBH deutet ja auf Host hin.
Gutes Beispiel. Schau mal in BB_Schem_75839_b.pdf in
http://cache.freescale.com/files/32bit/hardware_tools/schematics/iMX21ADSE_Schematics_and_BOM.zip?fpsp=1
nach - zum Anschließen fehlen ein paar Pins.
/G
von Ulrich P. (uprinz)
So, meine VP6500er sind jetzt auch angekommen. Yippie!
Nun sitze ich vor dem hübschen Teilchen und frage mich, wie man
zerstörungsfrei an die serielle Serielle kommt. Klar die Pinne liegen im
Batteriefach frei herum. Aber wenn man da was anlötet und das dann durch
die Batterien fädelt... Kann man über die Pad-Leiste nicht auch die
Spannungsversorgung realisieren?
Und beim 6500er ist unten links noch mal ein unbestückter 2-Poliger
Stecker. Wozu ist der da? Kann man hier vielleicht ein Akkupack
anschließen?
Jetzt muss ich nur noch warten, bis Fauchen vom PC weg ist, damit ich
die Jungs modden kann :)
Gruß, Ulrich
von Christian K. (Firma: Atelier Klippel) (mamalala)
> Cheers,
> Joost
Hello Joost,
yes, the 2.1.x stuff is a mess. However, i got it successfully compiled
for the x86 platform, and i'm in the process of cross-compiling it to
the ARM9 right now.
About newer versions, sure, that would be a nice thing. However, there
are a few problems with that approach, i think. From what i can see, a
few files for the Qtopia stuff are dependant on the actual hardware.
That means, to fully use all the functionality of the phone, that stuff
needs to be reimplemented. Like backlight control, for example. Then
there is the problem with the phone functionaly as a phone. The
installed software does that, but if we want to upgrade we have to
re-implement that stuff if it should be usable as a phone again.
My primary goal for now is to get some environment together that allows
for compiling QtEmbedded/Qtopia programs that run on the current phone,
so that people can extend the functionality without sacrificing the
existing functions.
Of course, for people who want to use that thing as general platform, it
is a good idea to get actual versions on it.
I think it's worth to have it both ways. I'll try to get the 2.1.x stuff
working, and others, like you, can start on the more recent versions.
Greetings,
Chris
von simultanuntertasse (Gast)
aktuell = current
tatsächlich = actually
von Ferdinand K. (foerdi)
Du könntest Federkontakte benutzen (siehe
Beitrag "[T]ipp: Testpins (Federkontakte) zum Selbstbau von Adaptern"), die sind genau für
solche Testpunkte gedacht. Über die Testpunkte solltest du auch die
Versorgungsspannung zuführen können.
Hi Chris e.o,
I'm personally not really interested in using it as a general
(development) board (o well.. maybe i use one of them for it ;)).
Looking at the functionality already built in to qtextended4.4 i think
most of the stuff which is on the phone right now is also supported in
qtextended4.4 (voip with video calling / camera functions) + a whole lot
more, which seems pretty nice to have (syncing options/email/etc), see
here for the full
list:http://doc.trolltech.com/qtextended4.4/fd-index.html.
In qtextended4.4 trolltech finally went nice and actually (tatsächlich)
put in all cool stuff and open sourced it (and then they stopped
development :().
It would be good to find out which parts of the current (aktuell ;))
installed qtopia version are really hardware specific. I think the
tv-out function would be one, backlight control another. Based on that
information something can be said about the amount of work which need to
be done to have the more recent qtextended4.4 running. The advantage
would obviously be a bigger community supplying applications (e.g.
http://qt-apps.org/) and we wont loose those great functions we have
right now. I don't think the kernel/filesystem/bootloader even have to
be changed.
Of course there are different roads to walk, just throwing in my
thoughts ;)
Cheers,
Joost
von Vlad T. (vlad_tepesch)
Ich habe das Ding zerlegt und dann auf die Pins solche einreihigen
gedrehten IC-Sockel Leisten gelötet:
http://www.reichelt.de/?ACTION=3;ARTICLE=19398;PROVID=2402
Zuerst unten die Spitze abgezwackt, dann ein wenig  Lötzinn drauf.
Auf die Pads auch ein wenig Lötzinn und dann auf die Platine aufgesetzt
und das Lötzinn verbunden.
Die aussparung im Gehäuse habe ich ein klein wenig mit einer feinen
Schlüsselfeile erweitert (an dem Gummi brauchte ich nix verändern).
jetzt hat man da von dem Batteriefach bequem zugang.
Die Federkontakte haben den NAchteil, dass sie auch irgendwie gehalten
werden müssen.
@Joost:
As you stated, expanding the qtopia 2.1 applications won't be easy. On
the other hand, it will take a lot of work to re-implement the
functionality that the device has today. It would surely be a lot easier
if we had access to the original source code, but I guess that it
contains lots of proprietary code and we won't get it unless someone
(and it won't be me) sues KPN or Philips for GPL violation.
So, I see people going in two directions:
a) the folks who're happy with the device as it is. They'll tinker a bit
with the original firmware, add a handful of command line tools, try to
use the camera as a webcam, play mp3s from the internal speaker, maybe
turn the help browser into a hypertext reader for RSS or email.
b) those who want to use the hardware for something completely different
and insist in using the latest kernel. Here I see MMC mass storage, an
X11 server, VGA out... maybe even something in the style of an always-on
ultra low-power X-terminal with an extra LCD status display (which can
show biff while the VGA monitor is off).
My five cents: these little devices are best at what they were designed
for: VoIP and video telephony. The "upgradeability" of the hardware is
poor (as I see it we won't be able to retrofit USB easily), most likely
someone will manage to connect a MMC/SD flash card, but even that
demands a new kernel, which is likely to break other things, which
depend on no-longer compatible modules. That's why, to most people, a)
is likely to be most appealing.
Cheers, groetjes,
/G
von karloheinzo (Gast)
@Markus Ried und snapper,
vielen Dank, für die Hilfe!!
Ich scheine also doch nicht der Mega-Dau zu sein (uff) - geht definitiv
nicht.
Ich komme problemlos auf die Kisten mit telnet drauf, habe auch schon
das Paket mit dem rudimentären deutsch Support installiert, alles
problemlos.
Könnte eventuell mal jemand sein  /user_data/data/hpr0userparam.cfg
posten (natürlich mit "ausgegrautem" Passwort)?
Ich habe echt keine Idee mehr !!!
Vielen Dank!
von MartinBaum (Gast)
jetzt klappt die Verbindung, hatte den alternativ DNS-Server nicht
angegeben,
deshalb wollte es wohl nicht. Kann auch sein das man zur ersten
Registrierung
WMM ausschalten muß.
Nun gibts noch einen telnet-Abend.
Danke an alle die zur sinnvollen Nutzung des Telefons beitragen.
Mein VP6500 liegt auch schon auf dem OP.
Gruß Martin
Gert D. schrieb:
> but I guess that it
I doubt that there are any severe violations. Qtopia is not GPL, and
propietary kernel drivers are not uncommon as well. The most that can
(and should) hand out are the sources for the parts that are really GPL
or that they modified, but are based on original GPL code.
Gert D. schrieb:
> most likely
At least for the 5500 i see a little chance. From what i see, the WLAN
module uses a regular PCMCIA/PCCard interface (i think, could be another
standard-interface... have to re-check the kernel boot-log and the
drivers)
That would mean that other stuff could be plugged in, maybe even in
addition to the WLAN module.
Of course, owners of the 6500 are out of luck there, since it is
soldered on the board. At least it won't be easy to hack that aspect of
the hardware.
Greetings,
Chris
Danke, dann müsste ich die erst mal ordern...
Also bei einem mal die Pinne direkt angelötet, habe eine lange feine
Spitze, auch kein Problem.
Leider bekomme ich vom Blob immer nur fortlaufend die Meldung, dass er
das serielle Kommando nicht versteht. Scheint ein Problem mit dem Port
des openocd-usb Adapters zu sein.
Also wollte ich ein anderes Gerät mal über die DNS-Umleitung frei
schalten, aber das verweigern alle drei. Ich nehme mal an, dass die das
Firmware-Update sicherheitshalber nur dann durchführen, wenn die Akkus
voll sind. Und das ist halt noch nicht der Fall. Also werde ich erst
morgen weitere Versuche starten können.
Gruß, Ulrich
> development :().
If i got it right, QtMOKO, GreenPhone, etc. are based on that, so there
is at least some development going on, and a chnace to "back-port"
things.
The TV-Out uses /dev/fb1, so it's rather easy to use from what i can
see. Maybe just some pin toggling to get the converter-chip running. And
if there is more, IDA-Pro is our friend ;)
Greetings,
Chris
Christian Klippel schrieb:
> Gert D. schrieb:
>> Im allgemeinen wäre eine "Entwicklungsumgebung aus der Dose" vermutlich
> ich habe eine Kubuntu 8.04 VM aufgesetzt und richte das grad zum
Kubuntu 8.04 ist prima. Falls ich die Wahl hätte, hätt ich aber eher was
kleineres auf Debian-Basis genommen (oder eben gleich Debian). OOo
braucht man in der Entwicklungs-VM eher selten ;-)
Die Idee mit dem Torrent ist übrigens gut. Den kann bestimmt jemand
hochladen. Ein Problem ist dann höchstens noch, wie man künfitig
"Updates" der Entwicklungsumgebung verteilt.
Grüße
/G
von Christian H. (netzwanze) Benutzerseite
> http://cache.freescale.com/files/32bit/hardware_to...
Das sind die USBG_...-Anschlüsse.
Der Prozessor hat neben USB-OTG noch zwei "normale" USB-Ports.
Ok, das bringt nicht wirklich etwas. Ich hatte nur etwas von multiplexed
gelesen und dachte in meiner Naivität, dass diese Signale auch auf
andere Pins geschaltet werden können (bei einigen Prozessoren ist ja
sowas möglich).
Schade eigentlich. Ich hätte gerne einen USB-Host-Port gehabt.
So noch mal de kleine Rückmeldung und eine Frage...
Die Serielle funktioniert, habe mir auch das telnet schon mal frei
gemacht. Fein.
Dass die Dinge die mods von sprite_tm's Server nicht abholen, kann das
auch daran liegen, dass mein Netzt nicht 192.168.2.x ist, sondern
192.168.10.x?
Da war doch mal was...
Gruß, Ulrich
von Robert (Gast)
Sind auf dem VP6500 und dem VP5500 die gleichen WLAN-Chips verbaut? Also
hinsichtlich WMM und WPA2? Oder hat evtl. nur das VP6500 einen Chipsatz
der AES in Hardware unterstützt?
Toll wäre von der Anwendungsseite eine Art Überwachungskamera bzw.
Babyfon: Wenn sich etwas vor der Kamera bewegt oder es Geräusche gibt
wird ein Videoanruf auf ein zweites Gerät oder einen COmputer gestarter.
Wie sehen die Experten die Chancen dafür?
Hurra,
es geht jetzt (Registrierung an der Fritz Box 7270)!! Warum?
Ich bin mir nicht ganz sicher, ich habe
1. beim WLAN das N abgeschaltet,
2. die Telefone wieder auf Englisch umgestellt (ich glaube, das ist die
Ursache-deutsch geht es nicht)!!
Noch mal vielen Dank an die Tipgeber!!
> 192.168.10.x?
Kaum. 192.168.x.x wird im Internet sowieso nicht geroutet.
hehe, that is something which i thought about as well, i've asked
(bugged) Philips, KPN and the main vpx500 projectmanager (after a long
search i traced him) multiple times for giving out the source.. without
any success. Maybe a nice case for a law student in software rights..
since i'm not one of them, i also consider this a dead end.
This is indeed (reading the full thread) the current intention of most.
Sounds as a great goal as well ;) ..and i want to add a third option:
c) those who are happy with the functions of device and want to keep
them, but also want to be able to use the extra stuff which is already
out there. This means taking the top layer off (qtopia2.1.0) replace it
with a similar (but more recent) layer (qtextended4.4), without losing
the current functions.
Most (all?) of the possible wishes you summed up in a. (mp3 playback /
webcam / streaming video etc) are already build and ready to run if c.
can be accomplished... if ;)
With the small amount of empty space and the lack of MMC/SD/USB,
upgrading possibilities are indeed very limited. Even if c. could be
accomplished you probably need to do an nfs mount to store all the extra
applications, which then won't be the fastest because of the (relative)
slow wifi connection you're stuck with.
Nevertheless, i think i'm gonna focus on c. for now (I already tinkered
with the device for a few weeks ..e.g. option a. ;)). b. is not an
option for me at this point, as i have very less knowledge about
hardware stuff (that's why i asked sprite to help out in the first
place) and it would take me loads of time to get those skills (but it
sounds like fun though ;)).
I'm very curious to see where we all are in a few months, whether it is
with option a. b. or c. or people doing just the greatest stuff with it,
as it is, but originally not meant to be used for (e.g. calling up
friends from a bar drinking beers and filming cute girls while having
illegal wifi access on someone's accesspoint ;))
Prost,
Joost
von Roman (Gast)
Guten Abend zusammen,
nachdem ich den Mut gefasst habe mich auf dem VP einzuloggen und etwas
auszuprobieren, habe ich erstmal eine Datensicherung durchgeführt.
Dabei fiel mir auf das das VP einen ftp-Client hat. Dieser ist zwar
etwas schmallbrüstig, ihm feheln dir local Kommandos, aber der Upload
von dem Backup der Rootpartition war in 1 Minute erledigt.
Roman
Hi!
@Roman: Gute Entdeckung.
@All:
Habe das hack2.tgz per wget auf / des Tel kopiert. Dann per
tar xfzv hack2.tgz
das Archiv entpackt. Dabei hat er wohl die meisten Dateien ersetzt, denn
nun geht das Telnet auch nach einem Reboot. Aber die de-Dateien aus dem
i18n sind nicht mit gekommen. Im Archiv sind sie drinn.
Ich finde keine Einstellung um das Teilchen von NL auf US oder DE
umzustellen. Leider werde ich aus dem NL nicht schlau genug, um die SIP
Anmeldung auf einer 7170 hin zu bekommen...
Naja, ich probiere noch mal weiter.
Gruß, Ulrich
von blooza (Gast)
Schau mal bei den Einstellungen nach Taal...
von Ralph S. (rallerix)
> Roman
geht denn auch die umgekehrte Richtung: vom PC per ftp aufs VP5500?
Welche user/pw- Kombi?
Rallerix
von Daniel K. (blooza)
> 192.168.10.x?
Nein, ich glaube das Problem bei Sprite's DNS liegt im Moment an der
verwendeten swinfo! Sprite scheint aber auch nichts davon zu wissen!?
Vielleicht schaut er ja mal wieder vorbei?
kann man eigentlich das qtopia neu starten, ohne das gerät aus und
wieder einzuschalten?
mich nervt ein wenig, dass jedes mal die telnet verbindung stirbt, wenn
ich veränderungen testen möchte
Das Telefon scheint aber tatsächlich Probleme mit dem Akku zu haben.
NAchdem er den ganze Tag geladen hatte und vorhin voll war, zeigt er
jettzt nach einen Neustart wieder leer an.
 Das ganze hab ich gestern auch schon mal beobachtet. Das Telefon hat
aber trotz der Anzeige bis heut nachmittag durchgehalten.
Deutsch ist nicht da, aber Englisch ist auch wunderbar, endlich verstehe
ich das Ding :)
Also, das erste Telefon funktioniert an der FB7170.
Ein kleiner Test gegen das E61i zeigt keine Probleme, anrufen und
angerufen werden ist kein Problem.
Nun ist das 2. drann, ich nehme den Umweg über die Serielle, drei
Drätchen anlöten ist einfacher als jetzt noch Stundenlang mit den
IP-Einstellungen zu experimentieren.
Mit ist aufgefallen, dass das VP6500 wirklich nur dann etwas über die
Serielle ausgibt, wenn der TIN Pin auf GND liegt.
Das VP bootet auch nicht fertig durch, wenn TIN auf GND liegt, aber man
kann das Problem umschiffen. Nachdem man einmal mit boot-Parametern
gestartet hat und das root-Passwort geändert ist, macht man einen
Kaltstart.
Dann bootet das Telefon und man lässt TIN high. Wenn dann die
Splash-Screen erscheint, kann man TIN wieder verbinden und ist auf der
seriellen Konsole.
Dann den Rest erledigen, bis Telnet geht, dann braucht man die Serielle
eh nicht mehr.
Gruß, Ulrich
von karl (Gast)
meine akkus scheinen auch nicht mehr wirklich fitt zu sein .... 24
stunden hat mein akku gehalten ... ich tippe das die die lange lagerung
ohne saft ziehmlich kaputt gemacht hat... vielleicht sollten wir mal
schauen ob sich nicht irgendein handy akku zweckentfremden läst ?
von Michael S. (Gast)
Also ich hab meine Vp6500 auch "gerooted". Hab dazu eine alte Fritz Box
Fon Wlan genutzt und mithilfe von Freetz ein Firmware Image für die Box
erstellt. Entsprechend der Anleitung von sprites mit DNSMASQ die
bekannten Addressen auf die Fritz-Box umgelenkt und damit dann die
swinfo und hack.tgz auf die WLAN-Phones übertragen...
happy hacking
Hab ich auch schon überlegt. Die Frage ist, kommt die Ladeschaltung mit
anderen Akkus klar. Wird das vom Linux gesteuern, oder ist das
unabhängig?
von Marcus S. (marcus3967)
Ich habe jetzt ein VP5500 soweit am Laufen (via 1und1), daß ich
rausrufen kann. Aber beim Angerufen werden passiert nichts. Ein
Softphone auf dem PC kann mit den gleichen Einstellungen in beide
Richtungen. Am Router oder so sollte es also nicht liegen.
Was habt Ihr für folgende Punkte eingestellt:
SIP_SYMETRIC
SUBNET_MASK
PRIMARY_RTP_PORT
PRIMARY_RTCP_PORT
SECONDARY_RTP_PORT
SECONDARY_RTCP_PORT
Woran könnte es noch liegen?
Eingehende Gespräche sind sehr leise, wo kann man das einstellen?
Danke,
Marcus
von karl (Gast)
@vlad
cd user_data/data/battery/
battery_current.cfg     battery_error.log
battery_dev_delta.cfg   last_battery_level.cfg
dem nach läge meine wette hier das linux zumindest daran beteilig ist...
von karl (Gast)
@Marcus S.
es kann trotzdem am "router" liegen ... viele softphones können per upnp
und oder per stun sich die entsprechenden ports auf machen und oder frei
halten ....
du könntest versuchen auf dem telefon mal stun an zu machen ...
@karl:
stun ist eingestellt:
#Stun server address
STUN_SERVER_ADDRESS=stun.1und1.de
#Stun server port
STUN_SERVER_PORT=3478
wie gesagt, das komische ist, daß zwei versch. softphones angerufen
werden können, das vp5500 jedoch nicht. falls da irgendwelche ports
oder so aufgemacht werden müssten würde das auch für die softphones
gelten. upnp ist im router ausgeschaltet. wenn ich das vp5500 anrufe,
höre ich im rufenden telefon nicht mal ein klingeln...
Ich habe im Vorübergehen ein paar Dateien gefunden, die mit dem Akku zu
tun haben. Kann sein, dass dort Kalibrierwerte für den Akku eingetragen
werden können. Ich weiß jetzt nicht mehr, wo die steckten, aber wenn ich
mich am Wochenende weiter mit den Teilchen auseinander setze, melde ich
mich dazu.
Hoffe nur dass die hacks diese Dateien nicht überschrieben haben. Das
könnte die merkwürdige Akku-Anzeige erklären.
Andererseits, wenn die Dinger wirklich seid 2007 irgendwo herum gelegen
haben, dann können die Akkus auch gelitten haben.
Noch eine Frage an Alle:
Kann man die Dinger auch irgendwie Benamsen? Also ihnen eine auf dem
Display sichtbaren Namen geben, oder die interne Nummer einblenden?
Das wäre wirklich hilfreich und erheblich schöner, als wenn ich da jetzt
Aufkleber auf die Rückseite machen muss mit Nummer und IP...
Gruß und gute Nacht
Ulrich
von Sörn (Gast)
DAS wuerde mich auch mal interessieren - ich habe hier mehrere und lasse
durch schalten der tastaturbeleuchtung kurz aufblinken - aber eine
"tolle" loesung ist das nicht gerade...
Ich habe schon versucht, den Screensaver anzupassen, aber in der Doku
hatte ich nichts brauchbares gefunden. Ich tippe mal darauf, das man das
irgendwo in der qpe.conf anpassen kann - aber wo? ...keine ahnung.
"Infobox = ..." in der screensaver sektion hat jedenfalls nicht
geholfen.
Ich glaube das was hier steht, ist alles was von config seite her geht:
http://qt.nokia.com/doc/qtopia2.2/html/qtopiatheming.html
...und da steht ausser der infobox nichts brauchbares - problem ist, das
die infobox a) schon belegt ist und b) nur im homescreen und eben nicht
im screensaver geht.
Ja, das geht. Zumindest einen festen Namen geben. In dem script unter:
/usr/local/startup_V4.20/daemon.sh
gibt es einen Bereich der sich liest:
HOSTNAME=VP5500_`grep MACAddress /proc/net/wlan/info | cut -d'"' -f2 |
cut -d':' -f4-6 | tr -d ':'`
#HOSTNAME=chuck_`ifconfig | awk '$4 ~ /^HWaddr$/ {print $5}' | cut -d':'
-f4-6 | tr -d ':'`
Einfach das HOSTNAME= anpassen, z.b. in HOSTNAME=MeinTelefon
Dieser Name wird dann an den DHCP Server gegeben, somit sollte dann
(wenn der ebenfalls Rputer, etc... ist) das Telefon im Netzwerk unter
diesem Namen ansprechbar sein.
Eine Anzeige auf dem Display würde über ein eigenes Hintergrundbild
gehen. Das speichert man im .PNG Format dann auf dem Telefon im
Verzeichnis:
/usr_local/pics/wallpaper
ab. Format ist 176x220 Punkte. Anschliessend am Telefon unter den
Einstellung "Appearance" das Bild auswählen.
Grüße,
Chris
von R. H. (snapper)
nein, siehe 2. beitrag ganz oben von mir, auf dem bild ist wegen dem
blechstreifen über dem chip leider nicht die bezeichnung des IC´s zu
lesen und leider haben wir auch noch kein foto von der anderen seite des
vp65xx
aber vl ist jemand von den "hardcore" bastlern, der sein vp6500 sowieso
zerlegt hat ja bereit, uns das mal kundzutun !
> wird ein Videoanruf auf ein zweites Gerät oder einen Computer gestarter.
einaches babyphone hast du im prinzip ja mit 2 geräten und dem
demomodus, darfs´t nur nicht vergessen bei dem phone im kinderzimmer den
LS auszuschalten und brauchs´t natürlich entspr. licht für die cam
(infrarot?)
> Kaltstart.
> seriellen Konsole.
Das ist aber nur Anfangs so. Man kann diese Verhalten durchaus ändern,
das habe ich hier auch schon mal gepostet. Thread lesen hilft!
Hier nochmal, nur für Dich:
Das 5500 scheint nicht komplett zu starten wenn man TIN auf low hat und
die serielle Schnittstelle benutzt. Man kann das Gerät dann nicht normal
bedienen. Dies lässt sich ändern indem man in der Datei
/usr/local/startup/daemon.sh
ziemlich am Anfang das TINDETECT="TRUE" ändert auf TINDETECT="FALSE"
Danach startet er auch mit aktiver serieller Verbindung komplett durch
und das Gerät ist ganz normal bedienbar.
Grüße,
Chris
Zum Thema anzeigen des Namens, etc....
Es gibt ja diese Themes. Wie einigen vielleicht schon aufgefallen ist
hat z.B. das "Gel" Theme eine Anzeige der Uhrzeit+Datum in der oberen
Leiste.
Gesteuert wird das ganze über .xml Dateien der Themes. Schaut mal in
/usr/local/etc/themes rein. Dann mal in der Doku zu Qt/Qtopia/QtEmbedded
schauen was es da so gibt.
So ist im "Gel" Theme eine Zeile in der title.xml:
<text name="datetime" short="yes" size="12" color="HighlightedText"
shadow="200" interactive="yes"/>
die dafür verantwortlich ist das eben Zeit+Datum dort stehen. Wer weiss
was es da noch alles an Möglichkeiten gibt.
Man kann sich auch eigene Themes bauen, die Bilder die ein Theme
verwendet sind alle unter /usr/local/pics/themes zu finden.
Grüße,
Chris
von R. H. (snapper)
schon mal jemand bemerkt, das in den cam modulen magnete eingebaut sind
? ich hatte zufällig ne büroklammer dran hängen, wozu die wohl gut sind
? habe ich bei cam modulen so noch nicht gesehen. vl kann der tino,
der sein gerät ja sowieso geschrottet hat das cam modul mal öffnen, vl
erfahren wir dann auch noch eine genauere bezeichnung des moduls !
anbei die datenbl. der im 6500 verbauten speicher.
von Roman (Gast)
Hallo Ralph,
wenn Du den ftp-client auf dem VP aufrufst, dann kannst Du mit den
Befehlen put und get in beide Richtungen arbeiten. Deswegen war mir die
Mitteilung auch so wichtig, das ich sie hier gepostet habe. Per Netcat
waren die MS-User erst mal draussen. So ist es einfacher.
Roman
von Tino N. (tino)
Ich werde heute Abend mal das Modul zerlegen. Könnte mir aber vorstellen
dass der Magnet für die Positionserkennung zuständig ist. Wenn man die
Kamera um 180° dreht, würde ja das Bild sonst auf dem Kopf stehen.
Hab aber die Teile gerade nicht hier, die liegen auf dem Schreibtisch
Zuhause.
@Magnet
Das Telefon erkennt tatsächlich die Position der Kamera und dreht das
Bild entsprechend um. Dafür ist sicherlich der Magnet da; passend dazu
gibt es sicherlich noch ein Reed-Relais (obwohl ich bisher immer auf
Kontaktfeder getippt hatte).
@Akku
Ja, die sind wohl wirklich größtenteils Schrott.
Hatte beide Telefone eine Zeit lang (3-4h) am Ladegerät. Danach konnte
ich die ohne weiteres aus der Station nehmen und "hacken". Sie liefen
einwandfrei.
Dann hatte ich sie abgeschaltet (spart Strom) und in meinen
Bauteileschrank gelegt. Nun wollte ich am nächsten morgen eines nochmal
einschalten um etwas zu kontrollieren - Nix passiert. Akkuzustand wie
bei Lieferung - LEER.
So nicht ganz richtig. Ich hatte weiter oben bereits auf ein
Netcat für Windows verwiesen:
>PS: netcat für Windows hier:
>http://joncraton.org/blog/netcat-for-windows
Dieses fkt. auch wunderbar!
hat jemand die busybox von http://vp6500.bd8.nl/ installiert?
das archiv enthält dummerweise noch einen unterorder  busybox-1.11.2-1.
wie verscheibe ich nach dem entpacken die Ordner aus diesem nach root?
mv will die nicht verschieben, da die ordner nicht leer sind.
Oder kann man tar anweisen, dass es die Files direkt aus dem Unterordner
aus dem Archiv holen soll
So nachdem die USB-Pläne ja endgültig gestorben sind, dachte ich an den
Anschluss einer SD-Karte. Dazu sollten doch die Pins vorhanden sein:
34    Pin D 19 an IC5    CSPI2_SCLK
37    Pin D 18 an IC5    CSPI2_SS0
38    Pin E 19 an IC5    CSPI2_MOSI
54    Pin E 17 an IC5    CSPI2_MISO
Das wäre dann zwar kein SDIO-Interface aber über SPI kann man eine
SD-Karte ja auch ansprechen. Was meint ihr dazu?
von M. S. (schreinerman)
Bzgl. Akku einfach mal bei www.lipoly.de schauen. Da gibts Litium
Polymer Akkus. Der Umbau ist aber nicht ganz trivial (!). Bei falschem
Umbau droht Explosion Gefahr!
Bzw. Akkus gibts bei jedem Modellbau-Laden (hier z.B. auch
http://www.sl-motec.de/shop/start.htm?akkus___lipo_1s__3,7v_lipo's.htm)
von Timo (Gast)
hat eigentlich jetzt schon jemand Perl für das VP kompiliert und zum
laufen gebracht?
von R. H. (snapper)
den original akku gibt es hier :
http://www.atlbattery.com/eng/Psheet3759.html
modell : 503759
wer bedarf hat kann ja mal anfragen:
http://www.atlbattery.com/eng/contact.html
vl. sammelbestellung ?
nur die ladeelectonic wäre umzulöten !
vl. passt ja sogar noch ein etwas dickerer rein ?
5.05mm 1150 1200mah
5.50mm 1280 1350mah
6.40mm 1500 1560mah
von robin26 (Gast)
unser "Po**in E-Schrott" entwickelt sich ja super.
Mir scheint es gibt immer wieder Probleme von usern mit der SIP
Konfiguration. Ich hatte auch so meine Probleme mit DNS
Portweiterleitung... Meine Frage wäre ein zusätzlicher client der andere
Protokolle (z.B. Skype) unterstützt machbar? Auf meinem E51 habe ich
fring das mehrere logins (skype/sip/g-talk/icq...) bündelt. Da gibts
weniger config Probleme. Skype video ist sicher auch wesentlich
verbreiteter als SIP Video. Fring gibts auch für linux aber vielleicht
gibts ja noch was besseres...
robin26
von R. H. (snapper)
> 5.05mm 1150 1200mah
> 5.50mm 1280 1350mah
> 6.40mm 1500 1560mah
mal ein gleichgrosses stück platine auf den akku legen und sehen, ob der
deckel dann noch zugeht, mach imho 350mah !
Is ja schon jut...
Du musst aber zugeben, dass es hier inzwischen etwas unübersichtlich
geworden ist. Ich habe es dann später auch in einem der vielen zu diesem
Projekt angelegten Wikis gefunden.
Frage mich an dieser Stelle, ob das Dauerhafte Aktivieren dieser Option
aufwirkung auf den Akku hat. Warum sollte man es sonst überhaupt
abschalten. Naja, 'Sicherheit' ist es nicht wirlich, denn der
Kernel-Bootstring kommt auch ohne TIN hin und wieder. Eventuell EMV
begingt.
This is pretty much enough to simply write an email to the fsf, even
without beeing a law-student. But I'll try my connections too.
Linux kernel
I am not sure is a new kernel will break the box. At the beginning of
the thread someone mentioned that the audio code, the wlan chipset and
the LCD is already supported by the kernel. All we need is a keyboad
driver using a matrix keyboard at GPIO. I doubt that this doesn't exist
already, but I am sure, that the driver needs some adaption to the
layout. Not a problem I think. By the way, while TIN is low the kernel
reports every keystrok with the corresponding matrix code or GPIO that
changed. This is also valid for the camera position switch and the
charge recoginition.
I never checked with the mod for not needed TIN so I cannot tell if the
debuging is then active too.
With knowing that there is a >85% chance for getting a new kernel, wlan
and VoIP going. I have never installed a small body sip client on a
device, so I don't know about that. But it shouldn't be hardware
dependent.
For me it would be important to get openocd going on the device. If that
works I support anyone going for a uBoot or Blob upgrade as preparation
for any 2.6.x kernel.
In General / Allgemeines:
Shouldn't we split this thread into some pieces?
Sollten wir den Thread nicht splitten?
- Allgemeines und Konfiguration
- VPx500 Hardware
- Current kernel/qt2.1 based improvements
- New kernel 2.6.x/new qt improvements
Die Idee kam mir, weil der Welek Oszylloskop Thread den gleichen Weg
gegangen ist für Hardware / Software
Gruß / Best regards,
Ulrich
von Thorsten F. (blay)
Da Dieser Thread sich mittlerweile so exponentiell entwickelt, dass
selbst ich langsam den Überblick verliere, schlage ich eine andere Form
der Kommunikation vor.
Ich habe erstmal zusätzlich einen IRC Chanel eingerichtet:
#VPx500 auf irc.tu-ilmenau.de (IRCnet)
Sicherlich wäre auch ein Forum ganz sinnvoll, damit mann nicht immer
Suchen muss, was sind nun Informationen, und was sind Dau Fragen.
Wo könnte das sein? hier vllt: http://www.ip-phone-forum.de ?!
Ich bin da für alles offen.
von Andreas Z. (andreas1000)
R. H. schrieb:
>> 5.05mm 1150 1200mah
Da haben es die VP6500 Besitzer etwas besser: der Original VP5500 Akku
hat laut PHILIPS Bedienungsanleitung 1100mAh (ATL gibt 1150-1200mAh an),
wenn ich in das VP6500 zwei NiMH Mignon Akkus mit 3500mAh lege, sind das
2,4V x 3500mAh = 8,4Wh
gegenüber dem LiPo mit
3,7V x 1200mAh = 4,44Wh
also fast das Doppelte.
Ich habe mein VP6500 gestern bekommen, der "Umbau" war easy und hat auf
Anhieb geklappt, SIP Verbindung mit der FBF7170 auch sofort (nachdem ich
den Tippfehler im Passwort gefunden hatte...).
Habe das Teil über Nacht geladen (z.Z. 2300mAh Akkus drin, PHILIPS
liefert 1800'er mit) und seit 8:00 von der Ladestation runter - mal
sehen wie lange es durchhält. Ich werde damit heute telefonieren und
auch via Telnet noch so Sachen machen ;-)
Andreas
von Franz B. (byte)
L.O.L
2 Gehirne, ein Gedanke.
Während des Telefonats Cursor hoch/runter
finde ich nicht so toll
neue Informationen sollten in das Wiki eingetragen werden.
Hier können ruhig Probleme Diskutiert werden.
nur sollte vor einer neuen Frage da gschaut werden.
Sehe ich genauso: hier werden Probleme diskutiert und gelöst, um dann
ins Wiki zu wandern.
Aprospros Wiki:
Ich arbeite mich gerade durchs gestern von meinem Telefon gesaugte
filesystem und finde da an der einen oder anderen Stelle interessante
Dinge, z.B. unter "user_data/first_usage_date.txt" das Datum, wann das
Telefon zum ersten mal eingeschaltet wurde. War wohl für Garantiezwecke
gedacht.
Mein Vorschlag ist, daß wir das Wiki um einen entsprechenden Zweig
"filesystem" erweitern, in dem interessante Verzeichnisse und Dateien
erläutert werden.
Was haltet ihr davon?
von Roman (Gast)
Zur Stromversorgung,
der Regulator scheint ein
http://www.fairchildsemi.com/pf/FA/FAN2515.html zu sein. Ansonsten bin
bei einer Sammelbestellung für die Akkus dabei.
Roman
> erläutert werden.
Ich finde es Günstiger nach Effekt zu gliedern.
Habe ich bisher auch so gemacht.
Aktivierung WPA -> zu veränderne Datei
Veränderung der Menus -> zu verändernde Dateie
Eventuell könnte man aber auch ein Parallelindex erstellen, der nach
Dateisystem sortiert ist, wo dann bei relevanten Dateien auf die
entsprechende Unterabschnitte verlinkt wird.
Unter umständen enthält ja eine Datei mehrere Sachen, bzw umgedreht.
von Karl (Gast)
lustig finde ich das in der einen akku datei der lipo mit 950mA(so ich
das richtig deute) drin steht ?!
ich finde, man sollte diesen thread splitten und die ergebnisse ins
wiki posten. durch die entwicklung hier muß man schon ziemlich suchen,
bis man was zu 'seinem' thema findet.
wie wäre eine einteilung in
hardware
software
sip configuration
etc...
nur mal so als vorschlag
Prima Idee: je nach Bedarf (bzw. Veranlagung ;-) ) kann dann jeder
entsprechend suchen.
@Gert D.
> Mit
./mini-inetd 80 ./micro_httpd 1 /
>  bekommt man einen kleinen Webserver...
Du hast nicht grad' zufällig Lust, auch mal einen micro_ftpd zu
kompilieren... (grins)
Andreas
Komisch bei mir funktioniert der Softhack nicht!
Ich habe das Phone in mein WLAN gehängt, zuvor den DNS umgebogen auf den
von sprites seite. Nach dem Reset holt sich das phone auch wie
beschrieben die uhrzeit vom server 01:58. Dann stecke ich das Telefon in
die Ladestation und warte 10 Minuten oder mehr. Aber es passiert nichts,
kein Update, habe schon gewartet bis die Uhrzeit bei 2:20 stand.
Hat jemand noch einen Tipp für mich, was ich falsch machen könnte?
von karl (Gast)
lass den akku mal laden und versuch es in ner stunde nochmal ....
anscheint haben sie da einen "wenn akku zu leer mache kein upgrade"
drin... das kann ich aktuell nicht belegen aber ich hatte mit meinen
beiden auch das problem das es das erst nach einer stunde tat
Also den Akku habe ich die ganze Nacht über geladen. Allerdings hatte
ich da nicht die ganze Zeit das WLAN an.
Da bin ich erst einmal dagegen :)
Denkt daran, dass Viele auf der Arbeit keinen IRC Zugang haben, außerdem
wird dann vieles auf dem kurzen Weg besprochen, was nirgendwo wieder
auftaucht und für Andere wichtig oder interessant wäre.
Gruß, Ulrich
von Sörn (Gast)
Sourceforge Projekt?
Da hätte man ein, bzw. merhere Foren und nen SVN wo man den ganzen
krempel rein laden kann...
von Timo (Gast)
hab mal ne Quick&Dirty-Webcam-Lösung gebaut.
- *.sh-Dateien ins Root packen.
- php-Datei auf nen PHP-Server hochladen (hab mir schnell einen
kostenlosen bei bplaced.net gemacht)
- die Datei webcam.sh starten
- http://deinServer/test.php
Erklärung: webcam.sh schreibt alle 10 sekunden den Framebuffer /dev/fb0
in eine Datei. Diese wird durch upload.php per ftp auf den Server
hochgeladen.
Die php-Datei wandelt das 565-16Bit-Bild in ein jpg um.
Bitte entschuldigt mein unschönes Coding :-)
von Timo (Gast)
was ich noch vergessen habe:
Die Anwendung "Webcam" muss auf dem VP laufen.
Der Screensaver geht nach ner Zeit an. Dass das nicht passiert kann man
aber sicherlich irgendwo einstellen. War nur grad zu faul zum suchen.
Es wird also immer das aktuelle Bild, welches man auf dem LCD sieht, auf
den FTP geladen.
von Timo (Gast)
die Einstellung, dass er nach ner weile wieder in den homescreen geht,
müsste in /user_settings/qpe.conf stehen:
suspend=0
homescreen=0
mal testen.
naja, nicht grad die schönste lösung.
Was passiert, wenn der Framebuffer gerade geupdated wird?
Trifft man das nicht regelmäßig?
von Timo (Gast)
also ich hatte bisher immer korrekte bilder raus.
von ca. 30 versuchen.
Sourceforge...
ist eine gute Idee!
Da nicht jeder das passende Besteck für die Binaries hat, müsste man den
Quellcode ins SVN und die fertig compilierten Sachen zusätzlich ablegen.
Aber das sollte bei Sourceforge doch alles gehen.
Gruß, Ulrich
Noch ne Frage,
kann man
1) Mehrere WLANs aktivieren?
2) Automatisch zwischen diesen roamen?
Habe zwei WLAN Router, die im selben LAN sind. Haben beide eine
unterschiedliche Frequenz und SSID, aber gleiches Passwort.
Oder sollte ich beide mit gleicher SSID fahren und die VPs nehmen sich
den stärker empfangbaren automatisch?
Gruß, Ulrich
von florian (Gast)
ein paar stichworte:
man kann die gesamten SIP einstellungen wohl per DHCP vorgeben, so dass
man - wenn man das teil nur als telefon benutzen will - gar nichts
ändern muss.
auf der experia-box war ein SIP-proxy. die phone melden sich als user
103 mit dem passwort kpn an. die box vermittelte das dann weiter ins kpn
netz.
je nachdem ob man thomson oder siemens als box angegeben hat, wurden
unterschiedliche IPs für den proxy benutzt.
der syslogd auf dem teil kann im Vordergrund auf /dev/stdout loggend
gestartet werden. da steht dann drin, wann man das teil zum laden
reinlegt, rausnimmt und ob man die kamera dreht.
ausserdem schlagen da die stackraces auf, wenn man per SIP das telefon
zum absturz gebracht hat -.-
der akku in meinem ist auch ziemlich platt.
das telefon benutzt nicht ntp sondern das time-protokoll auf port 37 -
chronos.zedat.tu-berlin.de kann man als server nehmen.
den update-server kann man umbiegen und so einen eigenen rechner
angeben, damit man nicht immer den dns umbiegen muss. In der upgrade.cfg
kann man auch angeben, von welchem pfad das update kommen soll. wenn man
die hour auf 0 setzt, holt das auch direkt nach dem einschalten da ein
update...
videocalls habe ich mit sipgate noch nicht hinbekommen.
nebenfrage: ich verstehe grade nicht, wann das teil auf 'lauthören'
stellt und wann nicht bzw. wie man das unterbinden kann. habe gestern
nacht einige testanrufe gemacht und das war schon relativ laut ;)
im menü war leider kein punkt dafür :/
in der monitor.cfg stehen so interessante  Sachen wie:
#DHCP Parameter
DhcpDefaultA=42;66;120;224;225;226;229
#DHCP Parameter
stunserver=229
#DHCP Parameter
ntpserver=42
#DHCP Parameter
tftpserver=66
#DHCP Parameter
sipserver=120
#DHCP Parameter
sipusername=224
#DHCP Parameter
sippasword=225
werde die tage mal ein fabrikneues telefon nehmen und an einen
entsprechend konfigurierten dhcp klemmen - also mit parameter 225 ein
passwort angeben, etc.
für openwrt sieht die config dann so aus:
  list dhcp_option '120,172.16.1.1 42,172.16.1.1'
eventuell muss man diese DHCP-Konfig aber noch auf dem phon aktivieren.
mal sehn. Ich habe aber an vielen stellen gesehen, dass die optionen
auch per dhcp gesetzt werden können.
wäre natuerlich praktisch, wenn man mehrere telefone hat und die zentral
administrieren will :) - oder an verschiedenen orten benutzen will :D
von Roman (Gast)
Guten Tag,
Martin Baum haz weiter oben beschrieben das das Telefon alle 10 Sekunden
sich bemerkbar macht, repasktive ins Netz sendet. Vielleicht sollten wir
versuchen diese Stellen in der Konfiguration zu finden und z.B. auf 60
Sekunden zu setzen. Vielleicht lösst sich damit auch das Akku Problem.
Gruss
Roman
von Griesi (Gast)
mit chronos.zedat. fu -berlin.de ist die Zeit -glaube ich- genauer ;)
noch mal die Frage zu busybox? hat die schon mal jemand installierT?
Ich habe das arcchiv von der http://vp6500.bd8.nl/ seite runtergeladen
und entpackt.
Da es ein zusätzliches subfolder enthält liegen nun alle files in
/busybox_versionsnumme
verschieben will nciht, wegen nicht leeren verzeichnissen
Da wollte ich es kopieren, aber ich bekomme lauter meldungen:
cp: unable to open `/bin/dd': Text file busy
Beim letzten mal (als man mit der flaschen donfig das telefon
zerschossen hat) konnte er das doch auch einfach überbügeln.
Was mach ich also falsch?
von Griesi (Gast)
ich glaube bei einem Video-Gepräch stellt das Teil automatisch auf laut
um.
Ist ja auch logisch, dann hält man das Telefon nicht ans Ohr sondern
schaut auf den Bildschirm ;)
von Andreas S. (andreas) (Admin) Benutzerseite
Das geht auch hier auf Mikrocontroller.net. SVN-Server gibt es (siehe
Hilfe: SVN), Dateien kann man im Wiki hochladen.
von R. H. (snapper)
betr. Alternative Dropbear und winscp
wie ich im wiki gelesen habe:
können mittles eines Programms mit SCP-Unterstützung (zB. WinSCP für
Windows) sehr komfortabel Dateien ausgetauscht werden.
Mit WinSCP können auch Dateien direkt bearbeitet werden. Der Client läd
die Datei herunter, öffnet einen Editor und läd die Datei wieder herauf,
wenn diese geändert wurde.
hat das winscp schon mal jemand ausprobiert? ich hatte am 23.03.2010
12:53
mein problem damit geschildert, ist da jemand weiter und kann mir die
entspr. tips geben, ev. einstellungen im phone oder im winscp ? mir als
"nichtlinuxer"
 würde winscp die sachen sehr erleichtern!
Ich hab es ausprobiert und ins Wiki eingetragen, woran hängt es denn?
Den dropbear hast du installiert und er läuft? (mit 'ps' mal überprüfen)
besonders viel einzustellen ist eigentlich nicht.
IP, username und nicht vergessen File-Protokoll auf SCP zu stellen.
In den einstellungen kann man außerdem noch den Pfad zu Putty angeben
und ein häkchen setzen, dass automatisch immer eine putty-session
aufgemacht wird. - sehr nützlich.
Edit:
Ich bekomme lediglich beim einloggen eine Fehlermeldungen
Command 'groups'
failed with return code 127 and error message
-sh: groups: command not found.
scheinbar unterstützt das dropbear nicht, der Rest geht aber ganz normal
Wow, ich bin begeistert!
Das wusste ich nicht.
In Punkto small HTTP Server... http://www.acme.com/software/thttpd/
Der könnte übrigens auch CGI... (sprich bash scripts, um die
configuration daten lesen und schreiben könnten zum Einrichten)
von R. H. (snapper)
dropbear läuft !und telnet (putty) geht ja auch!
"besonders viel einzustellen ist eigentlich nicht.
IP, username und nicht vergessen File-Protokoll auf SCP zu stellen."
wenn ich scp einstelle kommt nur suche nach entferntem rechner, verbinde
mit entferntem rechner......., irgendwie komme ich da nicht sorecht
weiter. liegt es vl. am falschen port ? you have skype ? i am
coffee-cup-man !
Hi!
Die die mehrere Telefone haben und noch keine tief greifendenLinuxer
sind:
Man kann das Prompt des Konsole auch ändern. Dazu in
die /.profile ändern
Habe bei mir mal PS1='Develli:`pwd`> ' eigegeben. Die anderen Telefone
haben andere Namen aber alle auch das `pwd`.
Nun weiß man auf welchen Tel man gerade bastelt und man sieht auch in
welchem Verzeichnis man gerade steckt.
Ich habe leider noch keine Info, was die integrierte busybox für Tokens
unterstützt, daher steht dem Pfad immer das root/ voran. Keine Ahnung,
ob das jetzt der User oder symbolisch das root-Verzeichnis sein soll.
Jedenfalls ist es überflüssig. Aber besser als immer suchen zu Müssen,
wo man gerade ist.
Gruß, Ulrich
von Roman (Gast)
Hallo ,
so jetzt ist es passiert. Was ich gemacht habe weiss ich nicht aber das
Resultat ist das ich in der Sicherung des Filesystems ein
Geisterverzeichnis habe. Es heisst "er_data" und ist im Telefon nicht
darstellbar. Die Auswirkung ist das das Telefon beim bootet ca. 2
Minuten mit einem blauen Schirm verharrt um dann mit der Eieruhr zu
booten. Hat einer eine Idee was ich da angestellt haben kann und wo
diese Verzeichnis liegen könnte?
Gruss
Roman
von oobi (Gast)
Hi
habe die telefone auch endeckt :)
habe mich hier auch mal durch gelesen und die telefone wurden
mitlerweile zum laufen gebracht???
steht das irgent wo noch mal zusammen gefasst? wie man es anstellt?
gruß
oobi
Andreas Ziemer schrieb:
>> Mit
Hallo Andreas,
ich hab ein bisschen mit einer neuen busybox gespielt, die enthält auch
einen kleinen ftpd (und einen ordentlichen inetd). Der micro_inetd geht
inzwischen übrigens auch mit IPv4, aber der in busyox ist viel besser.
Der httpd in einer neueren busybox-version ist wohl auch ganz tauglich.
Mein Vorschlag wäre, entweder die ziemlich abgespeckte integrierte
busybox V0.6 mit einer aktuelleren version zu erweitern, diese ganz
durch eine aktuelle zu ersetzen oder auch eine erweiterte V0.6 zu
compilieren (mir fehlen besonders inetd, crond, httpd und nc).
Haserl würde sic als "bash-PHP-Ersatz" für CGIs anbieten.
/G
SD reicht dicke - und ine microSD passt sicher auch noch gut ins
Gehäuse. Wahrscheinlich sind nicht mal solche Verrenkungen nötig wie bei
OpenWRT.
Hi!
Habe hier drei VP6500 an einer FB7170. Irgendwie melden die sich dann
irgendwann einfach ab. Habe jetzt mal im SIP-Setup unter Server das Keep
Alive auf 600 gesetzt, ich rate einfach mal dass das Sekunden sein
sollen. Alle 10min sollte doch ausreichen.
Ist das richtig, dass die FB nur mit TCP arbeitet? Das erhöht nämlich
den Traffic, da ja jedes TCP Paket ein ACK erwartet, dazu noch die
CRC...
Weiter oben wurde ja beschrieben, wie man die ganzen Kartenreiter für
die Registrierung freischaltet. Ich kann mich nicht erinnern, dass es
folgende Hinweise bereits gab:
In den Server-Einstellungen gibt es zudem eine Option Auto SW Update,
wenn man alle Reiter freigeschaltet hat. Diesen kann man doch am besten
ausschalten, da sich das Tel ja keine Updates mehr holen soll, oder man
biegt die Adresse um, auf einen eigenen Server und kann dann per Force
SW Update das Update erzwingen.
Gruß, Ulrich
Kannst Du eine neue Busybox mit dem 3.3.2er gcc compilieren oder spielst
Du auf einer anderen Plattform damit? Wäre schick, wenn Du mal ein paar
Infos mehr dazu geben könntest.
Vor allem wüsste ich gerne, ob man die neue Version neben eine alte
installieren kann und diese dann per kernel-parameter auswählen kann.
Dann käme man auch wieder zurück, falls es schief geht.
Ich weiß, man kann auch ein Backup des Image per X-Modem
zurückspielen... Aber will man das wirklich :)
Gruß, Ulrich
von Richard (Gast)
Kann irgendwer bestätigen oder widerlegen (und begründen=, das man bei
Interngesprächen zwischen zwei VPs, die an einer Fritzbox angemeldet
sind, Videotelefonate führen kann?
Mit welcher Konstellation kann ich denn überhaupt Videotelefonate
führen? Ich wollte dem Opa zu Ostern so ein Teil schenken, damit er mit
seiner 50km entfernt wohnenden Enkelin Videotelefonate führen kann...
Wie gehe ich das denn am sinnvollsten an?
Danke, Richard
Hat hier jemand das Teil am Laufen und kann rein- und raustelefonieren
und macht das NICHT über ne Fritzbox? Also alle rel. SIP-Einstellungen
direkt im Telefon und der Router reicht das nur durch? Falls ja, hätte
ich bitte eine Kopie der hpr0userparam.cfg Datei (entspr.Stellen
natürlich ge-xxx-t).
Bei mir geht nur rausrufen, rein geht nüscht :-(
Danke,
Marcus
von karl (Gast)
fritz und sip extern gibt gerne mal probleme .....
anbei die kompletten Datenblätter zum FS455LF TV Encoder Chip. Es sind
zwei Datenblätter, einmal der Chip an sich, und einmal die
Programmierung des Chips (Register, etc.)
Grüße,
Chris
von R. H. (snapper)
hi chris
cam schon zerlegt ?
von HoppIT (Gast)
::HARDWARE/BATTERY::
> 5.05mm 1150 1200mah
> 5.50mm 1280 1350mah
> 6.40mm 1500 1560mah
ich glaube, man muss da nicht wirklich an der Ladeelektronik
'hard'werkeln, wenn ich den Inhalt aus "../battery" richtig deute.
user_data/data/battery/battery_current.cfg:
<--- snip --->
# Max Counter Value 1EE63C4
MAX_CNT_VAL=17100171
 # Charge min compteur Threshold
CHARGE_MIN_TH=13680137
# Capacity in mAh
CAPACITY=950
# Nominal Charge Current in mA
MAX_CURRENT=650
# Charge Factor (k1)
CHARGE_FACTOR_K1=120
# Charge Factor (k2)
CHARGE_FACTOR_K2=730
<--- snap --->
::COMMUNITY::
Ich verstehe absolut, dass so ein "unsortierter" [nicht böse gemeint:-)]
Tread auf jeden Fall geniales Brainstorming ist, aber ich habe mich
schon gefragt, wie man hier ein wenig Übersicht hineinbekommen kann, um
fortlaufend ein Thema beoachten oder durachstudieren zu können...
Evtl könnte man sich ja auf ein System für ::BEZEICHNER:: (englisch ?)
einigen, die man den Beiträgen voranstellt. So kann man zielsicher per
Suchfunktion die Posts durchklickern.
Beispiele:
::COMMUNITY:: -> Allgemeines, die Nutzer betreffend
::HARDWARE/SD:: -> Hardware / Baugruppe
::SOFTWARE/HACK:: -> Softhack
Grüße
HoppIT
von Detlef _. (detlef_a)
hm, ich kriege meine VP5500 ebenfalls nicht auf.
Ich trage sprites' (188.40.123.50) oder boozas' (84.38.68.30) Server als
DNS ein. In meiner Fritzbox 7170 exportiere ich dazu die Einstellungen,
ändere overwrite.dns1 und overwrite.dns2 entsprechend und schreibe die
Einstellungen zurück. Wenn ich dann 'vpcm-001.cust.kpn.net' eingebe,
sehe ich die hacks.
Ich boote die VP5500, verbinde sie mit der Fritzbox, die kriegen ne IP
und springen dann auf 1:59, diese Uhr läuft weiter aber es passiert
nichts mehr.
Bilde mir ein, im langen thread nichts übersehen zu haben, was mir
helfen könnte. Muß man Ports aufmachen? DHCP ist bei meiner Fritzbox an,
tauchte bei dieser Art Problemen im thread mal auf, was hat das damit zu
tun.
Bitte um sachdienliche Hinweise!
Cheers
Detlef
PS: hartelijk bedankt aan Sprite, uitsteekend werk, mitschien zallen wij
noch veel plezier met deze telefoon hebben.!
Die FritzBox unterstützt das Video-Profil nicht. Ich habe mich gerade
mal durch die COnfig der FB7170 gehangelt, sehe da aber auf Anhieb keine
der sip-Optionen, die zuvor schon in diesem Thread angesprochen wurden.
Es ist also auch nicht über einen Config-Hack zu machen.
Auch das steht weiter oben schon. Wenn Opa auch Internet hat, dann beide
bei SipGate anmelden und darüber geht dann auch Video.
Gruß, Ulrich
von R. H. (snapper)
Chip an sich hatte ich am 23.03. auf deine anfrage hin schon geposted
was nützt es wenn die lipos selbst vom jahrelangen lagern def.  sind ?
bei atlbattery.com gibt es nur die "nackte" zelle, die an die lipos
angelötete
ladeelectronic müsste man schon vom def. ablöten und an die neue zelle
anlöten!
von Sebastian R. (sebr)
Sehr interessant wäre auch ein MP3 Player für die Konsole zum hören von
Webradio Streams (z.B. mpg123 bzw. mpg321). Headset is ja auch dabei .
Müsste doch technisch möglich sein, oder?
Also bei mir klappt der Softhack immer noch nicht. Ich habe mitlerweile
zwei Telefone am WLAN dran. Den DNS habe ich umgebogen, dass es
funktioniert sehe ich daran, dass sich die Uhrzeit wie gedacht
einstellt. Aber das Update erfolgt nie!
Ich habe nun auch mal die Lösung mit dem eigenen Webserver durchgeführt.
Ich kann in den Server-Logs sehen, dass die Dateien von den Telefonen
auch direkt heruntergeladen werden. Aber installieren wollen die
Telefone sie nicht. Ich habe die Telefone nun schon zwei Tage und Nächte
in der Ladestation gelasse, aber nichts, kein Update.
Was stimmt da nicht?
von berny (Gast)
ich habe mit meinem VP6500 folgendes Problem:
ich nutze den Softhack von spritesmod, das Telefon bootet auch brav,
verbindet sich zum Netzwerk, holt sich die Zeit vom ntp-Server.
Mein http-Server sagt allerdings, dass das Telefon folgende Dateien
haben möchte:
192.168.250.200 - - [26/Mar/2010:06:48:37 +0100] "GET
/philips/VP6500/swinfo HTTP/1.0" 200 264 "-" "Wget/1.10.2"
192.168.250.200 - - [26/Mar/2010:06:48:43 +0100] "GET
/philips/VP6500/package1_V3.22 HTTP/1.0" 404 351 "-" "Wget/1.10.2"
Die swinfo bekommt es, nur wo bekomm ich die Datei package1_V3.22 her?
Vielleicht kann einer von Euch da Licht ins Dunkel bringen ...
Servus,
Berny
von G. S. (varda)
@starkeeper
Hatte selbes Problem wie Du !
1. Welchen Router benutzt du ?
2. Welcher DNS wird umgebogen? der im Router? der im VP5500?
von blooza (Gast)
Ich weiss nicht warum sich sprite nicht mehr meldet ich kann euch nur
sagen, dass es offensichtlich immer noch Probleme mit seiner swinfo
Datei gibt. Schaut doch einfach mal auf meinem DNS nach und ladet euch
die Dateien entweder dort herunter (wichtig: BEIDE Dateien), denn es
gibt immer eine passende swinfo zu einer hack Datei.
Die IP-Adresse meines DNS-Servers könnt ihr weiter oben lesen.
Ich hab damit beide VP-Modelle freigeschaltet.
Das Update von meinem DNS beinhaltet aber nur die hack.tgz um dann per
Telnet auf das Telefon zu kommen, die Hack2.tgz könnt ihr dann auf der
Konsole auf das Telefon laden. Ich hoffe dass es nun auch bei euch
funktioniert...
Gruß blooza
von R. H. (snapper)
The VP6x00 is based on a Freescale Dragon Ball i.MX21 processor
(MC9328MX21VK). The processor integrates an ARM9 core, clocked between
266 and 400 MHz.
kann man die tatsächliche taktfrequenz mit der das phone arbeitet
irgendwie abfragen ?
Philips's FCC registration materials for the Visiophone VP6x00 include
test results suggesting that the device will support 802.11b/g WiFi and
Bluetooth.
hat das vp6500er schon mal jemand auf bluetooth untersucht ?
was auch verwunderlich ist, das die geräte bei
https://fjallfoss.fcc.gov/oetcf/eas/reports/GenericSearch.cfm nicht mehr
auftauchen und auch keine FCC registrierung haben obwohl man tlw. lesen
kann, das die FCC prüfung abgeschlossen ist. das die so überhaupt auf
den markt gekommen sind, denn normalerweise hat alles, was auch nur
einen "furz" HF abstrahlt eine FCC zulassung !
@  Andreas Ziemer
"wenn ich in das VP6500 zwei NiMH Mignon Akkus mit 3500mAh lege"
jaja, 3500mah aus n´er mignonzelle, und webcams bei ebay aus fernost mit
20megapixel für 9,99€ und mp3 player aus ditto mit 32GB auch für´n
zehner und ne sterero anlage mit 300 watt  musikleistung und
telefonklingeldraht als zuleitung für die boxen usw.usw.
die zellen die das wirklich leisten möchte ich mal sehen, das ist erst
ab der grösse babyzelle machbar. ich habe zellen mit so astronomischen
angaben schon mal mit meinem "ladecomputer" untersucht, 2500mah waren da
schon eher die ausnahme !
von slime (Gast)
# cat /proc/systclk
System clocks state:
   Ref clock :      32768Hz  (int, premult by 512)
   MPLL clock:  263999905Hz  (computed: 264000000Hz)
   SPLL clock:  163840000Hz  (computed: 163840000Hz)
   CPU clock :  263999905Hz  (PERSC   = 0)
   Bus clock :  132000000Hz  (BCLKDIV = 1, computed: 131999952Hz)
   CSI clock :  unknown      (cannot read register CSICR1)
   USB clock :   20480000Hz  (USB_DIV = 7)
   Wait State:  CS0U[WSC] = 10, CS0U[WSC] = 48
   loops_per_jiffy = 665058
;-) mit 3500 mA glaub ich auch nicht. Die gute Grenze liegt derzeit bei
2500 mA bei NiMH AA Akkus. Übrigens haben die 3500 mA Akkus meistens
weniger als 1000 mA (!!) (weiss ich aus eigener Erfahrung). Gibt auch
einen schönen Artikel zu Fakes hier:
Beitrag "Gefälschte (gefälschte) Kondensatoren?"
Hello,
i'm writing this in english, so that Joost can easily read that as well.
I think i give up on Qtopia 2.1.0. Things is that it has many bugs in
the code, and that the configuration is pretty awkward. While i got the
"bugs" fixed, so that it compiles cleanly, it only works "somewhat". I
can start some of the compiled applications, but the output to the LCD
is not correct. It seems that it uses some window management, which
makes it pretty much impossible to correctly use the applications.
The problem is that each little change requires me to rebuild the whole
tree again. Otherwise the results are unpredictable. In short: it is
borked up beyond belief.
For that reason i will for now focus on reverse engineering the
existing, phone-specific code using IDA-Pro. That means, accessing the
camera, sound-system, TV output, etc. There are binaries under
/user_data/prod/bin that i will take apart and try to re-implement, so
that we can get some usable source code that demonstrates how to use
these functions.
Once thta is sorted out, that code can be integrated into a new version
of QtExtended or something, to finally replace the old stuff completely.
Extracting the strings from the installed libqtopiaphone shows that this
is the place where pretty much everything of the device specific
functionality is located. Attached is an archive that contains the
string-dump of that lib, so anyone interrested can take a peek there.
Btw, the 6500 has twice as much flash storage than the 5500. The 5500
has only 32 MBytes, while the 6500 has 64 MBytes.
Greetings,
Chris
blooza schrieb:
>>Ich hoffe dass es nun auch bei euch funktioniert...
Leider nicht, zumindest nicht bei mir, ich hatte letzte Nacht auch
Deinen server ausprobiert (siehe meinen post von heute 1:27). ich
scheine ja auch nicht der Einzige mit dem Problem zu sein.
hm
Cheers
Detlef
> funktioniert...
> Gruß blooza
Also ich habe es mit dem DNS von Sprite versucht, dass klappte nicht.
Dann habe ich es mit einem eigenen DNS probiert, der sich im gliechen
Netz befindet wie das Telefon, auch das klappte nicht. Aber ich konnte
so sehen, dass das Telefon die Dateien von meinem Webserver geladen hat.
Bei Meinem zweiten Versuch befanden sich DHCP, DNS und HTTP im gleichen
Netz, also kein Router dazwischen.
Ich glaube also eher, dass es an den Dateien liegt. Mein Telefon hat die
Software-Version 4.20. In der SWInfo-Datei steht an den meisten Stellen
die Version 3.55 oder so.. vllt. macht er kein Update, weil die Version
auf dem Telefon neuer ist als die in der Datei?!
von G. S. (varda)
@Detlef _a
Was für einen Router hast DU ?
Wie biegst du den DNS um, auf dem Router, im DHCP ? ...
Hatte auch Probleme damit:
swinfo wird geholt, hack.tgz wird geholt und dann passiert nix mehr
von karl (Gast)
jungs wenn das update nicht geht muss das bei euch am setup liegen...
wers nicht selbst hinbekommt und in aachen oder umgebung wohnt kann
gerne bei mir vorbei kommen ... auch per post wäre möglich nur dann
hätte ich gerne die Portokosten ;)
Ich hab heute morgen von Pollin leider ein ganzes und ein defektes
VP6500 erhalten .... das eine macht keinerlei Regung egal mit welchem
Akku satz ... hab denen nun mal ne mail geschrieben mal schauen was
passiert...
Hab nun schon zwei vp5500 und ein vp6500 erfolgreich unlocked!
Was mir noch aufgefallen ist:
Dem VP5500 liegt ein kopfhörer mit einem ohrhörer bei und micro 2,5mm!
Dem VP6500 liegt ein Stereo Kopfhörer bei allerdings ohne micro 3,5mm!
von Rainer (Gast)
Und welche Möglichkeit hat man, wenn Sipgage im eigenen Vorwahlbereich
keine Rufnummern anbietet? Ausser warten?
Jau, PMPO machts möglich ;-)
Laß mich raten, Du hast ein VP5500 und bist neidisch ;-)
Nein, Spaß beseite, hast schon recht, daß 3500mAh auf dem Akku meist nur
ein Werbeargument sind, und in der Praxis (z.Z.) wohl nie erreicht
werden - allerdings schwanken auch die Angaben bei den LiPo Zellen um
teilweise einige 10%... Also, dann nehmen wir eben 2000mAh, die sind
realistisch, macht 2,4V x 2000mAh = 4,8 Wh, immer noch etwas drüber ;-)
OK, gebe mich geschlagen, LiPo Akkus haben halt 'ne höhere Energiedichte
- wahrscheinlich bin ICH ja bloß neidisch ;-)
Andreas
von karl (Gast)
sonst mach doch mal einer von den leuten mit update problemen sein phone
auf mach die serielle dran und mach nen dump von hand ... vielleicht
bringt das ja alle weiter ?!
Günter S. schrieb:
> @Detlef _a
FB7170, DNS im Router umgebogen, siehe
Beitrag "Re: PHILIPS VP5500 VoIP Telefon bei Pollin"
>>Mein Telefon hat die Software-Version 4.20.
Ich habs nicht hier, aber ich glaube mein nichtfunzendes auch.
Karl, stimmt, aber genau das ist die Frage.
Cheers
Detlef
von Sprite_tm (Gast)
I hear there are problems with people not being able to unlock their
phones with my server. If you have these problems, could you please
state the phone you have (5500 or 6500) and what firmware version the
menu indicates? If you want, you can also state your IP so I can see in
my webservers logs what happened.
Hi sprite_tm, nice to hear from you again!
Wollen wir nicht mal eine kleine Umfrage starten, wer welche SW- Version
hat und mit welcher Version es bei wem (sprite/ Blooza) geklappt hat?
Ich fange einfach mal an: Bei mir hat es mit 2 VP5500 mit der Blooza-
DNS funktioniert.
Daten der Telefone:
SW- Version 4.20
Config Code NL
Hw: ind5 Date: 0649
PN: JH1106nnnnnnnn
Qtopia Version 2.1.0
An die, bei denen es (scheinbar ?) nicht geklappt hat: Habt ihr nach
einem Versuch mal ein "telnet <telefon-IP>" ausgeführt, ob der Hack
vielleicht doch schon gegriffen hat und ihr aufs Telefon kommt?
Ist mir nämlich auch so gegangen: das Ding war gepatcht und ich hatte
den Reboot nur nicht mitbekommen... Im gepatchten Zustand und
umgebogener DNS- IP im Router (oder sonstwo) läuft die Uhr nämlich immer
bei 1:58 los.
von robin26 (Gast)
Stromversorgung: Akku
hat schonmal jemand nachgemessen wieviel mm Akku wirklich in das Gehäuse
passen. Originalakkus werden wohl deutlich jehnseits des VP5500 Preises
liegen. Mamma Pollin hat da was
http://www.pollin.de/shop/dt/MjA1OTI3OTk-/Stromversorgung/Akkus/LiPo_Akkus/Lithium_Polymer_Akkupack_LIS2106.html
Passen die 62mm*35 rein. Eine hälfte des Akkupacks hätte dann 650mAh das
ganze pack wäre dann 7,8mm dick das wird wohl nicht passen. Vielleicht
findet ja sonst noch wer eine günstige Quelle.
Robin26
Die in den Telefonen verbauten Akkus sind auch von Pollin. Ich würde in
diesem Fall sicherlich keine Akkus von dort kaufen wollen.
Sowas würde ich generell dort nicht kaufen, da man davon augehen kann,
das alles was bei Pollin landet, woanders schon eine ganze Weile
rumgelegen hat.
von Christoph H. (wtzm)
> these functions.
/user_data/prod/bin/APPTvlink.exe ist ja interessant für alle die mal
den TV-Ausgang testen wollen. Programm starten, Menüpunkt 5, dann PAL
auswählen und schon sollte ein Bild am Fernseher erscheinen. Danach
/dev/fb2 zur Bildausgabe (640x480) verwenden.
Habe jetzt auch endlich mein VP6500 bekommen. Jedoch bekomme ich das
Gehäusenicht auf. Die beiden Schrauben unter dem Batteriefachdeckel habe
ich entfernt und auch die Rastnasen im unteren bereich entriegelt. aber
weiter oben (um das display rum) bekomme ich es einfachnicht
auseinander. Sind da noch irgendwo Schrauben oder gibts nen Trick?
von Star K. (starkeeper)
> Daten der Telefone:
> SW- Version 4.20
> Config Code NL
> Hw: ind5 Date: 0649
> PN: JH1106nnnnnnnn
Mein Telefon (VP5500) sieht genauso aus:
SW-Version: 4.20
Config code: NL
HW: ind 5 Date: 0648
PN: JH11064801...
Qtopia: 2.1.0
Es klappt mit sprite's dns nicht. Mit dem anderen werde ich es heute
abend testen.
von ED (Gast)
2x VP550
Sprite ging nicht..
Blooza ging ohne probleme
SW-Version: 4.20
Config code: NL
PN: JH11064801....
Qtopia: 2.1.0
von G. S. (varda)
@Detlef _a
@starkeeper
Ich habe gestern 10 VP5500 mit der Softwareversion 4.20 "gehackt"
aber erst auch nach langen Versuchen incl. log des Webservers und
Wireshark
1. Versuch
Immer schon brav den DNS im Router ( fli4l ) auf 84.38.68.30 (Blooza,
nochmals vielen Dank!) gestellt und immer wieder selbes Verhalten:
Uhr wird auf 1:58 gestellt
swinfo wird geholt
und dann passiert nix mehr.
2. Versuch
swinfo und hack.tgz auf eigenen Webserver im lokalen Netz und DNS im
Router auf Webserver umgeleitet.
selbes Verhalten -> swinfo wird geholt und hack.tgz wird geholt danach
passiert nix mehr; kannste ewig warten.
Danach war ich mit meinem Latein am Ende.
Das hat mir keine Ruhe gelassen. Gibt es nicht, habe seit 20 Jahren
Erfahrung mit TCP/IP Netzen; dass kann nicht sein.
Jetzt aber zur Lösung !!!
1. (momentan) nur die Dateien von Blooza 84.38.68.30 verwenden
2. DNS umbiegen !! JA, aber im DHCP des Routers !! damit die Clients bei
der DHCP-Vergabe auch den DNS (84.38.68.30) mitbekommen. Manche Router
(meist die billigen - machen dies automatisch; prof. Router NICHT!,
dürfen dies auch nicht!)
Was noch wichtig ist: Ein Update (vom) im lokalen Netz geht nicht;
warum, keine Ahnung.
Nur wenn der Client (VP5500) den DNS-Eintrag 84.38.68.30 hat geht das
Update, ansonsten nicht; holt zwar die Dateien und dann ist Sendepause.
Anscheinend gibt es eine Plauschiprüfung innerhalb der Update-Routine,
die ein Update nur von einem ausserhalb des eigenen - privaten -
TCP/Netzes akzeptiert.
Nochwas !!!
Eine Anmeldung an einen Asterisk Server im eigenen privaten Netz geht
zwar, allerdings gibt es meist nach ca. 31 sekunden wenn der
entsprechende Teilnehmer ANGERUFEN wird einen Verbindungsabbruch. Wird
bei der Anmeldung des VP5500 die öffentliche Addresse des
Asterisk-Servers benutzt, so laufen die Gespräche normal durch.
Verhalten wie bei UPDATE ???
Also - Zusammenfassung
Ganz einfach - DNS-Eintrag im DHCP - Server ändern; dies ist alles
von Franz B. (byte)
Weil du die Uhr auch noch entsprechend manipulieren must, da er nur
einmal am Tag Updatet. Entsprechend brauchst einen gefakten Zeitserver.
von G. S. (varda)
@Franz B.
hat damit nix zu tun.
Zeitserver war weiterhin umgeleitet auf  84.38.68.30; oder auch auf
meinen privaten mit der entsprechenden Zeit
von Christian K. (Firma: Atelier Klippel) (mamalala)
Das stimmt so nicht. Ich habe alle meine Telefone im lokalen Netz
aufgemacht, swinfo's und .tgz's auf meinem lokalen Server. Das
funktioniert Einwandfrei. Alle Geräte, Rechner, Server, etc. haben eine
Nummer in einem 192.168.1.0/24. Den Timeserver fake ich mit:
echo -ne '\xCF\x21\xC9\x7F' | nc -q 1 -l -p 37
auf dem lokalen Rechner. Es werden die Servernamen
"vpcm-001.cust.kpn.net" und "ntp.xs4all.nl" in der DNS Abfrage im Router
auf den lokalen Rechner umgeleitet.
Das einzigste was ich mir vorstellen kann ist das der MD5 Hash zur .tgz
in der swinfo nicht stimmt. Das Telefon lädt zuerst die swinfo runter.
Dann schaut es nach ob die angegebenen Updates neuer sind als wie das,
was auf dem Telefon ist. Wenn ja, holt er die entsprechenden Archive.
Danach errechnet es die MD5 der Archive und vergleicht das mit den MD5's
die in der swinfo stehen. Wenn das nicht passt macht er auch nichts
weiter.
Grüße,
Chris
von G. S. (varda)
@Christian Klippel
bei mir ist dies nicht gegangen; Hatte mir die Dateien von Server
84.38.68.30 geholt und auf meinen privaten Server geladen
Exakt auch den Timeserver - wie du nachgebildet
Ergebnis: dateien werden geholt, dann passierte nix mehr;
event. gibt es unterschiedliche VP5500 Versionen ????
was meinst du denn mit
"DNS Abfrage im Router"
DNS für den Router oder für die Clients die vom Router bzw. DHCP Server
kommen?
> kommen?
Mein WLAN Router kann DNS Abrfragen abfangen und eine selbstgewählte IP
zurückgeben. Die DHCP Clients bekommen von ihm seine IP als DNS, er
arebitet also als DNS Proxy.
Grüße,
Chris
von G. S. (varda)
@Christian Klippel
Normal sollte der Router keine DNS Anfragen "abfangen" er darf sie nur
maskieren wenn diese direkt an einen DNS gehen.
Dies mit dem DHCP und DNS steht auch auf
http://spritesmods.com/?art=vpx500&page=3 .... man muss es nur oft lesen
um den Sinn zu verstehen.
... Change the DHCP server to force it to use 188.40.123.50 as a DNS
server
Also bei mir hat es nun teilweise geklappt. Mit dem Server 84.38.68.30
hat er nun innerhalb weniger Minuten ein Update durchgeführt. Als
Version zeigt das Telefon (VP5500) noch immer 4.2 an. Aber ich kann nun
per Telnet drauf.
von bitmac (Gast)
Hi, hab mir auch das VP6500 geholt. Gestern dann mal den Softhack
ausprobieren wollen, aber leider feststellen müssen, daß keiner meiner
Router sich in der DNS umbiegen läßt :(
Habe dann von Marcus S. den Tip mit dem Soft-DHCP-Server anwenden
wollen. Nur leider habe ich sehr wenig Ahnung von DNS und manch anderen
Netztwerkgeschichten, daß ich damit leider auch nicht weiterkam.
Verstehe in untenstehender ini schon mal nicht, wieso DNS nicht enabled
wird und auch das Forward der DNS fehlt. Denn diese Teile der ini sind
für die Nutzung des DNS-Servers so auf der verlinkten Seite des
DHCP-Servers dokumentiert.
Deshalb meine Fragen:
1) Fehlt da noch was an der ini oder sollte es mit dieser bei Anpassung
der Routeradresse und der MAC-Adresse funktionieren?
2) Wie ist der Rechner, auf dem der Soft-DHCP-Server läuft in das WLAN
einzubinden? Habe ihn statisch angebunden (der DHCP im Router muß ja für
diese Lösung abgeschaltet werden), aber was trägt man dann als DNS in
den TCP/IP-Einstellungen des Rechners mit dem Soft-DHCP-Server ein? Bzw.
sind die Einstellungen dann überhaupt noch für die Funktion des
Soft-DHCP-Servers relevant?
Vielleicht könnten wir ja ne kleine Anleitung hinbekommen, wie man einen
solchen DHCP-Server softwareseitig aufsetzt, da es ja viele Leute gibt,
deren Router die DNS nicht verbiegen kann. Wäre aber für jeden Tip
dankbar!
Marcus S. schrieb:
> 1) DHCP-Server hier runterladen und entpacken:
> http://ruttkamp.gmxhome.de/dhcpsrv/dhcpsrv.htm
> 2) Die dhcpsrv.ini so modifizieren, daß Sprites DNS Server
> als DNS Server eingetragen wird, etc. Sieht dann z.B. so aus:
> [General]
> SUBNETMASK=255.255.255.0
> ROUTER_1=192.168.220.1  ;IP des Routers/AccessPoints
> DNS_1=188.40.123.50  ;Sprites DNS-IP
> NODETYPE=8  ; Hybrid
> LEASETIME=3600   ; lease time of 1 hour
> [Settings]
> Trace=1
> [00-16-41-72-72-D2]  ;MAC-Adresse des VP5500
> IPADDR=192.168.220.109  ;Adresse im Netz die noch NICHT vergeben ist
> ; New in version 1.4
> ; IPBIND_0 ... IPBIND_9
> ;IPBIND_1=194.168.123.132
> ; 1 = just keep quiet on unknown clients
> ; 0 = decline requests from unknown clients
> IgnoreUnknownClients=1
> 3) dhcpsrv.exe jetzt starten (ggfalls als Admin)
> 4) Tel. einschalten, mit dem AccessPoint verbinden lassen. Die
> IP-Adresse, etc. bekommt es jetzt von unsrem eigenen DHCP-Server
> 5) Jetzt wie von Sprite beschrieben vorgehen
> 6) Danach eigenen DHCP wieder beenden und den im Router wieder
> einschalten.
von robin26 (Gast)
Akku Füllstand
Hallo zusammen. Wenn ich das Telefon per reboot Kommando neu starte ist
darauf die Akkuanzeige flöten gegangen ---> leer Telefon läuft natürlich
noch weiter. Wenn ich "ordentlich" per roten Knopf ausschalte und wieder
einschalte dann merkt es sich den Akkustand..
Naja nur so bemerkt scheint wohl eher ein Schätzeisen zu sein die
Akkustandsanzeige..
robin26
Welchen Teil von:
"Die DHCP Clients bekommen von ihm seine IP als DNS, er
arebitet also als DNS Proxy."
hast Du nicht verstanden? Als solcher kann er natürlich bestimmte Namen
"abfangen" und eine eingestellte IP dafür zurückliefern. Schliesslich
fungiert er gegenüber dem Client als DNS, was diesem ja per DHCP
mitgeteilt wird.
Grüße,
Chris
von s2 (Gast)
robin26 schrieb:
> Akku Füllstand
> noch weiter.
Kann ich bestätigen. Auch nach dem Softhack ist der vorher volle Akku
angeblich leer.
Folgende Fragen drängten sich mir gerade auf:
1. Kann das VP5500 nun WPA2? Oder kann dies nur das VP6500? Nach der
Anleitung aus dem wiki geht bei mir (VP5500) nur WPA.
2. Gibt es Hardware unterschiede zwischen VP6500 und VP5500? Das könnte
man eventuell schon herausfinden durch vergleich der Linux-Distri auf
Dateisystemebene. Vllt. könnte man dann per JTAG das image des VP6500
auf das VP5500 spielen.
3. Hat schon mal jemand längere Zeit  mit dem Telefon telefoniert? mein
Akku zeigt schon "leer", wenn ich nur einige Minuten im Menü rumspiele.
von G. S. (varda)
Hab gestern mal 1 Stunde incl. Bildübertragung telefoniert; danach war
Akku lt. Anzeige noch halb voll.
VP6500 oder VP5500 ?
von G. S. (varda)
VP5500
Denke wir sollten Sprite mal Rückmeldung geben, dass etwas in seiner
swinfo für die hack2.tgz nicht passt!?
Hi Sprite,
I think there are some complications with your current hosted 'swinfo'
and the hack2.tgz file, can you check this?
I've hosted your latest working files temporary on my server if you need
them they are reachable at: http://84.38.68.30/philips/
I think nobody can use your server at the moment for upgrading the
phones!?
Thanks for your great work.
blooza
PS: Übrigends hab ich mich gestern hier mal registriert ;-)
Ich denke, swinfo und hack.tgz passen nicht zusammen?
Die hack2.tgz habe ich mir vom Phone aus mit wget geholt und lt.
Anleitung weiter oben entpackt.
Danach kam dropbear drauf und auf meiner Windows- Büchse WinSCP...
Jetzt kann man mit dem Ding arbeiten... :-)
BTW: nach hack2 und Reboot war die Akkuanzeige auch rot.
von Ulrich P. (uprinz)
@sprites_tm:
Is it possible that your hack2.tgz for the VP6500 does some more that
ought to be good?
I 'rooted' three VP6500 via serial port, enabled telnet and, on two of
them, wget your file and untared it on the phone. It includes lots of
files...
Then I configured all of them to use my FB7170 as a SIP-Server. I don't
have any sip account so the FB routes alle calls through ISDN. Works
pretty fine so far.
But two of the phones loose contact to the sip-server after minutes to
hours.
They do not fall out of the network as both can be reched via Telnet and
both show good signal rates.
The one I reconfigured manually by Telnet and vi does not show this
problems.
I reconfigured one of the problematic phones to 300s keep alive, the
other two to 600s keep alife in the menu of the sip settings. It doesn't
change the behaviour.
Any Idea? I will try to start ftp or scp and copy out everything. Then
I'll check with winmerge if there are interesting things different in
the config files.
Best regards, Ulrich
von R. H. (snapper)
an alle, besonders "neulinge"
bei kleinem fängt es an zu nerven, viele der fragen die ihr hier stellt
wurden schon beantwortet und auch dein browser hat eine suchfunktion !
(wer zahlt mir die ganzen mäuse, bei denen das scrollrad verschlissen
ist?)
@ Sebastian R. (Tino N. 19.03.2010 15:26)
Du musst das schwarze Kunststoffteil (hinten oben) noch entfernen . Das
ist geklebt , musst etwas vorsichtig anhebeln. Darunter sind noch 2
Schrauben.
betr. akkuanzeige : das ist wie bei meinen dect gigaset, wenn man die
akkus rausnimmt zeigen die danach erst einmal leer an und das gerät muss
anhand der ladung/entladung den akkuzustand wieder erlernen. wie soll es
sich das auch merken ohne strom. ich schätze mal das es bei den philips
nicht anders ist, die informationen über den ladestand stehen irgendwo
im speicher und sind nach einem reboot erstmal auf null.
betr. aukkutausch siehe 25.03.2010 10:35/47 u. 26.03.2010 01:30
keiner bock da mal anzufragen was die lipos in stückzahlen kosten ?
dann gäb´s keine probleme mit der grösse und ausserdem muss die
ladeelectronic eh umgelötet werden, da die bei ebay angebotenen lipos
nur 2 anschlüsse haben und auch meistens von den abmessungen nicht
passen.
modell 623759 mit 1500/1560mah von http://www.atlbattery.com passen ohne
prob.!das akkufach hat 38x60mm, ich habe es mal mit 2 aufgelegten euro
stücken (+2mm) zugemacht, das geht (weichschaum klebepad vorher
entfernt) also dürften 7mm dicke akkus da noch reinpassen ! könnte auch
gehen:
http://cgi.ebay.de/3-7v-1200MAH-18C-Lipo-battery-RC-Plane_W0QQitemZ320495085068
http://cgi.ebay.de/AKKU-SIEMENS-GIGASET-4000-4000s-4010-s-4015-MICRO-Q059_W0QQitemZ120545289494
leider findet man bei ebay zig lipos, die von den el. werten passen
würden
auch mit höheren kapazitäten und günstig für handy, pda foto usw. wo
aber leider keine abmessungen angegeben sind, da steht dann immer nur
passt für xyz...., wer lust hat kann sich da mal hinterklemmen und
entspr. ergebnisse hier posten !
von Vlad T. (vlad_tepesch)
> Schrauben.
Ich hab grad jede Menge Fotos beim Zerlegen gemacht, ich werde die erst
mal ohne viele Kommentare ins Wiki stellen.
Wenn ich Zeit habe werde was dazu schreiben.
von R. H. (snapper)
@ vlad , kanst du heute skypen ?
So, bin jetzt dazu gekommen das mal zu machen. Hatte aber auch schon
feste Namen in der FB vergeben, das scheint Vorrang zu haben.
Aber was mir auffiel:
Ich habe VP6500er und darin ist der Pfad:
/usr/local/startup_V3.22
Anscheinend gabe es für das VP6500 eine Neue Auflage der Firmware, bzw.
einiger Teile davon. Die meisten Dateien sind aus Jan/Feb 2007, wie ist
das beim VP5500?
Gruß, Ulrich
von R. H. (snapper)
info anbei !
Hi!
Auch die VP6500 Besitzer sollten auf ihre Akkus aufpassen. Während bei
zwei Telefonen die mitgelieferten Dinger noch gut zu halten scheinen,
bei einem werden sie sehr heiß beim Laden. Die sind ein Fall für die
Entsorgungsstelle.
Sollten zwar nicht explodieren, wie LiPos aber wer weiß...
Gruß, Ulrich
Bei mir sind die Daten ähnlich wie bei Dir R.H.
Develli//root> ll /usr/local/startup_V3.22/
drwxr-xr-x    2 301      504             0 Mar 26 22:29 .
drwxr-xr-x   18 301      504             0 Jan  1  2007 ..
-r-xr-x---    1 301      504          4437 Mar 26 23:21 daemon.sh
-r-xr-xr-x    1 301      504         23012 Feb 28  2007 netsyncd
-r--r-----    1 301      504        105600 Feb 28  2007 update.bin
lrwxrwxrwx    1 root     root           21 Jan  1  2007 upgrade.cfg -> ./upgrade_ref_KPN.cfg
-rw-r-----    1 301      504           986 Feb 28  2007 upgrade_ref.cfg
-rw-r-----    1 301      504           990 Feb 28  2007 upgrade_ref_EFT.cfg
-rw-r-----    1 301      504           985 Feb 28  2007 upgrade_ref_FT.cfg
-rw-r-----    1 301      504           975 Mar 26 22:29 upgrade_ref_KPN.cfg
-r-xr-xr-x    1 301      504         32920 Feb 28  2007 upgraded
von R. H. (snapper)
die scripts sehen bei mir so aus, sind nur 6 tage älter !
Bei alle vom 28.Feb.2007, wie die anderen auch. Anscheinend gab es bei
Philips damals einen Backport der Verbesserungen. Das VP6500 ist später
gestartet, die gefundenen Fehler wurden dann auch im VP5500 korrigiert,
aber das war vermutlich schon bei einer höheren Version angekommen.
Hat also wohl kaum was zu sagen.
ist jetzt doch ein bisschen mehr text geworden ;)
Hi all,
my phone settings are as follows:
SW-Version: 4.20
Config code: NL
PN: JH11064801....
Qtopia: 2.1.0
When I tried boozas' and sprites' server yesterday night I used IP
84.191.76.6
The thing is still not unlocked, but thanks to this afternoons' posts
the reason for that might be clear. I have no clue how to configure
FritzBox' DHCP server to deliver correct DNS addresses but I will find
out, probably.
Good night
Detlef
von R. H. (snapper)
thema neuer Akku:
was mich noch interessieren würde, ließe sich das kunststoff gehäuse an
der stelle "ausfräsen" wo der lipo sitzt ? dann könnte man dort einen
dickeren als 7mm einsetzen, ich denke mal philips hat da viel platz
verschenkt, die bauteile auf der platine tragen an der stelle nicht "so
dick auf".
Vlad Tepesch vote:
ich denke 8mm kriegt man ohne größere schwierigkeiten rein, wenn man die
Zwischenwand ganz raus macht wahrscheinlich nochmal +2-4mm
von R. H. (snapper)
@ detlef_a
This once in a nutshell:
In the web interface of Fritzbox Settings> System> Save Settings,
download an export file. In this file search using the search function
of the editor and after overwrite_dns1 overwrite_dns2 and among the
first entries to replace 0.0.0.0 with the required DNS entries. Further
back i.d. File is still a overwrite_dns that I had to change it.
(Search other possibility: FbFEditor / Telnet fritz.box [nvi /
var/flash/ar7.cfg] around line 300 or send: / overwrite_dns1)
The upload of the file is more difficult because the file has a
checksum. The review can be avoided with the additional entry of NoCheck
= yes,
(in pre **** CFGFILE: ar7.cfg.)
Then you have on the home page of the web interface not the ugly
reference to manufacturer-supported changes. At least not make you
forget that the DNS is changed.
it work´s on my FB7050 easily !!!
http://knevels.org/dns-eintraege-der-fritzbox-aendern/
kind regards
von Onno (Gast)
ich würde hier gerne noch anmerken, daß es nicht immer nötig ist, an
seinem Haupt-DHCPServer herumzufummeln, um die Dinger gehackt zu
kriegen.
Ich habe hier auf meinem Laptop einfach parallel einen "udhcpd"
gestartet, denn ich neben der übliche Adresswahl für das lokale Netz mit
folgenden Daten ausgestattet habe:
opt     dns     84.38.68.30
Da die Fritzboxen und andere Geräte meist langsamer im Beantworten von
DHCP-Anfragen sind als die heutigen Laptops/Desktops, kriegt man es
trotz der offensichtlichen Race-Condition hin, den Telefonen einen
anderen DNS unterzujubeln.
Ich würde es einfach ausprobieren und den UDHCPD dann noch zusätzlich so
konfigurieren, daß der auch nur eine ganz spezielle IP vergibt, die
außerhalb des per DHCP-Vergabe vergebenen IP-Bereiches der Routerbox
(Fritzbox o.ä.) liegt, aber natürlich immer noch im richtigen Subnet.
Ob dieses Unterjubeln dann geklappt hat, kann man dann einfach mit einem
parallel laufenden Ping testen.
Ich habe hier schon so ohne Probleme parallel zu einer Fritzbox WLAN7050
vier Telefone umgebogen, 1x 6500 und 3x 5500.
Auch kann ich den Leuten, die Probleme beim Umbiegen haben, noch zwei
Dinge auf den Weg geben:
1. Geduld, geduld, geduld
2. Wenn man einmal angemeldet war, wird die Firmware meistens erst beim
nächsten Neustart übertragen
HTH und viel Spaß noch Leute..
von Stefan N. (apophis81)
ich kam bis jetzt leider noch nicht dazu mein VP5500 per Software Hack
zum Leben zu erwecken. Das VP6500 ist gestern gekommen und ich will
nächste Woche mal schauen ob es geht.
Was ist jetzt genau der Unterschied zwischen Bloozer und Sprites Hack?
Irgendwie bin ich jetzt verwirrt.
Schaltet BroozHack auch schon alles direkt frei oder muss ich mich dann
per Telenet einloggen und das update von Hand installieren um die SIP
Einstellungen frei zu schalten?
Apo
@all echt klasse Arbeit :)
von Robert (Gast)
Hi!
Ich konnte mit Bloozas als auch Sprites DNS kein Telefone updaten. Ein
User auf Sprites Seite hat dann auch 85.214.148.94 verwiesen - damit
konnte ich dann je zwei VP5500 und VP6500 updaten. Allerdings klappt es
nicht immer - von daher lieber noch mal neustarten als alles
umzukonfigurieren. Was auf jeden Fall ein Indiz ist ist die Uhrzeit auch
01:58.
Meine zwei VP5500 können sich an meiner FB7570 anmelden - bei den zwei
VP6500 funktionieren die identischen Einstellungen nicht.
Was mich sehr freut ist die Displayqualität - da kann man wirklich was
drauf erkennen - trotz der vergleichweise geringen Auflösung. Was mich
betrübt ist die Verarbeitung insbesondere bei den VP5500 - das knarzt
und knackt es bei jedem Tastendruck - bei einem bleibt das Steuerkreuz
sogar nach einem "nach oben" im Gehäuse hängen... Nicht Philips-like und
für einen möglichen Preis von ca. 80 Euro (Fritzbox MT-F) eigentlich
nicht akzeptabel.
Apropo Fritz MT-F - wäre das nicht eine mögliche Software? Ist doch
sicher auch Linux - da müssten dann natürlich einige Anpassungen gemacht
werden. So oder so wäre ich beim Programmieren dabei - allerdings wäre
es wirklich schön wenn es eine VM oder ein CD-Image geben würde damit
nmicht jeder die Toolchain neu zusammenbauen muss - das wäre im
Endeffekt auch das Beste da so alles kompatibel ist.
Grüße
Robert
von R. H. (snapper)
> nicht akzeptabel.
wie meinst du das mit dem preis 80€ ? du hast dafür ja sicherlich auch
nur 10€ bezahlt wie alle anderen hier auch und das mit der taste ist
doch reparabel ? die dinger sind m.v. in rumänien gefertigt und einen
DACIA kannste ja auch nicht mit einem DB vergl. !
@ detlef_a
fbeditor enclosed !
also, ich finde die Verarbeitung ganz gut, da knarzt nix und hängt auch
nix (ich habe zwei)
Hat schon jemand die Dateien mit den Kontakten gefunden? Ich würde die
gerne am PC eintragen, über das Telefon ist das doch eine langwierige
Angelegenheit. Zumal man dann auch ein backup machen könnte. Oder mit
ein paar Skripten ein Outlook export realisieren.
von g457 (Gast)
# cat /user_data/home/Applications/addressbook/addressbook.xml
<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE Addressbook ><AddressBook>
<Groups>
</Groups>
<Contacts>
<Contact Uid="-1269681130" FirstName="test" FileAs="test" HomeVideo="+49123456"  BUSINESS_CONTACT="" qdl-private-data=""  />
</Contacts>
</AddressBook>
HTH
ins wiki bitte
Das mit dem Addressbook ist eine Sache, an der ich auch schon überlege.
Es wäre doch fein, das auf einem zentralen Speicher liegen zu haben und
alle VPs laden es sich dort herunter, oder ziehen es per nfs oder wie
auch immer. Ein Update auf einem VP sollte auch alle anderen updaten.
Man müsste aber mal die ganzen mögichen Einträge sammeln:
Develli//> cat /user_data/home/Applications/addressbook/addressbook.xml
<Groups>
</Groups>
<Contacts>
<Contact Uid="-1269554029" FirstName="VoIP" LastName="Phone1" FileAs="VoIP Phone1"
HomeMobile="**621"  tone="/usr/local/etc/SystemRingTones/15-Techno2.desktop"  />
<Contact Uid="-1269554032" FirstName="VoIP" LastName="Phone3" FileAs="VoIP Phone3"
HomeMobile="**623"  BUSINESS_CONTACT="" qdl-private-data=""
tone="/usr/local/etc/SystemRingTones/08-Celtrelax.desktop"  />
</Contacts>
</AddressBook>
Die einzelnen Datenfelder sollten ja dank XML kein Problem sein, aber
was ist mit der Uid?
Man müsste als nur diese Datei synchronisieren und alle Dateien auf die
verlinkt werden, also Photos und Klingeltöne.
Wenn jemand dann noch Java kann, könnte man auch ein PC-Tool schreiben,
das das Editieren der zentralen Datei erlaubt, bzw. das Synchronisieren
mit den gängigen Handies oder eMail Programmen.
R.H.
Wenn ich den FBEditor starte, dann kommt immer die OVI Suite, also die
Nokia Softrware für mein E61i hoch, nicht der FBEditor. Mach ich da was
falsch?
Gruß, Ulrich
von Ralph S. (rallerix)
> [code]# cat /user_data/home/Applications/addressbook/addressbook.xml
Kann man die UID frei vergeben, (natürlich eindeutig)?
Andere Sache, die von florian am 25.03. angesprochen wurde: bei
Telefongesprächen ist Lauthören eingestellt. Da mich die Fritzbox über
ISDN routet, sind das definitiv Audiogespräche. Gibts da einen Menüpunkt
zum Umstellen auf Hörmuschel?
Nächste Frage in diesem Zusammenhang: hin und wieder will man ja andere
am Gespräch teilhaben lassen und auf Lauthören stellen, da wäre eine
Umstellung per "Kontextmenü" über die linke Displaytaste hilfreich.
Gibt es da schon Erkenntnisse?
Nachtrag:
Addressbook.xml scheint in einem VCard Format zu sein:
Habe dazu folgendes gefunden:
http://www.thok.org/intranet/python/contacts/vcard_to_pma.py
Wenn ich über die FB telefoniere ( ich habe nur ISDN, kein SIP) dann
verhält sich das VP6500 so, dass das Freizeichen extrem laut über die
Freispreche ausgegeben wird, nimmt der Angerufene ab, schaltet das VP
auf Hörmuschel. Man kann dann per Linker Taste auf Freisprechen wechseln
und wieder auf Hörer.
Ich würde es aber gerne so haben, dass alles erst einmal immer über
Hörmuschel läuft. Ich habe aber weder herausfinden können, wie man
komplett auf Hörer umschaltet, auch schon für das Freizeichen, noch wie
man die extrem schmerzhafte Lautstärke des Freizeichens leiser machen
kann.
von R. H. (snapper)
Ulrich P. schrieb:
> R.H.
> falsch?
keine ahnung, bei mir läuft´s ! vllt. mal die nokia sw deinstallieren ,
java deinst. und neu inst. und dann testen, wenn du anschl. die nokia sw
wieder inst. und es dann nicht mehr funzt wird die wohl im java was
verbiegen !
> kann.
Welches RingTone-Profil hast du denn ausgewählt? Wenn ich das Ringer
Boost wähle ist bei mir zumindest der Klingelton extrem laut, vllt.
hängt damit auch die Lautstärke beim telefonieren zusammen?
Die Fritzbox könnte als Server dienen und außerdem das interne
Telefonbuch noch mit diesem Synchronisieren.
Folgendes sollte recht einfach machbar sein:
Fritzbox ftp dient als Datenspeicher.
Jedes Telefon prüft regelmäßig die interne Datei auf änderungen (datum)
und legt in diesem fall seine Datei und alle zugehörigen Medienfiles in
eigenen Ordner auf der FB ab.
Auf der Fritzbox läuft ein service, der regelmäßig diese in ein
Verzeidhnic zusammenführt, welches die Telefone regelmäßig auf
änderungen überprüfen.
Das sollte mit ein paar scripten (vorzugsweise Perl) machbar sein.
lediglich der Merge der Dateien erfordert ein wenig mehr.
hat jemadn schon perl kompiliert?
Die neue busybox hab ich immer noch nicht drauf bekommen.
von Waldi (Gast)
ist jemand so freundlich und erklärt mir, ob und wie ich mit dnsmasq
(http://www.thekelleys.org.uk/dnsmasq/docs/dnsmasq-man.html, weiter oben
einmal erwähnt) den Update- und Zeitserver umleiten kann? In der
Artikelsammlung steht dazu leider noch nichts
(http://www.mikrocontroller.net/articles/PHILIPS_VP5500_VoIP_Telefon).
sprite_tm schreibt dazu einen Satz: "Change the DHCP server to force it
to use 188.40.123.50 as a DNS server"
(http://spritesmods.com/?art=vpx500&page=3).
Mein Router ist mit "tomato" (http://www.polarcloud.com/tomato/)
ausgestattet, ich vermute dass die erforderliche Umleitung funktioniert,
aber ich weiss nicht weiter..
von senk (Gast)
einfach mal probieren: rechtsklick auf die datei -> öffnen mit ->
"java..."
von Waldi (Gast)
Kommando zurück, es hat mit Basic>Network>Static DNS = 188.40.123.50
funktioniert.
Na sowas, jetzt beantworte ich schon meine eigenen Fragen ;-)
Habe gerade mal ein bischen mit dem Adressbuch gespielt und einen
Eintrag manuell eingebaut. UID ist wohl egal, solange sie nicht zweimal
vorkommen.
Kennt jemand einen komfortablen xml- Editor? Mit Ultraedit macht es
nicht wirklich Spaß...
Die Beschränkung auf 500 Adressbucheinträge kann man auch aufheben; bin
neulich auf "maxEntries = 500" in der "Contacts.conf" gestoßen.
bitte haltet das mal im Wiki fest!
Es sit fast unmöglihc in diesem Thread was wiederzufinden
von Leo C. (rapid)
Zu dnsmasq
Bei mir gings so in der /etc/dnsmasq.conf:
# Gruppe "tel" mit einem ip Nummernbereich für telefone
dhcp-range=tel,192.168.7.70,192.168.7.79,12h
# DNS-Server für Gruppe "tel":
dhcp-option=tel,option:dns-server,84.38.68.30
# Gerät mit dieser MAC-Adresse in die Gruppe
dhcp-host=00:16:41:72:7A:78,net:tel
Nach erfolreichem Update kann man den DNS-Server Eintrag löschen.
von Waldi (Gast)
Ich kann nun ein VP6500 von Ekiga aus anrufen (103@xxx.xxx.xxx.xxx),
allerdings nur mit Sprachverbindung.
Was ist für eine Videoübertragung notwendig? Wie kann man vom VP6500
einen SIP user wie user@host anrufen?
Der hier ist super: http://www.firstobject.com/dn_editor.htm und kost'
nix! Das Teil ist sogar in einer C-ähnlichen Sprache programmierbar.
Andreas
Hat es eigentlich mal jemand geschafft, das Addressbuch mit dem QTopia
Desktop zu synchronisieren? Bei mir versucht sich der Desktop auf das
Gerät zu verbinden, scheitert dabei allerdings. Offenbar läuft dort
irgendein Dienst nicht, zu dem er verbinden will. Vermutlich jemand, der
auf Port 16 lauscht - zumindest wollte von meinem Rechner irgendwer ein
SYN an diesen Port senden.
Andreas
Indem man einfach als Telefonnummer entweder user@host oder
sip:user@host einträgt. Umschalten zwischen Zahlen- und Texteingabe kann
man durch langes drücken der # Taste. Ich glaube das man das sip: davor
nicht braucht.
Bzgl. Video-Telefonat: Kann es sein das man den Anruf als Video-Anruf
machen muss? Zumindest bei dem Telefon gibt es im Tel.-Buch ja
verschiedene Kategorien für sowas. Es müssen natürlich auch die
verwendeten Ports stimmen.
Grüße,
Chris
> "java..."
Anwendungsfehler: Die Anwendung konnte nicht gestartet werden.
Keine Chance. Ist aber nicht so tragisch, hatte das Editieren für den
DNS einfach vie Notepad++ gemacht. Nach einem halbherzigen Fehlversuch
dann aber gleich die Serielle genommen.
Gruß, Ulrich
Es gibt noch einen kleinen Komfortmakel:
Die VPs verwalten die verpassten Gespräche autark. Hat man also mehrere
VPs so sammeln sich da ganz schöne Listen von verpassten Anrufen. Hat
die FritzBox, bzw. der Sip-Server auf ihr nicht selber ein Missed-Call
verzeichnis und setzt dieses auch zurück, wenn eines der Mobilteile die
Liste angerufen hat?
Meine Siemens DECT Anlage macht das so, dass sie die Missed-Calls
Anzeige auf allen Mobilteilen zurück setzt, wenn man an einem
nachgesehen hat.
Ich weiß, kann man bestimmt scripten, aber ich wollte halt mal wissen,
ob ein SIP Server grundsätzlich so etwas kann, speziell der auf der FB.
von Waldi (Gast)
Danke für den Tip mit dem Umschalten des Eingabemodus. Mir wird dann
aber gesagt: "Unable to make phone calls as no network has been
registered."
Ich nehme an, damit ist ein SIP-Server gemeint? Also ein eigener
asterisk oder ein Dienst wie sipgate.de?
Habe versucht, ein ekiga.net SIP-Account einzutragen
(OK>Applications>Registration). Da kann ich dann plötzlich für mein WLAN
kein WPA mehr auswählen.
Weitere Hürde ist, dass das VP6500 für SIP register die Angabe im Format
address:port haben möchte. Nun weiss ich nicht, ob man ekiga.net:5060
irgendwie auflösen kann.
Also ich muss sagen, dass das VP6500 was das Öffnen des Gehäuses angeht,
sehr vom VP5500 abweicht! Das VP6500 hat nur 2 Schrauben um den
Frontrahmen zu befestigen, ist aber ziemlich tricky geklipst: Die
Rastnasen unter dem display, also im Bereich der Tastatur sind mit der
Unterschale verbunden. Im Bereich des Displays jedoch hängt der
Frontrahmen an dem Displayrahmen. Also kurz zusammengefasst: im unteren
Bereich die Haken zum Gehäuseinneren drücken, weiter oben beim Display
nach außen. Hoffe das ist verständlich so...
Ansonsten bin ich froh "kein" 5500 bekommen zu haben wenn ich von den
Akkuproblemen lese. Da ist das 6500 mit den Mignon Akkus doch deutlich
einfach mit neuen akkus zubestücken.
> registered."
Ja, oder eben ekiga.net.
Aber vorsicht: Die ganzen SIP Registrare machen das unter sich aus
welchem Netz man in welches andere Telefonieren kann mittels SIP. So
kann man z.B. aus SipGate heraus nur in zwei andre SIP Netze direkt
telefonieren. Alles andere muss dann über die jeweilige, normale
Telefonnummer des anderen Teilnehmers gemacht werden. Sofern er dann
eine hat. Ekiga ist z.B. nur Internet, ohne "echte" Anschlüsse.
Also das sollte eigentlich gleich der erste Dialog sein der da kommt.
Der öffnet dann auch gleich die Auswahlbox für das WLLN (SSID).
Allerdings scheint es irgendwie einen Bug in dem Dialog zu geben. Wenn
man irgendwie ein Feld leer lässt, in dem was stehen muss, scheint es ab
dann Probleme zu geben. Ich hatte das auch schon einmal, aber nicht
weiter nachverfolgt. Dann heisst es die serielle anschliessen und die
betreffenden Dateien wieder herstellen. Das wäre einmal die
/user_data/data/hpr0userparam für die SIP Einstellungen, und die
/usr/local/data/wpa_supplicant.conf für die WLAN Einstellungen.
Diese Einstellungen haben nur bedingt etwas damit zu tun wie das intern
gehandhabt wird. Man gibt ekiga.net:5060 ein, abgespeichert wird das in
den Config-Dateien dann aber getrennt. Also einmal der Hostname und
einmal die Portnummer.
Grüße,
Chris
vielleicht wäre es Sinnvoll die Artikelseite umzubenennen. Jetzt heisst
der Link ja "PHILIPS_VP5500_VoIP_Telefon". Da jetzt aber auch vermehrt
die 6500er dazukommen, sollte man das evtl. in
"PHILIPS_VP5500_VP6500_VoIP_Telefon" umbenennen. Dadurch das beide Namen
angegeben sind sollte das auch bei Suchmaschinen entsprechend leicht zu
finden sein.
Dann nach und nach die Unterschiede zwischen den beiden auflisten. So
hat das 6500 ja 64MB Flash, das 5500 nur 32MB.
Grüße,
Chris
