Hallo Bin langsam am Verzweifeln. Bekomme das LCD nicht zum laufen. Ist das jemandem gelungen - mit Assembler ?. Habe solche LCD vor Jahren mit dem 8051 und 80535 zum laufen gebracht jetzt aber kein Erfolg. Das Board geht , LCD mit dem Loader von Deltawave auch. Ersetze ich das Programm mit meinem dann nur dunkel. Auch Versuche Programme aus dem Netz zu benutzen schlagen fehl. Hilfe !!!
Port C (PC7..PC0) Port C is an 8-bit bi-directional I/O port with internal pull-up resistors (selected for each bit). The Port C output buffers have symmetrical drive characteristics with both high sink and source capability. As inputs, Port C pins that are externally pulled low will source current if the pull-up resistors are activated. The Port C pins are tri-stated when a reset condition becomes active, even if the clock is not running. If the JTAG interface is enabled, the pull-up resistors on pins PC5(TDI), PC3(TMS) and PC2(TCK) will be activated even if a reset occurs. The TD0 pin is tri-stated unless TAP states that shift out data are entered. Port C also serves the functions of the JTAG interface and other special features of the ATmega32 as listed on page 60. Zitat: • TDI – Port C, Bit 5 TDI, JTAG Test Data In: Serial input data to be shifted in to the Instruction Register or Data Register (scan chains). When the JTAG interface is enabled, this pin can not be used as an I/O pin. • TDO – Port C, Bit 4 TDO, JTAG Test Data Out: Serial output data from Instruction Register or Data Register. When the JTAG interface is enabled, this pin can not be used as an I/O pin. The TD0 pin is tri-stated unless TAP states that shifts out data are entered. • TMS – Port C, Bit 3 TMS, JTAG Test Mode Select: This pin is used for navigating through the TAP-controller state machine. When the JTAG interface is enabled, this pin can not be used as an I/O pin. • TCK – Port C, Bit 2 TCK, JTAG Test Clock: JTAG operation is synchronous to TCK. When the JTAG interface is enabled, this pin can not be used as an I/O pin. Mit der AVR Debug Funktion sieht man aber (fälschlich) das alles geht und die Pins richtig geschaltet werden. Das stimmt aber nicht.
edi schrieb: > Das Board geht , LCD mit dem Loader von Deltawave auch. > Ersetze ich das Programm mit meinem dann nur dunkel. Dann wird wohl ein Fehler im Programm vorliegen
Hi >When the JTAG interface is enabled, this pin can not be used as an I/O pin. Ist dein JTAG-Interface disabled? MfG Spess
Danke spess53 für die Antwort - bin edi = edi1s nach Anmeldung. Ich vermute daß es enabled ist. Werde gugen ob ich es einfach mit AVR Studio ändern kann. Schleierhaft: Mit dem Deltawave Soft wird LCD angesteuert - kann man alle Fuse mit Soft ändern ??
Hi >Schleierhaft: Mit dem Deltawave Soft wird LCD angesteuert - kann man >alle Fuse mit Soft ändern ?? Nein. Aber das JTAG-Interface lässt sich per Software abschalten. Ansonsten im AVR-Studio bei den FUSES Häkchen entfernen und Fuses neu programmieren. MfG Spess
Eduard S... schrieb: > Danke spess53 für die Antwort - bin edi = edi1s nach Anmeldung. Und ich dachte schon, der erste Antworter hätte ins blaue geraten :-) Ist denn dein LCD am Port C angeschlossen? > Ich vermute daß es enabled ist. vermuten ist immer schlecht. Im Regelfall sieht man einfach nach. > Werde gugen ob ich es einfach mit AVR Studio ändern kann. Das kann man. > Schleierhaft: Mit dem Deltawave Soft wird LCD angesteuert - kann man > alle Fuse mit Soft ändern ?? Alle nicht. Aber diese kann tatsächlich per Software überschrieben werden. Auf lange Sicht ist es aber besser, JTAG ganz einfach abzuschalten. Denn dann hast du deine Ruhe.
Danke Dir auch - Karl heinz Buchegger Es ist am Port C angeschlossen. Ich kann das mit dem Jtag jetzt nicht nachschauen - bin weg von dem ganzen, aber morgen mit der neuen Hoffnung ... Jtag werde ich mit AVR abschalten , sonst wenn ich das in einem Programm vergesse, dann wieder .... Danke nochmal, werde ev. über den fälligen Erfolg berichten.
Und Erolg Bits kann man nicht mit AVR Studio (oder bin ich blind?) sondern nur mit PonyProg auslesen und verändern. JtagEN enthackt. Eigentlich sofort danach gelaufen. Danke
Hi >Bits kann man nicht mit AVR Studio (oder bin ich blind?) sondern nur >mit PonyProg auslesen und verändern. Wenn einen AVR-Studio kompatiblen Programmer hast, ist das kein Problem. MfG Spess
