1 | Hello Yong Zhou,
2 |
3 | thank you for your quick answer. As I was abroad this week, I could not follow your advices before today.
4 |
5 | First of all: I followed all steps through your answer and finally could
6 | recover my JTAGICE mkII: Everthing is fine now. :-)
7 |
8 | To give as much feedback as possble, I just tell in detail what happened,
9 | maybe this can help in similar cases:
10 |
11 | > 1. If you use USB connection, please confirm that the USB port is capable
12 | > of supplying 500mA current.
13 |
14 | My laptop is a Lenovo Thinkpad T61p, which should comply to the USB-standards. As I have no USB-cable available which I could cut for the purpose of measuring the current, I did the following:
15 |
16 | - I Installed a fresh Windows XP on a Dell inspiron 8200, to test with a
17 | serial connection (my current Lenovo does not have a serial interface).
18 |
19 | - I installed the complete AVR-Studio software V4.18, build 716 and the SP3 package.
20 |
21 | - I connected the JTAGICE-MK-II with the serial cable which was supplied with my JTAGICE.
22 |
23 | - I powered the JTAGICE with a power-supply from my lab. Voltage was set to 13.0 Volts. Ground was connected to the center-wire of the power-plug which was supplied with my JTAGICE.
24 |
25 | - I powered on the JTAGICE. current reading was about 150 mA.
26 |
27 | - the LEDs showed up as described in my last email: LED #2 was red, LED #3 was yellow. No other lights on.
28 |
29 | - I opened the connect dialog from AVR-studio and tried 'connect' with 'AUTO' setting, baudrate set to 115000.
30 |
31 | - I could see the JTAGICE switching off the yellow LED for 1-2 seconds. After that, the LED went back to 'on' state, yellow color.
32 |
33 | - the AVR Studio popped up again, stating "Connect failed - Select AVR
34 | Programmer"
35 |
36 | - I repeated this procedure with all baud settings down to 19200
37 |
38 | - during all probes, the current did never exceed 140 mA (though the metering of the power supply does not exactly happen in real-time)
39 |
40 | > 2. Did the JTAGICE mkII USB driver works well? Check it in Windows PC
41 | > "Device Manager", if it's recognized as "JTAGICE mkII".
42 |
43 | Yes. On the fresh installed Dell Laptop, I tried USB as well (it has USB 1.1). After switching on the JTAGICE, Windows issued an acoustic signal to indicate that a new USB device was detected.
44 |
45 | In Windows devicemanager, I could see the 'JUNGO' drivers 'JTAGICE-mkII' and 'WinDriver' '
46 |
47 | > 3. Are there any error messages when the issue happened? Send us the
48 | > screenshot of the error message if possible.
49 |
50 | The only error message to see was the one described above. A screenshot is
51 | attached.
52 |
53 | > 4. Try to update the firmware of JTAGICE mkII by the instructions in
54 | > "JTAGICE mkII User Guide --> Firmware Upgrade".
55 |
56 | Yes, I did this before on my Lenovo, it didn't work. But after your mail, I tried this with the Dell via the serial interface and with the external power supply, and then it worked.
57 |
58 | I thank you very much for your fast and competent answer. Though they were no real new things to consider, it finally led me to a new installation and the check with the serial interface.
59 |
60 | Thank you again,
61 |
62 | good bye and all the best!
63 | ...
