1 | //ICC-AVR application builder : 13.04.2010 16:15:44
2 | // Target : m48
3 | // Crystal: 8.0000Mhz
4 |
5 | #include <iom48v.h>
6 | #include <macros.h>
7 |
8 |
9 | unsigned int RulInt = 9;
10 | unsigned int WarnInt = 49;
11 |
12 | unsigned int f_1sec;
13 | unsigned char f_100ms;
14 |
15 |
16 | //------------------------------------------------------------------------------
17 | // Port-Zuweisung
18 | //------------------------------------------------------------------------------
19 |
20 | /* PORT B */
21 | //#define PB7
22 | //#define PB6
23 | #define jump2 PB5
24 | #define jump1 PB4
25 | #define servo3 PB3
26 | #define servo2 PB2
27 | #define servo1 PB1
28 | #define pin_taster PB0
29 |
30 | /* PORT C */
31 | #define poti1 PC7
32 | #define reset PC6
33 | #define pinnchen PC5
34 | //#define PC4
35 | //#define PC3
36 | #define sound1 PC2
37 | #define poti3 PC1
38 | #define poti2 PC0
39 |
40 | /* PORT D */
41 | #define ziel_led PD7
42 | #define pump1 PD6
43 | #define pump2 PD5
44 | #define R_LED4 PD4
45 | #define R_LED3 PD3
46 | #define R_LED2 PD2
47 | #define sound2 PD1
48 | #define R_LED1 PD0
49 |
50 |
51 |
52 | void port_init(void)
53 | {
54 | PORTB = 0xF1;
55 | DDRB = 0x0E;
56 | PORTC = 0x43;
57 | DDRC = 0xBC;
58 | PORTD = 0x00;
59 | DDRD = 0xFF;
60 | }
61 | //TIMER1 initialize - prescale:64
62 | // WGM: 0) Normal, TOP=0xFFFF
63 | // desired value: 100mSec
64 | // actual value: 100,000mSec (0,0%)
65 | void timer1_init(void)
66 | {
67 | TCCR1B = 0x00; //stop
68 | TCNT1H = 0xCF; //setup
69 | TCNT1L = 0x2C;
70 | OCR1AH = 0x30;
71 | OCR1AL = 0xD4;
72 | OCR1BH = 0x30;
73 | OCR1BL = 0xD4;
74 | ICR1H = 0x30;
75 | ICR1L = 0xD4;
76 | TCCR1A = 0x00;
77 | TCCR1B = 0x03; //start Timer
78 | }
79 | #pragma interrupt_handler timer1_ovf_isr:iv_TIM1_OVF
80 | void timer1_ovf_isr(void)
81 | {
82 | static unsigned int t1;
83 | //TIMER1 has overflowed
84 | TCNT1H = 0xCF; //reload counter high value
85 | TCNT1L = 0x2C; //reload counter low value
86 | if(t1) {t1=9; f_1sec=1;}
87 | else --t1;
88 |
89 | }
90 |
91 |
92 | //----------------------------------------------------------------------------//
93 | // Servo
94 | //----------------------------------------------------------------------------//
95 |
96 | // Bei dieser Funktion werden jeweils 2000x 10usec gezählt um 20milisec für das PPM-Signal zu erzeugen.
97 |
98 | volatile unsigned char servo1pos; //(98,7 =1msec bis 197,5 = 2msec)
99 | volatile unsigned char servo2pos; //(98,7 =1msec bis 197,5 = 2msec)
100 | volatile unsigned char servo3pos; //(98,7 =1msec bis 197,5 = 2msec)
101 |
102 | void servoweg(void)
103 | {
104 | static int count1;
105 | static int count2;
106 | static int count3;
107 | //----Servo 1-----------------------------------------------------------------//
108 |
109 | if(count1>servo1pos) {PORTB &= ~(1<<servo1);}
110 | else PORTB|=(1<<servo1);
111 |
112 | if(count1<2000+servo1pos)count1++;
113 | else count1=0;
114 | //----Servo 2-----------------------------------------------------------------//
115 |
116 | servo2pos = 20;
117 | if(count2>servo2pos) {PORTB&=~(1<<servo2);}
118 | else PORTB|=(1<<servo2);
119 |
120 | if(count2<2000+servo2pos)count2++;
121 | else count2=0;
122 | //----Servo 3-----------------------------------------------------------------//
123 |
124 | if(count3>servo3pos)PORTB&=~(1<<servo3);
125 | else PORTB|=(1<<servo3);
126 |
127 | if(count3<2000+servo3pos)count3++;
128 | else count3=0;
129 |
130 |
131 | }
132 |
133 | //TIMER2 initialize - prescale:1
134 | // WGM: Normal
135 | // desired value: 10uSec
136 | // actual value: 10,000uSec (0,0%)
137 | void timer2_init(void)
138 | {
139 | TCCR2B = 0x00; //stop
140 | ASSR = 0x00; //set async mode
141 | TCNT2 = 0xB0; //setup
142 | OCR2A = 0x50;
143 | OCR2B = 0x00;
144 | TCCR2A = 0x00;
145 | TCCR2B = 0x01; //start
146 | }
147 | #pragma interrupt_handler timer2_ovf_isr:iv_TIM2_OVF
148 | void timer2_ovf_isr(void)
149 | {
150 | static unsigned int t2;
151 | TCNT2 = 0xB0; //reload counter value
152 |
153 | //servoweg(); //HIER IST DER ÜBELTÄTER
154 |
155 | if(t2) {t2=9; f_100ms=1;}
156 | else --t2;
157 | }
158 | //ADC initialize
159 | // Conversion time: 6uS
160 | void adc_init(void)
161 | {
162 | ADCSRA = 0x00; //disable adc
163 | ADMUX = 0x00; //select adc input 0
164 | ACSR = 0x80;
165 | ADCSRB = 0x00;
166 | ADCSRA = 0x01;
167 | }
168 |
169 | unsigned char taster = 0;
170 | //----------------------------------------------------------------------------//
171 | // Tasterabfrage
172 | //----------------------------------------------------------------------------//
173 | void funkt_tast(void)
174 | {
175 | static char rw = 0;
176 | if(taster == 0 && !(PINB & (1<<pin_taster))) //Taster wird gedrueckt (steigende Flanke)
177 | {
178 | taster = 1;
179 | rw = 1;
180 | }
181 | else if (taster == 1 && !(PINB & (1<<pin_taster))) //Taster wird gehalten
182 | {
183 | taster = 2;
184 | rw = 0;
185 | }
186 | else if (taster == 2 && (PINB & (1<<pin_taster))) //Taster wird losgelassen (fallende Flanke)
187 | {
188 | taster = 3;
189 | rw = 0;
190 | }
191 | else if (taster == 3 && (PINB & (1<<pin_taster))) //Taster losgelassen
192 | {
193 | taster = 0;
194 | rw = 0;
195 | }
196 |
197 |
198 |
199 | }
200 | unsigned char i = 0;
201 |
202 | unsigned int result;
203 | unsigned int poti_1;
204 | unsigned int poti_2;
205 | unsigned int poti_3;
206 | unsigned int batt;
207 |
208 |
209 | //----------------------------------------------------------------------------//
210 | // AD-Wandlung
211 | //----------------------------------------------------------------------------//
212 | void ad(void)
213 | {
214 | // Dummy-Readout
215 | ADCSRA = (1<<ADEN) | (1<<ADPS2) | (1<<ADPS1); // ADC aktivieren, Frequenzvorteiler: setzen auf 64 (8 MHz / 64 = 125 kHz) und ADC aktivieren
216 | ADMUX |= (1<<REFS0) | (1<<REFS1); // interne Referenzspannung nutzen
217 | ADCSRA |= (1<<ADSC); // eine ADC-Wandlung
218 | while(!(ADCSRA & (1<<ADIF))); // auf Abschluss der Konvertierung warten (ADIF-bit)
219 | result = ADC; // ADC muss einmal gelesen werden,
220 | // sonst wird Ergebnis der nächsten Wandlung
221 | // nicht übernommen.
222 |
223 | //ADC-Messung mit arithmetischen Mittel aus 4 Messungen
224 | result = 0;
225 | for (i=0;i<4;i++)
226 | {
227 | ADCSRA |= (1<<ADSC); // Messung ausfuehren
228 | while ( ADCSRA & (1<<ADSC) ); // Konvertierung abwarten
229 | result += ADC; // aufaddieren zur Mittelwertbildung (ADC auslesen der zwei Bits
230 | }
231 | ADCSRA &= ~(1<<ADEN); // ADC ausschalten
232 |
233 | result /= 4; //
234 |
235 |
236 | }
237 |
238 | //----------------------------------------------------------------------------//
239 | // AD-Wandlung für Poti 1-3 und Batterie
240 | //----------------------------------------------------------------------------//
241 | void adc(void)
242 | {
243 | //Poti 1
244 | ADMUX = 0x00;// Kanal waehlen (ADC0)
245 | ad();
246 | result /= 4;//auf 8 Bit reduzieren
247 | poti_1 = result;
248 | OCR0A = poti_1;
249 | // Poti 2
250 | ADMUX = 0x01;// Kanal waehlen (ADC1)
251 | ad();
252 | result /= 4;//auf 8 Bit reduzieren
253 | poti_2 = result;
254 | OCR0B = poti_2;
255 | //Poti 3
256 | ADMUX = 0x07;// Kanal waehlen (ADC7)
257 | ad();
258 | result /= 4;//auf 8 Bit reduzieren
259 | poti_3 = result;
260 | OCR0A = poti_3;
261 |
262 | //Batteriespannung
263 | ADMUX = 0x02;// Kanal waehlen (ADC2)
264 | ad();
265 | batt = result;
266 |
267 |
268 |
269 | }
270 |
271 |
272 | //----------------------------------------------------------------------------//
273 | // Akkuwarnung
274 | //----------------------------------------------------------------------------//
275 |
276 | void warn(void)
277 | {
278 | static unsigned int delay;
279 | if (delay>WarnInt)
280 | {
281 | delay=0;
282 | adc();
283 | if (poti_3>40)//if (batt < 500) Momentan noch auf einem Poti gelegt
284 | {PORTC ^= (1<<pinnchen);}
285 | else {PORTC |= (1<<pinnchen);}
286 | }
287 | else delay++;
288 | }
289 |
290 | //----------------------------------------------------------------------------//
291 | // RundUmLicht
292 | //----------------------------------------------------------------------------//
293 | unsigned char blink_state = 0;
294 | unsigned char countLED = 0;
295 | void rul(void)
296 | {
297 | switch (blink_state)
298 | {
299 |
300 | case 0: // R_LED1 ein
301 | {
302 | PORTD &= ~((1<<R_LED2) | (1<<R_LED3) | (1<<R_LED4));
303 | PORTD |= (1<<R_LED1);
304 | break;
305 | }
306 | case 1: // R_LED2 ein
307 | {
308 | PORTD &= ~((1<<R_LED1) | (1<<R_LED3) | (1<<R_LED4));
309 | PORTD |= (1<<R_LED2);
310 | break;
311 | }
312 | case 2: // R_LED3 ein
313 | {
314 | PORTD &= ~((1<<R_LED1) | (1<<R_LED2) | (1<<R_LED4));
315 | PORTD |= (1<<R_LED3);
316 | break;
317 | }
318 | case 3: // R_LED4 ein
319 | {
320 | PORTD &= ~((1<<R_LED1) | (1<<R_LED2) | (1<<R_LED3));
321 | PORTD |= (1<<R_LED4);
322 | break;
323 | }
324 | }
325 | countLED++;
326 | if (countLED>RulInt) //Hier stellt man die Drehzahl der Rundumleuchte ein
327 | {
328 | countLED=0;
329 | blink_state++;
330 | }
331 | if (blink_state>3) {blink_state=0; // Lauflicht neustarten
332 | }
333 | }
334 |
335 |
336 | ////////////////////////////////////////////////////////////////////////////////
337 | // Hauptprogramm
338 | ////////////////////////////////////////////////////////////////////////////////
339 | void main(void)
340 | {
341 | //stop errant interrupts until set up
342 | CLI(); //disable all interrupts
343 | port_init();
344 | timer1_init();
345 | timer2_init();
346 | adc_init();
347 |
348 | MCUCR = 0x00;
349 | EICRA = 0x00; //extended ext ints
350 | EIMSK = 0x00;
351 |
352 | TIMSK0 = 0x00; //timer 0 interrupt sources
353 | TIMSK1 = 0x01; //timer 1 interrupt sources
354 | TIMSK2 = 0x01; //timer 2 interrupt sources
355 |
356 | PCMSK0 = 0x00; //pin change mask 0
357 | PCMSK1 = 0x00; //pin change mask 1
358 | PCMSK2 = 0x00; //pin change mask 2
359 | PCICR = 0x00; //pin change enable
360 | PRR = 0x00; //power controller
361 | SEI(); //re-enable interrupts
362 | //all peripherals are now initialized
363 |
364 | while(1)
365 | {
366 | if(f_1sec)
367 | {
368 | f_1sec=0;
369 | rul(); // RundUmLicht
370 | }
371 | if(f_100ms)
372 | {
373 | f_100ms=0;
374 | adc(); // AD-Wandlung aller 4 Kanäle (3x Poti, 1x Batteriespannung)
375 | warn(); // Unterspannungswarnung
376 | funkt_tast(); // Taster
377 | if (taster == 1) PORTD |= (1<<ziel_led); // LED an
378 | if (taster == 0) PORTD &= ~(1<<ziel_led);// LED aus
379 | }
380 | }return;
381 | }
