Forum: Mikrocontroller und Digitale Elektronik AT91SAM7S64 OLIMEX P64 USB usb_control_msg write fails libusb-win32
von dg (Gast)
vorher auf yahoo gepostet, von daher auf englisch:
Dear all,
I'm having problems with sending data FROM Host TO Device (OUT).
I extended the code can be found in the FreeRTOS distribution.
I can read data with control transfer, I can do write control transfer
without
DATA STAGE.
My sequence:
PC: result = usb_control_msg(dev, USB_TYPE_VENDOR | USB_RECIP_DEVICE |
USB_ENDPOINT_OUT, 0x01, 0xAA55, 0xBB44, (char *)&ulUSBConfig, 0x08,
5000);
SAM7:
1)
ISR -> RXSETUP (device sends ACK after clearing flag)
2)
USBSample -> Gets the messages, does nothing as not necessary.
3)
ISR -> RXDATA (data payload received as awaited)
4)
USBSample -> prvProcessEndPoint0Interrupt() processes the message, sends
then
prvUSBTransmitNull() as ACK
5)
USBSample -> prvProcessEndPoint0Interrupt() does AT91C_UDP_TXCOMP
Actually I have the data in the SAM7 sent by the PC.
Still I have TIMEOUT (-116) with libusb-win32.
Any idea?
Thanks for the help.
Also, weiß jemand, was man nach prvUSBTransmitNull & TXCOMP bei Control
Transfer machen muss?
Grüße
dg
