Forum: Compiler & IDEs Fehlermeldung eclipse
Autor: Knut (Gast)
nach dem Übertragen der Software meldet Eclipse folgenden Code in der
Console:
Launching C:\WinAVR-20100110\bin\avrdude -pm128 -cstk500v2 -Pcom9 -u
-Uflash:w:MTS200.hex:a -Ulfuse:w:0x3f:m -Uhfuse:w:0xd9:m
-Uefuse:w:0xff:m -Ulock:w:0xf3:m
Output:
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100%
0.02s
avrdude: Device signature = 0x1e9702
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be
performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "MTS200.hex"
avrdude: input file MTS200.hex auto detected as Intel Hex
avrdude: writing flash (266 bytes):
Writing | ################################################## | 100%
0.14s
avrdude: 266 bytes of flash written
avrdude: verifying flash memory against MTS200.hex:
avrdude: load data flash data from input file MTS200.hex:
avrdude: input file MTS200.hex contains 266 bytes
avrdude: reading on-chip flash data:
0.09s
avrdude: verifying ...
avrdude: 266 bytes of flash verified
avrdude: reading input file "0x3f"
avrdude: writing lfuse (1 bytes):
0.02s
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0x3f:
avrdude: load data lfuse data from input file 0x3f:
avrdude: input file 0x3f contains 1 bytes
avrdude: reading on-chip lfuse data:
0.00s
avrdude: 1 bytes of lfuse verified
avrdude: reading input file "0xd9"
avrdude: writing hfuse (1 bytes):
0.00s
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xd9:
avrdude: load data hfuse data from input file 0xd9:
avrdude: input file 0xd9 contains 1 bytes
avrdude: reading on-chip hfuse data:
0.02s
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xff"
avrdude: writing efuse (1 bytes):
0.00s
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xff:
avrdude: load data efuse data from input file 0xff:
avrdude: input file 0xff contains 1 bytes
avrdude: reading on-chip efuse data:
0.00s
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0xf3"
avrdude: writing lock (1 bytes):
Writing |  ***failed;
################################################## | 100% 0.11s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0xf3:
avrdude: load data lock data from input file 0xf3:
avrdude: input file 0xf3 contains 1 bytes
avrdude: reading on-chip lock data:
0.00s
avrdude: verification error, first mismatch at byte 0x0000
         0xf3 != 0x33
avrdude: verification error; content mismatch
avrdude done.  Thank you.
avrdude finished
Das Programm funktioniert, jedoch mach mich der letzte Absatz etwas
stuzig
Warum gibt es beim verifying einen Fehler bzw. was sagt dieser Fehler
aus?
Gruß Knut
Autor: Klaus Falser (kfalser)
Nicht Eclipse meldet den Fehler, sondern das Programm avrdude, das den
Chip programmiert.
Und zwar werden das extendend fuse byte und das lock byte nicht richtig
programmiert.
Autor: Knut (Gast)
Ok, aber woran liegt das bzw. kannst du das etwas präziser ausführen?
Gruß Knut
Autor: Oliver (Gast)
> programmiert.
Doch. Da hat avrdude einen "Bug". In diesen Fuse-Bytes sind nicht alle
Bits benutzt, laut Datenblatt stehen die ungenutzten auf 1, allerdings
liest avrdude da eine 0. Daher kommt der Verify-Error. Die benutzen Bits
stimmen aber trotzdem, was man mittels Datenblatt nachprüfen kann und
sollte.
Allerdings sollte man an den fuses nur rumspielen, wenn es absolut
erforderlich ist. Die müssen nicht bei jedem Programmiervorgang erneut
geschrieben werden. Und deine Frage lässt vermuten, daß du da gar nicht
genau verstehst, was da eigentlich passiert.
Oliver
Autor: Knut (Gast)
Könnte man vermuten... Ich hab vorher mit dem AVR- Studio programmiert,
da Tabs nie Probleme mit den fuses. Jetzt bin ich auf Eclipse
umgestiegen
und hatte groß Probleme überhaupt meine Programmer einzurichten!
1. Falsche Version von WinAVR
2. System hat falsche Treiber verwendet
daher war ich mir jetzt unscher was nun wieder falsch sein könnte,
da es sehe leicht is mit Eclipse Fehler zu machen. Im Nachhinein
überlege ich ob ich wirklich bei Eclipse bleiben soll und nich doch bei
AVR Studio bleibe! Eclipse hat halt ne sehr schöne Oberfläche.
Kann mir denn jemand mal Vorteile gegenüber dem Studio nennen?
Gruß Knut
Besserer Editor, integrierte Versiosnverwaltung, Programmer besser
integriert, ...
Und die Settings für avrdude und anderes lassen sich per Mausclick in
den Projektsettings einstellen.
Eclipse verwendet genauso wie AVRStudio WinAVR. Was sollte da an der
Version falsch sein (ausser, du nutzt steinalte Versionen)?
Oliver
Autor: Knut (Gast)
WinAVR20070XYZ, in dieser Version standen unter Eclipse keine
Programmiergeräte zur Auswahl,  warum auch immer...
mit der ganz aktuellen Version hat's auf Anhieb geklappt!
Der Editor von Eclipse ist sehr übersichtlich und optisch ansprechend!
Da macht das Programmieren richtig Spass fürs Auge!
Ich werd nochn paar Tage rumspielen, ma sehn wie es sich dann
handhaben lässt
Gruß Knut
