Forum: Mikrocontroller und Digitale Elektronik RC5 mit Assembler
Autor: M. H. (bambel2)
Hallo Leute.
Ich habe mir mal ein paar Projekte mit RC5-Dekodierung im Internet
angeschaut. Habe mir jetzt mal folgenden Code für den atmega 8515
zusammegebastelt. Aber es funktioniert nicht. Die fertige routine von
Atmel liefert immer 0xFF zurück (Fehler)
Was mache ich falsch??
Gruß M.H.
Der Code:
.include <m8515def.inc>
.equ  INPUT    =0  ;PD2
.equ  SYS_ADDR  =0  ;The system address
.def  S  =R0
.def  inttemp  =R1
.def  ref1  =R2
.def  ref2  =R3
.def  temp  =R16
.def  timerL  =R17
.def  timerH  =R16
.def  system  =R19
.def  command  =R20
.def  bitcnt  =R21
.cseg
.org $00
rjmp reset
.org OVF0addr
TIM0_OVF:  in  S,sreg
    inc  timerL    ;Updated every 64us
    inc  inttemp
    brne  TIM0_OVF_exit
    inc  timerH
TIM0_OVF_exit:  out  sreg,S
    reti
reset:
ldi r16, low(RAMEND)
ldi r17, high(RAMEND)
out spl, r16
out sph, r17
;ldi    temp,low(RAMEND)  ;Initialize stackpointer
    ;out  SPL,temp
    ;ldi    temp,high(RAMEND)  ; Commented out since 1200 does not hae SRAM
    ;out  SPH,temp
    ldi  temp,1    ;Timer/Counter 0 clocked at CK
    out  TCCR0,temp
    ldi  temp,(1<<TOIE0)  ;Enable Timer0 overflow interrupt
    out  TIMSK,temp
    ldi temp, 0
    out ddrd, temp
  ldi r16, 255
  out ddrb, r16
out portd, r16
    sei
        ;Enable gobal interrupt
start:
rcall detect
and command, system
cpi command, 0xff
breq o
sbi portb, 0
rjmp start
o:
cbi portb, 0
rjmp start
detect:
clr  inttemp
    clr  timerH
detect1:  clr  timerL
detect2:  cpi  timerH,8  ;If line not idle within 131ms
    brlo  dl1
    rjmp  fault    ;  then exit
dl1:    cpi  timerL,55  ;If line low for 3.5ms
    brge  start1    ;   then wait for start bit
    sbis  PIND,INPUT  ;If line is
    rjmp  detect1    ;   low  - jump to detect1
    rjmp  detect2    ;   high - jump to detect2
start1:    cpi  timerH,8  ;If no start bit detected
    brge  fault    ;within 130ms then exit
    sbic  PIND,INPUT  ;Wait for start bit
    rjmp  start1
    clr  timerL    ;Measure length of start bit
start2:    cpi  timerL,17  ;If startbit longer than 1.1ms,
    brge  fault    ;   exit
    sbis  PIND,INPUT
    rjmp  start2
          ;Positive edge of 1st start bit
    mov  temp,timerL  ;timer is 1/2 bit time
    clr  timerL
    mov  ref1,temp
    lsr  ref1
    mov  ref2,ref1
    add  ref1,temp  ;ref1 = 3/4 bit time
    lsl  temp
    add  ref2,temp  ;ref2 = 5/4 bit time
start3:    cp  timerL,ref1  ;If high periode St2 > 3/4 bit time
    brge  fault    ;   exit
    sbic  PIND,INPUT  ;Wait for falling edge start bit 2
    rjmp  start3
    clr  timerL
    ldi  bitcnt,12  ;Receive 12 bits
    clr  command
    clr  system
sample:    cp  timerL,ref1  ;Sample INPUT at 1/4 bit time
    brlo  sample
    sbic  PIND,INPUT
    rjmp  bit_is_a_1  ;Jump if line high
bit_is_a_0:  clc      ;Store a '0'
    rol  command
    rol  system
          ;Synchronize timing
bit_is_a_0a:  cp  timerL,ref2  ;If no edge within 3/4 bit time
    brge  fault    ;   exit
    sbis  PIND,INPUT  ;Wait for rising edge
    rjmp  bit_is_a_0a  ;in the middle of the bit
    clr  timerL
    rjmp  nextbit
bit_is_a_1:  sec      ;Store a '1'
    rol  command
    rol  system
          ;Synchronize timing
bit_is_a_1a:  cp  timerL,ref2  ;If no edge within 3/4 bit time
    brge  fault    ;   exit
    rjmp  bit_is_a_1a  ;in the middle of the bit
    clr  timerL
nextbit:  dec  bitcnt    ;If bitcnt > 0
    brne  sample    ;   get next bit
;All bits sucessfully received!
    mov  temp,command  ;Place system bits in "system"
    rol  temp
    rol  system
    rol  temp
    rol  system
    bst  system,5  ;Move toggle bit
    bld  command,6  ;to "command"
          ;Clear remaining bits
    andi  command,0b01111111
    andi  system,0x1F
    ret
fault:    ser  command    ;Both "command" and "system"
    ser  system    ;0xFF indicates failure
    ret
.exit
Autor: Stulle (Gast)
Die MCU in der  Atmel App. läuft mit 4Mhz Taktfrequenz !
also alle 64µsec. ein Interupt , nochmal alles überprf.
oder deine Fernbedienung ist keine RC5
mfg
Autor: Spess53 (Gast)
Hi
Und dein Controller läuft auch mit 4MHz?
MfG Spess
Sorry:
Ich hab vergessen zu sagen, dass er mit 4 MHz ext. quarz läuft.
Hab mehrere Fernbedienungen versucht.
ach, noch was: wenn kein signal reinkommt, liegt der Output vom
empfänger auf high. Ist das normal?
Gruß M.H.
Autor: Stefan B. (stefan) Benutzerseite
Als ich das damals mit dem TSOP1736 auf dem Pollin-Funk-Board in C
(Artikelsammlung) gemacht hatte, war es so. Dein Programmcode mit
eingeschaltetem Pullup-Widerstand an PD2 deutet auch darauf hin. Um
deine Frage exakt zu beantworten, müsste man wissen, welchen Empfänger
du benutzt und wie der angeschlossen ist.
