Forum: PC-Programmierung "unresolved externals" bei statischer Methode
Autor: Maxim (Gast)
DE_handler.h
#pragma once
#include "stdafx.h"
class DE_handler
public:
  int main(void);
  DE_handler(void);
  static vector<float> mul_vec(vector<float>, float k);
  static vector<float> add_vec(vector<float>, vector<float>);
DE_handler.cpp
#include "DE_handler.h"
#include "equation.h"
int main(void)
  float time = 0.0;
  float t_end = 10.0;
  float h = 1;
  vector<float> c; //constants
  vector<float> initial; //initial values
  vector<float> temp_res; //temporary stored results
  vector<vector<float>> results; //calculated results
  //define vector of constants belonging to the differential equation
  c.push_back(1/4);
  c.push_back(-1/100);
  c.push_back(-1);
  c.push_back(1/100);
  //define initial values
  initial.push_back(80.0);
  initial.push_back(30.0);
  equation eq(c);
  temp_res = initial;
  temp_res = DE_handler::add_vec(initial, initial);
  cout << temp_res.at(0) << " " << temp_res.at(1);
  system("Pause");
  return 0;
static vector<float> mul_vec(vector<float> vec, float k)
    for(int i = 0; i <= vec.size(); i++)
      vec.at(i) = vec.at(i)*k;
    return vec;
static vector<float> add_vec(vector<float> vec1, vector<float> vec2)
    vector<float> sum;
    for(int i = 0; i < vec1.size(); i++)
      sum.push_back(vec1.at(i)+vec2.at(i));
    return sum;
DE_handler::DE_handler(void)
Die genaue Meldung des Compilers:
"Error  3  error LNK2019: unresolved external symbol "public: static
class std::vector<float,class std::allocator<float> > __cdecl
DE_handler::add_vec(class std::vector<float,class std::allocator<float>
>,class std::vector<float,class std::allocator<float> >)"
(?add_vec@DE_handler@@SA?AV?$vector@MV?$allocator@M@std@@@std@@V23@0@Z)
referenced in function _main
D:\Dokumente\Studium\NDGL\NDGL_P1\NDGL_P1\DE_handler.obj  NDGL_P1
Ich komme nicht drauf, was dem Compiler fehlt. Wenn ich die Zeile
auskommentiere, gibt es diesen Fehler nicht. Anscheinend kann der
Compiler die Methode add_vec() nicht finden, oder wie?
Autor: g457 (Gast)
(u.A.) da..
..fehlt der Klassenname!
HTH
Autor: Karl Heinz (kbuchegg) (Moderator)
Maxim schrieb:
> #pragma once
> #include "stdafx.h"
> class DE_handler
> public:
>   int main(void);
>   DE_handler(void);
Du sollst nicht Java programmieren, wenn du einen C++ Compiler benutzt.
Autor: Mark Brandis (markbrandis)
Autsch... was hat denn main() in der Deklaration einer Klasse zu suchen?
Autor: ... (Gast)
Das war aber nicht der Fehler.
Der Linker vermisst eine Funktion DE_handler::add_vec, Du hast aber nur
add_vec.
Steht hier aber schon mal:
Beitrag "Re: "unresolved externals" bei statischer Methode"
Autor: Klaus Wachtler (mfgkw)
Auch wenn es eher -äh- etwas ungewöhnlich ist, spricht theoretisch
nichts gegen eine Methode main in einer Klasse.
Eh. Wird die dann als Einsprungpunkt genommen? Und wenn es eine
nicht-statische Methode ist und zur Laufzeit noch kein Objekt dieser
Klasse instanziiert wurde?
Autor: ... (Gast)
Nein, die wird natürlich nicht als Einsprungpunkt genommen. Ist eine
stinknormale Methode wie jede andere auch.
Genau.
Ebenso wie rhein(), donau() und mosel().
Der ganze gepostete Code erzählt allerdings die Geschichte, dass der TO
das ganze anders sieht :-)
Das ist dann sein Problem :-))
Autor: Maxim (Gast)
Zu main(): Das Programm wird ausgeführt, auch wenn kein Objekt von
DE_handler erstellt wurde. Die main()-Methode funktioniert bestens ...
Wo ist das Problem?
Ansonsten läuft es jetzt. Musste die Klasse vor die Methode schreiben.
Mit static hatte der Compiler dann auch Probleme. Anscheinend darf
static vor der Methode nur in der Headerdatei stehen, nicht aber im
Quellcode, oder?
Ich stolper über viele Sachen in C++, weil ich davor lange in Java
programmiert habe. Vor allem die ganzen Deklarationen und die
Headerdateien verwirren mich.
Autor: Klaus (Gast)
> Wo ist das Problem?
Das funktioniert aber nur, weil du vor main eben nicht den Klassen-Namen
geschrieben hast. Damit ist deine Funktion main aus der DE_Handler
Klasse noch undefiniert. Zum Glück rufst du die auch nicht auf, so dass
der Linker keinen Grund hat zu meckern.
Also: raus mit dem main() aus der Klassendefinition, das hat da nichts
zu suchen!
Autor: Rufus Τ. Firefly (rufus) (Moderator) Benutzerseite
Die Implementierung heißt main und nicht /DE_handler::main/.
Deswegen funktioniert es, der Compiler erwartet ein main auf globaler
Ebene.
Hättest Du Deine Implementierung /DE_handler::main/ genannt, würde Dich
der Linker anmotzen, weil er kein main finden kann.
Würde irgendwo /DE_handler::main/ referenziert, würde der Compiler
motzen, solange es keine Implementierung davon gibt.
Das ist der Vorteil von Java, daß es mit C++ nur die Syntax, sonst
aber nicht viel gemein hat.
> programmiert habe.
Du stolperst über viele Sachen in C++, weil du versuchst nach der
Methode 'Versuch und Irrtum' bzw. 'Für einen alten Java Hasen kann das
doch nicht so schwer sein' an die Sache ran zu gehen.
Hol dir einen Stroustroup aus der nächsten Buchhandlung und arbeite ihn
von vorne weg durch. Die ersten Kapitel, wo es um Zahlen, Darstellungen
und dergleichen geht, kannst du oberflächlich überfliegen. Sobald aber
die ersten Programme im Text auftauchen, solltest du etwas genauer
lesen. Du wirst vieles entdecken, was ganz ähnlich wie in Java
funktioniert. Du wirst aber auch noch viel mehr entdecken, was in C++
völlig anders gemacht wird.
Zb. Muss in Java jede Funktion ein Member einer Klasse sein.
In C++ aber nicht. Es ist kein Problem freistehende Funktionen zu haben,
die zu keiner Klasse gehören.
Ganz im Gegenteil: 1 Funktion ist in jedem Programm, welche zu keiner
Klasse gehört: main()
Und deine static Funktionen:
Diese Funktionen haben ja im eigentlichen Sinn überhaupt nichts mit
einem DE_Handler zu tun (was immer das auch sein mag). An dieser Stelle
macht diese Klasse überhaupt keien Sinn! Es sieht so aus, dass du die
Klasse nur deswegen gebaut hast, weil du von Java gewohnt bist, dass
jede Funktion in irgendeiner Klasse sein muss.
Aber wie schon gesagt: In C++ ist das nicht so. Man gruppiert Funktionen
in Klassen, weil es sinnvoll ist, weil diese Funktionen einen
gemeinsamen Bezug zueinander und zur Klasse haben und nicht weil das
Sprachkonzept es nicht erlaubt Funktionen ausserhalb von Klassen zu
haben.
Und wenn du dann im Stroustroup soweit vorgedrungen bist, sollte man
sich auch einmal über Argument Passing Mechanismen unterhalten :-)
Autor: Rolf Magnus (Gast)
> Quellcode, oder?
Richtig. Das ist etwas seltsam, aber ist nun mal so in C++.
Du solltest dir auch mal die Standardlib anschauen. Für das, was du da
mit vector<float> machst, wäre std::valarray<float> eine sinnvolle
Alternative. Da ist das, was deine Funktionen machen, schon als
Operatoren vordefiniert.
Damit könnten die Funktionen so aussehen:
valarray<float> mul_vec(valarray<float> arr, float k)
  arr *= k;
  return arr;
valarray<float> add_vec(const valarray<float>& arr1, const valarray<float>& arr2)
  return arr1 + arr2;
Eigentlich braucht man sie also gar nicht mehr.
Übrigens:
geht nicht durch einen konformen Compiler. Es müßte heißen:
   vector<vector<float> > results; //calculated results
Und warum benutzt du eigentlich überall float statt double? Wenn deine
Arrays nicht gerade so riesig werden, daß du auf den Speicher achten
mußt, solltest du grundsätzlich double bevorzugen.
