Hallo zusammen, ich versuche einen Mega128 über den OOCD-Link von Embedded Projects anzusprechen. Allerdings kommt beim ausführen meines Config Files immer die folgende Fehlermeldung: Open On-Chip Debugger 0.2.0-in-development (2009-06-30-01:49) svn:r2403 BUGS? Read /usr/share/doc/openocd/BUGS $URL: http://svn.berlios.de/svnroot/repos/openocd/trunk/src/openocd.c $ jtag_speed: 1 4500 kHz jtag_nsrst_delay: 100 Error: JTAG communication failure: check connection, JTAG interface, target power etc. Error: trying to validate configured JTAG chain anyway... Error: Could not validate JTAG scan chain, IR mismatch, scan returned 0x3F. tap=avr.cpu pos=0 expected 0x1 got 3 Warn : Could not validate JTAG chain, continuing anyway... Anbei noch mein Config File was aus den bei OOCD vorhandenen config files zusammengeschustert wurde: #daemon configuration telnet_port 4444 gdb_port 3333 #Board interface ft2232 ft2232_vid_pid 0x0403 0x6010 ft2232_device_desc "Dual RS232 A" ft2232_layout "oocdlink" ft2232_latency 2 # 6/(1+n) Mhz TCLK jtag_speed 1 #Target # for avr set _CHIPNAME avr set _ENDIAN little # jtag speed jtag_khz 4500 reset_config srst_only jtag_nsrst_delay 100 #jtag scan chain if { [info exists CPUTAPID ] } { set _CPUTAPID $CPUTAPID } else { set _CPUTAPID 0x8970203F } jtag newtap $_CHIPNAME cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id $_CPUTAPID set _TARGETNAME [format "%s.cpu" $_CHIPNAME] target create $_TARGETNAME avr -endian $_ENDIAN -chain-position $_TARGETNAME #$_TARGETNAME configure -work-area-virt 0 -work-area-phys 0x20000000 -work-area-size 16384 -work-area-backup 0 flash bank avr 0 0 0 0 0 #to use it, script will be like: #init #jtag_khz 4500 #reset init #verify_ircapture disable # #halt #wait halt #poll #avr mass_erase 0 #flash write_image E:/Versaloon/Software/CAMERAPROTOCOLAGENT.hex #reset run #shutdown # # For more information about the configuration files, take a look at: # openocd.texi Hab leider noch nicht so viel Erfahrung mit der Programmierung von Controllern daher hoffe ich das ihr mir weiterhelfen könnt. Vielen Dank schonmal Mfg Johannes
Ich hatte gedacht/gehofft das, weil der mega128 im target verzeichnis ist, es möglich sein sollte!
Ich bin bislang davon ausgegangen, daß AVRs nur mit speziellen ATMEL-ICEs bzw. Nachbauten angesprochen werden können; wenn das mittlerweile mit OOCD geht, wäre das ein großer Fortschritt. Also bitte nicht missverstehen als "was machst Du da für einen Unfug" oder so!
Kein Problem! Ich hatte gedacht/gehofft das es möglich ist den Mega zu programmieren. Gibt es denn sonst eine lowcost JTAG alternative für den Mega?
http://wiki.ullihome.de/index.php/Hauptseite#USB_AVR-Lab kann auch über JTAG programmieren, jedoch nicht debuggen. lg Christian
