1 | /***********************************************************************/
2 | /* ROM.ld: Linker Script File */
3 | /***********************************************************************/
4 | ENTRY(_boot)
5 | STACK_SIZE = 0x400;
6 |
7 | /* Memory Definitions */
8 | MEMORY
9 | {
10 | ROM (rx) : ORIGIN = 0x00000000, LENGTH = 512k
11 | RAM (rw) : ORIGIN = 0x40000000, LENGTH = 32k
12 | }
13 |
14 | /* Section Definitions */
15 | SECTIONS
16 | {
17 | /* first section is .text which is used for code */
18 | .text :
19 | {
20 | /* *crt0.o (.text) */ /* Startup code */
21 | KEEP(*(.init)) /* Startup code from .init-section */
22 | *(.text .text.*) /* remaining code */
23 | *(.gnu.linkonce.t.*)
24 | *(.glue_7)
25 | *(.glue_7t)
26 | *(.gcc_except_table)
27 | *(.rodata) /* read-only data (constants) */
28 | *(.rodata*)
29 | *(.gnu.linkonce.r.*)
30 | } > RAM
31 |
32 | /***** old:
33 | .text :
34 | {
35 | *crt0.o (.text)
36 | *(.text)
37 | *(.rodata)
38 | *(.rodata*)
39 | *(.glue_7)
40 | *(.glue_7t)
41 | } > ROM
42 | *****/
43 |
44 | . = ALIGN(4);
45 |
46 | /* .ctors .dtors are used for c++ constructors/destructors */
47 | /* added by Martin Thomas 4/2005 based on Anglia Design example */
48 | .ctors :
49 | {
50 | PROVIDE(__ctors_start__ = .);
51 | KEEP(*(SORT(.ctors.*)))
52 | KEEP(*(.ctors))
53 | PROVIDE(__ctors_end__ = .);
54 | } >RAM
55 |
56 | .dtors :
57 | {
58 | PROVIDE(__dtors_start__ = .);
59 | KEEP(*(SORT(.dtors.*)))
60 | KEEP(*(.dtors))
61 | PROVIDE(__dtors_end__ = .);
62 | } >RAM
63 |
64 | . = ALIGN(4);
65 | /* mthomas - end */
66 |
67 | _etext = . ;
68 | PROVIDE (etext = .);
69 |
70 | /* .data section which is used for initialized data */
71 | .data : AT (_etext)
72 | {
73 | _data = .;
74 | *(.data)
75 | *(.data.*)
76 | *(.gnu.linkonce.d*)
77 | SORT(CONSTRUCTORS) /* mt 4/2005 */
78 | . = ALIGN(4);
79 | *(.fastrun) /* !!!! "RAM-Function" example */
80 | } > RAM
81 |
82 | . = ALIGN(4);
83 | _edata = . ;
84 | PROVIDE (edata = .);
85 |
86 | /* .bss section which is used for uninitialized data */
87 | .bss (NOLOAD) :
88 | {
89 | __bss_start = . ;
90 | __bss_start__ = . ;
91 | *(.bss)
92 | *(.gnu.linkonce.b*)
93 | *(COMMON)
94 | . = ALIGN(4);
95 | } > RAM
96 |
97 | . = ALIGN(4);
98 | __bss_end__ = . ;
99 | PROVIDE (__bss_end = .);
100 |
101 | .stack ALIGN(256) :
102 | {
103 | . += STACK_SIZE;
104 | PROVIDE (_stack = .);
105 | } > RAM
106 |
107 | _end = . ;
108 | PROVIDE (end = .);
109 |
110 | /* Stabs debugging sections. */
111 | .stab 0 : { *(.stab) }
112 | .stabstr 0 : { *(.stabstr) }
113 | .stab.excl 0 : { *(.stab.excl) }
114 | .stab.exclstr 0 : { *(.stab.exclstr) }
115 | .stab.index 0 : { *(.stab.index) }
116 | .stab.indexstr 0 : { *(.stab.indexstr) }
117 | .comment 0 : { *(.comment) }
118 | /* DWARF debug sections.
119 | Symbols in the DWARF debugging sections are relative to the beginning
120 | of the section so we begin them at 0. */
121 | /* DWARF 1 */
122 | .debug 0 : { *(.debug) }
123 | .line 0 : { *(.line) }
124 | /* GNU DWARF 1 extensions */
125 | .debug_srcinfo 0 : { *(.debug_srcinfo) }
126 | .debug_sfnames 0 : { *(.debug_sfnames) }
127 | /* DWARF 1.1 and DWARF 2 */
128 | .debug_aranges 0 : { *(.debug_aranges) }
129 | .debug_pubnames 0 : { *(.debug_pubnames) }
130 | /* DWARF 2 */
131 | .debug_info 0 : { *(.debug_info .gnu.linkonce.wi.*) }
132 | .debug_abbrev 0 : { *(.debug_abbrev) }
133 | .debug_line 0 : { *(.debug_line) }
134 | .debug_frame 0 : { *(.debug_frame) }
135 | .debug_str 0 : { *(.debug_str) }
136 | .debug_loc 0 : { *(.debug_loc) }
137 | .debug_macinfo 0 : { *(.debug_macinfo) }
138 | /* SGI/MIPS DWARF 2 extensions */
139 | .debug_weaknames 0 : { *(.debug_weaknames) }
140 | .debug_funcnames 0 : { *(.debug_funcnames) }
141 | .debug_typenames 0 : { *(.debug_typenames) }
142 | .debug_varnames 0 : { *(.debug_varnames) }
143 | }
