bekomme Diese Fehlermeldung wer kann mir helfen > "make.exe" all set -e; avr-gcc -MM -mmcu=atmega32 -I. -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=main.lst -std=gnu99 -DVERSION_HAUPTVERSION=1 -DVERSION_NEBENVERSION=0 -DF_CPU=16000000 main.c \ | sed 's,\(.*\)\.o[ :]*,\1.o \1.d : ,g' > main.d; \ [ -s main.d ] || rm -f main.d -------- begin -------- avr-gcc (WinAVR 20100110) 4.3.3 Copyright (C) 2008 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. Compiling: main.c avr-gcc -c -mmcu=atmega32 -I. -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=main.lst -std=gnu99 -DVERSION_HAUPTVERSION=1 -DVERSION_NEBENVERSION=0 -DF_CPU=16000000 main.c -o main.o Linking: FTM1_3.elf avr-gcc -mmcu=atmega32 -I. -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=main.o -std=gnu99 -DVERSION_HAUPTVERSION=1 -DVERSION_NEBENVERSION=0 -DF_CPU=16000000 main.o --output FTM1_3.elf -Wl, -Map=FTM1_3.map,--cref -lm c:/winavr-20100110/bin/../lib/gcc/avr/4.3.3/../../../../avr/bin/ld.exe: : No such file: No such file or directory avr-gcc: unrecognized option '-Map=FTM1_3.map,--cref' make.exe: *** [FTM1_3.elf] Error 1 > Process Exit Code: 2 > Time Taken: 00:01
Hallo, hast du das Makefile mit den "MFile [WinAVR]" von WinAVR erstellt? Sieht so aus als ob dem Linker die Option mit den .map File nicht schmeckt. Gruß Reini
DJ Tessa schrieb: > c:/winavr-20100110/bin/../lib/gcc/avr/4.3.3/../../../../avr/bin/ld.exe: > : No such file: No such file or directory Die ld.exe wird nicht gefunden.
