1 | //ICC-AVR application builder : 13.04.2010 16:15:44
2 | // Target : m48
3 | // Crystal: 8.0000Mhz
4 |
5 | #include <iom48v.h>
6 | #include <macros.h>
7 |
8 | unsigned char i = 0;
9 | unsigned int result;
10 |
11 | void port_init(void)
12 | {
13 | PORTB = 0xF1;
14 | DDRB = 0x0E;
15 | PORTC = 0x43;
16 | DDRC = 0xBC;
17 | PORTD = 0x00;
18 | DDRD = 0xFF;
19 | }
20 |
21 | void timer0_init(void)
22 | {
23 | OCR0A = 0x80;
24 | OCR0B = 0x80;
25 | TCCR0A |= (1 << WGM01) | (1 << WGM00); // Fast PWM
26 | TCCR0A |= (1 << COM0A1); // Fast PWM, non-inverting mode
27 | TCCR0A &= ~(1 << COM0A0);
28 | TCCR0A |= (1 << CS02); // Prescaler: 1/256
29 |
30 | // TCCR0B |= (1 << WGM01) | (1 << WGM00); // Fast PWM
31 | // TCCR0B |= (1 << COM0B1); // Fast PWM, non-inverting mode
32 | // TCCR0B &= ~(1 << COM0B0);
33 | // TCCR0B |= (1 << CS02); // Prescaler: 1/256
34 |
35 |
36 | }
37 |
38 | //TIMER1 initialize - prescale:64
39 | // WGM: 0) Normal, TOP=0xFFFF
40 | // desired value: 100mSec
41 | // actual value: 100,000mSec (0,0%)
42 | void timer1_init(void)
43 | {
44 | TCCR1B = 0x00; //stop
45 | TCNT1H = 0xCF; //setup
46 | TCNT1L = 0x2C;
47 | OCR1AH = 0x30;
48 | OCR1AL = 0xD4;
49 | OCR1BH = 0x30;
50 | OCR1BL = 0xD4;
51 | ICR1H = 0x30;
52 | ICR1L = 0xD4;
53 | TCCR1A = 0x00;
54 | TCCR1B = 0x03; //start Timer
55 | }
56 |
57 | //ADC initialize
58 | // Conversion time: 6uS
59 | void adc_init(void)
60 | {
61 | ADCSRA = 0x00; //disable adc
62 | ADMUX = 0x00; //select adc input 0
63 | ACSR = 0x80;
64 | ADCSRB = 0x00;
65 | ADCSRA = 0x01;
66 |
67 | }
68 |
69 | #pragma interrupt_handler timer1_ovf_isr:iv_TIM1_OVF
70 | void timer1_ovf_isr(void)
71 | {
72 | //TIMER1 has overflowed
73 | TCNT1H = 0xCF; //reload counter high value
74 | TCNT1L = 0x2C; //reload counter low value
75 |
76 |
77 |
78 | //----------------------------------------------------------------------------//
79 | // AD-Wandlung
80 | //----------------------------------------------------------------------------//
81 | // Dummy-Readout
82 | ADCSRA = (1<<ADEN) | (1<<ADPS2) | (1<<ADPS1); // ADC aktivieren, Frequenzvorteiler: setzen auf 64 (8 MHz / 64 = 125 kHz) und ADC aktivieren
83 | ADMUX = 0x00; // Kanal waehlen (ADC0)
84 | ADMUX |= (1<<REFS0) | (1<<REFS1); // interne Referenzspannung nutzen
85 | ADCSRA |= (1<<ADSC); // eine ADC-Wandlung
86 | while(!(ADCSRA & (1<<ADIF))); // auf Abschluss der Konvertierung warten (ADIF-bit)
87 | result = ADC; // ADC muss einmal gelesen werden,
88 | // sonst wird Ergebnis der nächsten Wandlung
89 | // nicht übernommen.
90 |
91 | //ADC-Messung mit arithmetischen Mittel aus 4 Messungen
92 | result = 0;
93 | for (i=0;i<4;i++)
94 | {
95 | ADCSRA |= (1<<ADSC); // Messung ausfuehren
96 | while ( ADCSRA & (1<<ADSC) ); // Konvertierung abwarten
97 | result += ADC; // aufaddieren zur Mittelwertbildung (ADC auslesen der zwei Bits
98 | }
99 | ADCSRA &= ~(1<<ADEN); // ADC ausschalten
100 |
101 | result /= 16; // Mittelwert aus 4 und 8Bit für PWM (1024 / 4 = 256)
102 |
103 | OCR0A = result; // OC0A (PD6) = Poti-wert
104 | OCR0B = result; // OC0B (PD5) = Poti-wert
105 |
106 |
107 | //----------------------------------------------------------------------------//
108 | // AD-Abfrage zur Prüfung auf Funktion - Komentare sind für ein anders Projekt
109 | //----------------------------------------------------------------------------//
110 | if (result < 63) //410 = 5,4V
111 | {
112 | PORTD &= ~0x15; // PD4, PD2 &PD0 low
113 | PORTD |= 0x08; // PD3 high => LED an
114 | }
115 | if ((result < 127) & (result >= 63)) //430 = 5,7V
116 | {
117 | PORTD &= ~0x0D; // PD3, PD2 & PD0 low
118 | PORTD |= 0x10; // PD4 high => LED an
119 | }
120 | if ((result < 191) & (result >= 127)) //915 = 10,8V, 975 = 11,5V bei 100K und 330R
121 | {
122 | PORTD &= ~0x1c; // PD4, PD3 & PD2 low
123 | PORTD |= 0x01; // PD0 high => LED an
124 | }
125 | if (result >= 191)
126 | {
127 | PORTD &= ~0x19; // PD4, PD3 & PD0 low
128 | PORTD |= 0x04; // PD2 high => LED an
129 | }
130 |
131 | }
132 | ////////////////////////////////////////////////////////////////////////////////
133 | // Hauptprogramm
134 | ////////////////////////////////////////////////////////////////////////////////
135 | void main(void)
136 | {
137 | //stop errant interrupts until set up
138 | CLI(); //disable all interrupts
139 | port_init();
140 | timer0_init();
141 | timer1_init();
142 | adc_init();
143 |
144 |
145 | MCUCR = 0x00;
146 | EICRA = 0x00; //extended ext ints
147 | EIMSK = 0x00;
148 |
149 | TIMSK0 = 0x01; //timer 0 interrupt sources
150 | TIMSK1 = 0x01; //timer 1 interrupt sources
151 | TIMSK2 = 0x00; //timer 2 interrupt sources
152 |
153 | PCMSK0 = 0x00; //pin change mask 0
154 | PCMSK1 = 0x00; //pin change mask 1
155 | PCMSK2 = 0x00; //pin change mask 2
156 | PCICR = 0x00; //pin change enable
157 | PRR = 0x00; //power controller
158 | SEI(); //re-enable interrupts
159 | //all peripherals are now initialized
160 |
161 | while(1);
162 | // Endlosschleife, blinken läuft im 100ms Interrupt
163 |
164 |
165 | }
