1 | #include <avr/io.h>
2 | #include <avr/interrupt.h>
3 | #include <avr/pgmspace.h>
4 | #include <avr/eeprom.h>
5 | #include <util/delay.h>
6 | #include <stdlib.h>
7 |
8 | #define BAUD 2400UL
9 | #define UBRR_VAL ((F_CPU+BAUD*8)/(BAUD*16)-1) // clever runden
10 |
11 |
12 |
13 | #define RFM02_CS PB5 // AVR MOSI
14 | #define RFM02_SDI PB6 // AVR MISO
15 | #define RFM02_SCK PB7 // AVR SCK
16 | #define RFM02_IRQ PB0
17 |
18 | #define RFM02_DDR DDRB
19 | #define RFM02_PORT PORTB
20 | #define RFM02_PIN PINB
21 |
22 |
23 | void rfm02_init();
24 | void rfm02_send_data(void);
25 | uint8_t rfm02_send_cmd(uint16_t);
26 | uint8_t rfm02_send_8bit(uint8_t);
27 |
28 |
29 | void uart_putc(unsigned char c)
30 | {
31 | while (!(UCSRA & (1<<UDRE))); /* warten bis Senden moeglich */
32 | UDR = c; /* sende Zeichen */
33 | }
34 |
35 | //######################################################################################################
36 |
37 |
38 | void uart_puts( char * s )
39 | {
40 | while(*s)
41 | { /* so lange *s != '\0' also ungleich dem "String-Endezeichen" */
42 | uart_putc(*s);
43 | s++;
44 | }
45 | }
46 |
47 |
48 | void uart_init()
49 | {
50 | UCSRB |= (1<<RXEN);
51 | UCSRB |= (1<<TXEN);
52 |
53 | UBRRH = UBRR_VAL >> 8;
54 | UBRRL = UBRR_VAL;
55 | }
56 |
57 |
58 |
59 | char buffer = 'B';
60 | void rfm02_init()
61 | {
62 |
63 | RFM02_PORT |= (1<<RFM02_IRQ) | (1<<RFM02_CS) | (1<<RFM02_SDI); // PullUp ein / Ausgang H
64 | RFM02_DDR |= (1<<RFM02_CS) | (1<<RFM02_SCK) | (1<<RFM02_SDI); // Ausgänge
65 | RFM02_DDR &= ~(1<<RFM02_IRQ); // Eingang
66 |
67 | rfm02_send_cmd(0xCC00); // Status read
68 |
69 | rfm02_send_cmd(0xC0E0); // Power Settings: Quarz ein, Synthesizer und PA ein bei Send-Command
70 | rfm02_send_cmd(0xC220); //ENABLE BIT SYNC
71 | rfm02_send_cmd(0x8883); // Control: 1MHz Clock Out, 12,5pF Last Quarz, 120kHz Shift
72 | rfm02_send_cmd(0xA620); // Frequenz: 860MHz + (0,005 * 0x620) -> 867,84MHz
73 | rfm02_send_cmd(0xB200); // Power 2 * -3dBm -> -6dBm
74 | rfm02_send_cmd(0xD2C0); // Set PLL: set 33%
75 | rfm02_send_cmd(0xC810); // Baudrate: 344827 / 19200 = 17 - 1 -> 0x10 // Status read
76 | rfm02_send_cmd(0xE500 + 200); // WakeUp-Timer 2^7 *234ms ~ 30s ???!! nicht 1ms sondern 10ms !!???
77 | rfm02_send_cmd(0xC002); // alles aus, WakeUp-Timer ein
78 |
79 | rfm02_send_cmd(0xC440); // sleep, noch 64 Takte
80 | }
81 |
82 | uint8_t rfm02_send_cmd(uint16_t command)
83 | {
84 | uint8_t status;
85 | RFM02_PORT &= ~(1<<RFM02_CS); // CS auf L
86 | rfm02_send_8bit(command >> 8); // H-Byte senden
87 | status = rfm02_send_8bit(command & 0xFF); // L-Byte senden
88 | RFM02_PORT |= (1<<RFM02_CS); // CS auf H
89 | return status;
90 | }
91 |
92 | //-----------------------------------------------------------------------------------------
93 |
94 | uint8_t rfm02_send_8bit(uint8_t byte)
95 | {
96 | uint8_t i;
97 |
98 | for (i=0; i<8; i++)
99 | {
100 | if (byte & 0x80)
101 | {
102 | RFM02_PORT |= (1<<RFM02_SDI); // DATA auf H als Ausgang
103 | }
104 | else
105 | {
106 | RFM02_PORT &= ~(1<<RFM02_SDI); // DATA auf L
107 | }
108 | asm("nop");
109 | RFM02_PORT |= (1<<RFM02_SCK); // CLK auf H
110 | asm("nop");
111 | asm("nop");
112 |
113 | byte = (byte << 1); // nächstes Bit nach oben
114 |
115 | if (RFM02_PIN & (1<<RFM02_IRQ)) // unteres Bit Status einlesen, H?
116 | {
117 | byte |= 0x01; // DATA war H
118 | }
119 | else
120 | {
121 | byte &= ~(0x01); // DATA war L
122 | }
123 | asm("nop");
124 | RFM02_PORT &= ~(1<<RFM02_SCK); // CLK auf L
125 | }
126 | return byte;
127 | }
128 |
129 | //-----------------------------------------------------------------------------------------
130 |
131 | void rfm02_send_byte(uint8_t byte)
132 | {
133 | uint8_t i;
134 |
135 | for (i=0; i<8; i++)
136 | {
137 | while (!(RFM02_PIN & (1<<RFM02_IRQ))) {
138 | uart_putc('6');
139 | } // warten bis IRQ L/H
140 |
141 | while (RFM02_PIN & (1<<RFM02_IRQ)) {
142 | uart_putc('7');
143 | } // warten bis IRQ Impuls zuende H/L
144 |
145 | if (byte & 0x80)
146 | {
147 | RFM02_PORT |= (1<<RFM02_SDI); // DATA auf H als Ausgang
148 | }
149 | else
150 | {
151 | RFM02_PORT &= ~(1<<RFM02_SDI); // DATA auf L
152 | }
153 | byte = (byte << 1); // Bit 7 rausschieben
154 | }
155 | uart_putc('1');
156 | }
157 |
158 | //-----------------------------------------------------------------------------------------
159 |
160 | void rfm02_send_data()
161 | {
162 | uint8_t i;
163 |
164 | rfm02_send_cmd(0xC0E0); // einschalten
165 |
166 | RFM02_PORT &= ~(1<<RFM02_CS); // CS auf L
167 |
168 | rfm02_send_8bit(0xC6); // Kommando Daten senden
169 |
170 | rfm02_send_byte(0xAA); // Sync
171 | rfm02_send_byte(0xAA);
172 | rfm02_send_byte(0xAA);
173 | rfm02_send_byte(0x2D); // Magic
174 | rfm02_send_byte(0xD4);
175 |
176 | rfm02_send_byte(buffer);
177 | while (!(RFM02_PIN & (1<<RFM02_IRQ))) {
178 | uart_putc('3');
179 | }
180 | // auf Ende sendes letztes Byte warten -> L/H
181 |
182 | while (RFM02_PIN & (1<<RFM02_IRQ)) {
183 | uart_putc('4');
184 | } // erledigt, wenn IRQ wieder -> H/L
185 |
186 | while (!(RFM02_PIN & (1<<RFM02_IRQ))) {
187 | uart_putc('5');
188 | } // auf Ende Power Off warten -> L/H
189 |
190 |
191 | RFM02_PORT |= (1<<RFM02_CS); // CS auf H
192 |
193 | rfm02_send_cmd(0xC002); // alles aus, WakeUp-Timer ein
194 | rfm02_send_cmd(0xC440); // sleep, noch 64 Takte
195 |
196 | }
197 |
198 | int main(void) {
199 |
200 | uart_init();
201 | sei();
202 | rfm02_init();
203 |
204 | while(1) {
205 | _delay_ms(100);
206 | uart_putc('2');
207 | rfm02_send_data();
208 | }
209 | return 0;
210 | }
