1 | /********************************************************************/
2 | /* */
3 | /* 1LED 1Taster - Entprellung (bessere Version */
4 | /* */
5 | /* active-low: ein Anschluss an den Port-Pin, der anderer an GND */
6 | /* Pull-Up Widerstand (10k) zwischen Port-Pin und VCC. */
7 | /* */
8 | /* PB0: Taster */
9 | /* PD0: LED */
10 | /* */
11 | /* Datum: 10.10.2010 */
12 | /* */
13 | /********************************************************************/
14 |
15 | #include <stdint.h>
16 | #include <avr/io.h>
17 | #include <avr/interrupt.h>
18 |
19 | #ifndef F_CPU
20 | #define F_CPU 1000000
21 | #endif
22 |
23 | #define KEY_DDR DDRB
24 | #define KEY_PORT PORTB
25 | #define KEY_PIN PINB
26 | #define KEY0 0
27 | #define KEY1 1
28 | #define KEY2 2
29 | #define ALL_KEYS (1<<KEY0 | 1<<KEY1 | 1<<KEY2)
30 |
31 | #define REPEAT_MASK (1<<KEY1 | 1<<KEY2) // repeat: key1, key2
32 | #define REPEAT_START 50 // after 500ms
33 | #define REPEAT_NEXT 20 // every 200ms
34 |
35 | #define LED_DDR DDRD
36 | #define LED_PORT PORTD
37 | #define LED0 0
38 | #define LED1 1
39 | #define LED2 2
40 |
41 | volatile uint8_t key_state;
42 | volatile uint8_t key_press;
43 | volatile uint8_t key_rpt;
44 |
45 |
46 | ISR( TIMER0_OVF_vect ) { // every 10ms
47 | static uint8_t ct0, ct1, rpt;
48 | uint8_t i;
49 |
50 | TCNT0 = (uint8_t)(uint16_t)-(F_CPU / 1024 * 10e-3 + 0.5); // preload for 10ms
51 |
52 | i = key_state ^ ~KEY_PIN; // Key changed?
53 | ct0 = ~( ct0 & i ); // reset or count ct0
54 | ct1 = ct0 ^ ( ct1 & i); // reset or count ct1
55 | i &= ct0 & ct1;
56 | key_state ^= i;
57 | key_press |= key_state & i;
58 |
59 | if( (key_state & REPEAT_MASK) == 0 )
60 | rpt = REPEAT_START;
61 | if( --rpt == 0 ) {
62 | rpt = REPEAT_NEXT; // repeat delay
63 | key_rpt |= key_state & REPEAT_MASK;
64 | }
65 | }
66 |
67 |
68 | // Pr¸fe ob eine Taste gedruekt wurde. Jeder Druck wird als eins gewertet
69 | uint8_t get_key_press( uint8_t key_mask ) {
70 | cli();
71 | key_mask &= key_press;
72 | key_press ^= key_mask;
73 | sei();
74 | return key_mask;
75 | }
76 |
77 | // Pr¸fe ob eine Taste lange genug gedr¸ckt wurde
78 | uint8_t get_key_rpt( uint8_t key_mask ) {
79 | cli();
80 | key_mask &= key_rpt;
81 | key_rpt ^= key_mask;
82 | sei();
83 | return key_mask;
84 | }
85 |
86 | // Pr¸fe ob eine Taste kurz gedr¸ckt wurde
87 | uint8_t get_key_short( uint8_t key_mask ) {
88 | cli();
89 | return get_key_press( ~key_state & key_mask );
90 | }
91 |
92 | // Pr¸fe ob eine Taste lang gedr¸ckt wurde
93 | uint8_t get_key_long( uint8_t key_mask ) {
94 | cli();
95 | return get_key_press( get_key_rpt(key_mask) );
96 | }
97 |
98 |
99 |
100 | int main(void) {
101 | KEY_DDR &= ~ALL_KEYS; // Taste fuer Eingabe
102 | KEY_PORT |= ALL_KEYS; // PULL-UP Widerstand An
103 |
104 |
105 | TCCR0 = (1<<CS02)|(1<<CS00); // durch 1024 dividieren
106 | TIMSK |= 1<<TOIE0; // Timer-Interrupt aktivieren
107 |
108 |
109 | LED_PORT = 0xFF;
110 | LED_DDR = 0xFF;
111 |
112 | sei();
113 |
114 | while(1) {
115 | if( get_key_short( 1<<KEY0 ) )
116 | LED_PORT ^= 1<<LED0;
117 |
118 | if( get_key_long( 1<<KEY0 ) )
119 | LED_PORT ^= 1<<LED1;
120 | }
121 | }
