Forum: Mikrocontroller und Digitale Elektronik Fehler im Programm lauflicht.c
Autor: Andreas Knaup (sulospace)
ich habe gerade folgendes Programm in AVR Studio eingegeben:
 * This program is free software: you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation, either version 3 of the License, or
 * (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this program.  If not, see <http://www.gnu.org/licenses/>.
#include <avr/io.h>
#define F_CPU 1000000
#include <util/delay.h>
#define PORT_ROW PORTD
#define DDR_ROW  DDRD
#define PORT_COL1 PORTC
#define DDR_COL1  DDRC
#define PORT_COL2 PORTB
#define DDR_COL2  DDRB
#define PORT_COL3 PORTD
#define DDR_COL3  DDRD
//  ABCDEF...
//const uint8_t displayText[] = { 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30, 200};
// VISIT WWW.STUDENT-IM-URLAUB.DE
//const uint8_t displayText[] = { 0,0,22,9,19,9,20,0,0,23,23,23,29,19,20,21,4,5,14,20,31,9,13,31,21,18,12,1,21,2,29,4,5,0,0, 200};
  0,0,6,18,15,8,5, // FROHE
  0,23,5,9,8,14,1,3,8,20,5,14, // WEIHNACHTEN
  0,21,14,4, // UND
  0,7,21,20,5,14, // GUTEN
  0,18,21,20,19,3,8, // RUTSCH
  0,9,14,19, // INS
  0,14,5,21,5, // NEUE
  0,10,1,8,18, // JAHR
  0,200 }; // 200 markiert das Ende
const uint8_t charTable[] = {
  0, 0, 0, 0,     // Leerzeichen
  126,9,9,126,    // A
  127,73,73,54,   // B
  62,65,65,65,    // C
  127,65,65,62,   // D
  127,73,73,73,   // E
  127,9,9,1,      // F
  62,65,81,50,    // G
  127,8,8,127,    // H
  0,127,127,0,    // I
  49,65,65,63,    // J
  127,24,38,67,   // K
  127,64,64,64,   // L
  127,6,2,127,    // M
  127,14,48,127,  // N
  127,65,65,127,  // O
  127,9,9,6,      // P
  63,33,49,127,   // Q
  127,25,41,70,   // R
  70,73,73,49,    // S
  1,1,127,1,      // T
  63,64,64,63,    // U
  15,120,48,15,   // V
  127,32,48,127,  // W
  67,44,18,97,    // X
  71,72,72,63,    // Y
  97,89,69,67,    // Z
  0,111,111,0,    // !
  2,97,105,6,     // ?
  96,96,0,0,      // .
  64,32,0,0,      // ,
  12,12,12,12     // -
uint8_t currentColumn=0;
uint8_t columnBuffer[10];
uint8_t  charPosition=0;
uint8_t  stringPosition=0;
// Spalte aktivieren. colNr ist dabei die Spaltennr 0 bis 9
inline void setActiveCol(const uint8_t colNr)
  int8_t maskLo;
  int8_t maskHi;
  if (colNr < 10)
    maskLo = (1 << colNr) & 255;
    maskHi = 0;
    if (colNr > 7)
      maskHi = (1 << (colNr-8)) & 255;
  }else{
  maskLo = 0;
  maskHi = 0;
  PORT_COL1 = maskLo & 63;
  PORT_COL2 = ((maskLo >> 6) &3) | ((maskHi & 1) << 2);
  PORT_COL3 &= ~(1<<7);
  PORT_COL3 |= (maskHi & 2) << 6;
inline void initPorts()
  // LED-Port auf OUT
  DDR_ROW = 255;
  PORT_ROW = 0;
  DDR_COL1 = 255;
  DDR_COL2 = 255;
  DDR_COL3 = 255;
  PORT_COL1 = 255;
  PORT_COL2 = 255;
  PORT_COL3 |= (1<<7);
  // Puffer leeren, damit nicht zunächst
  // wirre Zeichen angezeigt werden.
  columnBuffer[0] = 0;
  columnBuffer[1] = 0;
  columnBuffer[2] = 0;
  columnBuffer[3] = 0;
  columnBuffer[4] = 0;
  columnBuffer[5] = 0;
  columnBuffer[6] = 0;
  columnBuffer[7] = 0;
  columnBuffer[8] = 0;
  columnBuffer[9] = 0;
int main()
  uint8_t n=0;
  initPorts();
  // Endlosschleife
  while (1)
  // Die Bildaufbaugeschwindigkeit ist einfach faul
  // durch diesen Sleep für 1ms zwischen den Frames
  _delay_ms(1);
    setActiveCol(10);
  PORT_ROW &= ~127;
  PORT_ROW |= ~(columnBuffer[currentColumn]) & 127;
    setActiveCol(currentColumn);
    if (++currentColumn > 9)
      currentColumn=0;
      if(++n>13) // Nach jedem 13. Bildaufbau wird das Bild selbst weitergeschoben
    // Spaltenweise weiterkopieren
      for(n=9; n>0; --n)
        columnBuffer[n] = columnBuffer[n-1];
        if (4 == charPosition) // Eine Spalte Zwischenraum zwischen den Buchstaben
        } else {
      // Bitmuster des entsprechenden Buchstabenteils einsetzen
          columnBuffer[0] = charTable[displayText[stringPosition]*4 +charPosition];
      if (++charPosition > 4)
        {  // Es wurde ein ganzer Buchstabe angezeigt --> es folgt der nächste!
          charPosition=0;
          ++stringPosition;
          if (200 == displayText[stringPosition])
            stringPosition=0;
        n=0;
Leider kommt beim Compilieren ein Fehler.
Kann mir jemand den Fehler nennen?
Das Programm habe ich hierher:
http://www.student-im-urlaub.de/?p=244
Autor: Peter (Gast)
und warum zeigst du uns nicht den Fehler?
Autor: g457 (Gast)
Das kann nur Dein Compiler (oder Linker? oder doch der Präprozessor??).
Hierzuworkstation compiliert (und linkt) es einwandfrei und sogar mit
ohne Warnings.
Bei mir kommt:
c:/winavr-20100110/bin/../lib/gcc/avr/4.3.3/../../../../avr/lib/avr4/crt
m8515.o:(.init9+0x0):  undefined reference to `main'
make: *** [Laufschrift.elf] Error 1
Autor: Lehrmann Michael (ubimbo)
Ein genereller Tipp: (nicht böse gemeint)
Der Informationsgehalt deines Postings ist ungefähr:
'Mein Auto Marke VW ist kaputt. Sag mir wo der Fehler liegt ich verrate
dir aber nicht mehr.'
z.B:
-was für einen AVR verwendest du?
-was für (einen) / welche Fehler gibt dir der Compiler zurück.
(Zeilenangaben sind hier im Forum sinnlos)
Ich hoffe du hast es reinkopiert xD =) =) =)
Autor: g457 (Gast)
Zeich mal ∗alles∗
Sorry, aber bin noch ein Frischling.
Hab es reinkopiert.
Hier die Ausgabe:
Build started 1.11.2010 at 11:37:06
avr-gcc  -mmcu=atmega8515 -Wall -gdwarf-2 -Os -std=gnu99 -funsigned-char
-funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT
lauflicht2.o -MF dep/lauflicht2.o.d  -c  ../lauflicht2.c
avr-gcc -mmcu=atmega8515 -Wl,-Map=lauflicht2.map lauflicht2.o     -o
lauflicht2.elf
make: *** [lauflicht2.elf] Error 1
Build failed with 1 errors and 0 warnings...
nutze einen Atmega8515
Autor: g457 (Gast)
Funktiniert hierzuworkstation noch immer. Lösch mal alle temporären
Dateien.
hierzuworkstation?
Jetzt erstmal Mittagessen, danke erstmal.
In welchem Ordner soll ich die Temporären Daten löschen? Von Windows
oder AVR Studio?
Autor: Simon K. (simon) Benutzerseite
Auch wenn du Frischling bist: Mehr Infos!
Womit schreibst du die Programme? Du hast wohl vergessen diese .c Datei
deinem Projekt hinzuzufügen, bzw. die Datei im MAKEFILE anzugeben oder
ähnliches.
Autor: Hc Zimmerer (mizch)
Was auffällt:  in der ersten Fehlermeldung ging's um Laufschrift.elf, im
Mitschnitt der Kompilierung war's lauflicht2.elf, und das hier
eingestellte Programm ist gem. Überschrift lauflicht.c, es müsste also
lauflicht.elf heißen, somit wieder anders.
Welches Programm hast Du hier gezeigt und welches hast Du kompiliert?
Ich hatte einfach noch ein zweites Projekt angelegt, desegen lauflicht
und lauflicht2.
Ich habe ein Projekt in AVR Studio4 angelegt und dort das Programm
reinkopiert.
Hat sonst bei anderen Programmen auch funktioniert.
Nun hat es, warum auch immer funktioniert.
Hab TEmp Ordner mal gelöscht und nochmal ein neues Projekt angelegt.
Dafür wird der Atmega jetzt leider nicht mehr im STK500 erkannt, ich
denke er ist defekt.
