Verkaufe wegen Fehlkauf die oben genannten Mikrokontroller. Gesammt 60 Stück Neu und OVP. Part: LPC2290FBD144 Category: Microcontrollers => 16/32 bit Description: 16/32-bit Arm Microcontrollers With CAN, 10-bit ADC And External Memory Interface<<<>>>the LPC2290 is Based on a 16/32 Bit ARM7TDMI-STM Cpu With Real-time Emulation And Embedded Trace Support. For Critical Code Size Applications, The Alternative 16-bit Thumb Mode Reduces Code BY More Than 30pct With Minimal Performance Penalty. <<<>>><<<>>>With Its 144 Pin Package, Low Power Consumption, Various 32-bit Timers, 8-channel 10-bit ADC, 2 Advanced CAN Channels, PWM Channels And up to 9 External Interrupt Pins This Microcontroller is Particularly Suitable For Automotive And Industrial Control Applications as Well as Medical Systems And Fault-tolerant Maintenance Buses. LPC2290 Provides up to 76 Gpio Depending on Bus Configuration. With a Wide Range of Additional Serial Communications Interfaces, it is Also Suited For Communication Gateways And Protocol Converters as Well as Many Other General-purpose Applications. <<<>>><<<>>> <<<>>> Features Key Features<<<>>>16/32-bit ARM7TDMI-S Microcontroller in a LQFP144 Package. <<<>>>16 KB On-chip Static RAM. <<<>>>Serial Boot-loader Using UART0 Provides In-system Download And Programming Capabilities. <<<>>>EmbeddedICE-RT And Embedded Trace Interfaces Offer Real-time Debugging With The On-chip Realmonitor Software as Well as High Speed Real-time Tracing of Instruction Execution. <<<>>>Two Interconnected CAN Interfaces With Advanced Acceptance Filters. Additional Serial Interfaces Include Two Uarts (16C550), Fast i C (400 Kbits/s) And Two Spistm. <<<>>>Eight Channel 10-bit A/D Converter With Conversion Time as Low as 2.44 Us. <<<>>>Two 32-bit Timers (with 4 Capture And 4 Compare Channels), PWM Unit (6 Outputs), Real Time Clock And Watchdog. <<<>>>Vectored Interrupt Controller With Configurable Priorities And Vector Addresses. <<<>>>Configurable External Memory Interface With up to Four Banks, Each up to 16 MB And 8/16/32 Bit Data Width. <<<>>>Up to 76 General Purpose I/o Pins (5 V Tolerant). Up to 9 Edge/level Sensitive External Interrupt Pins Available. <<<>>>60 MHZ Maximum Cpu Clock Available From Programmable On-chip Phase-locked Loop. <<<>>>On-chip Crystal Oscillator With an Operating Range of 1 MHZ to 30 Mhz. <<<>>>Two Low Power Modes, Idle And Power-down. <<<>>>Processor Wake-up From Power-down Mode Via External Interrupt. <<<>>>Individual Enable/disable of Peripheral Functions For Power Optimization. <<<>>>Dual Power Supply: <<<>>>CPU Operating Voltage Range of 1.65 V to 1.95 V (1.8 V +-0.15 V). <<<>>>I/O Power Supply Range of 3.0 V to 3.6 V (3.3 V +-10pct) With 5 V Tolerant I/o Pads Company: Philips Semiconductors (Acquired by NXP) Preis 300 euro inkl. Versand einzelversand auch Möglich habe noch eine bereits geöffnete PAckung. Bei Interesse bitte an eye-turner@gmx.de mailen. mfg hujilo
Das ist doch mehr oder weniger derselbe den Reichelt momentan zu dreifuenfundneunzig pro Stueck im Angebot haben, bei Einzelabnahme, oder vertu ich mich da?
faustian schrieb: > Das ist doch mehr oder weniger derselbe den Reichelt momentan zu > dreifuenfundneunzig pro Stueck im Angebot haben, bei Einzelabnahme, oder > vertu ich mich da? Stimmt: http://www.reichelt.de/?ACTION=3;ARTICLE=68408;PROVID=2402 Scheint ein Sonderangebot zu sein. Mouser hat den Controller für 5,31 € bei 25 Stück Abnahmemenge.
Naja, dann bietet der OP die zu 5 Euro/stk an, also fast zum Mouser-Preis..... aber ich halte lieber die Klappe, mache mich momentan in solchen Threads schnell unbeliebt ;)
Die LPC2290 bei Mouser sind aber /01-Typen, d.h. das ist die drastisch verbesserte Version des von hujilo angebotenen "alten" LPC2290. Die Verbesserungen: -64kByte RAM (statt 16kByte) -72MHz max. CPU Clock (statt 60MHz) -Fast-IOs (3,5x schneller) -separate Ergebnisregister für jeden ADC-Kanal -UART0/1: fractional baud rate generator, AutoBaud fähig, Hardwareflusssteuerung -SSP (statt einfachem SPI-Interface: schneller, universeller und mit FIFOs)
Hilfe, und sowas bekommt dann noch dieselbe Typnummer? Hinter einem - oder / erwartet man eigtl nur noch eine Geschwindigkeits-und Packageangabe...
moin falls der Preis zu teuer ist mailt mit mit Preisvorschlag
