Hi everyone, i got a problem using a matrix in vhdl. I have a 5x8 matrix (5 x std_logic_vector). this matrix can be modified by user. the user can choose a row and give a decimal number. the decimal number will be converted into std_logic_vetor. for example: data from user: row 2 = 34 --> matrix[2] = "00100010" i need to make a check every time when new data are entered. with this check i want to make sure that every column in the matrix doesn't have more than one '1'. for example see this 5x8 matrix: row 1 00101000 2 01000001 3 10000100 4 10001000 --unacceptable:matrix[4][0] = '1' as well as matrix[3][0] 5 00010000 -- just like matrix[4][4] and matrix[1][4] how can i solve this? any idea? thanks in advance for any help. flex
Hi flex. You could XOR all the bits in each column, so you will get eigth bits as result. Then you could AND this eigth bits, if the result is '1', each column contains only one '1' I think.
flex schrieb: > with this check i want to make sure that every column in the matrix > doesn't have more than one '1'. Try this:
1 | signal fail : std_logic; |
2 | |
3 | process (matrix) |
4 | signal one : std_logic; |
5 | begin
6 | fail <= '0'; |
7 | for c in 0 to 7 loop |
8 | one := '0'; |
9 | for r in 1 to 5 loop |
10 | if (matrix(r,c)='1') then -- or matric (r)(c) depends on definition of matrix |
11 | if one='1' then |
12 | fail <= '1'; |
13 | -- exit; -- maybe this helps saving ressources
14 | end if; |
15 | one := '1'; |
16 | end if; |
17 | end loop; |
18 | end loop; |
19 | end process; |
BTW: why does the row count of your matrix start with number 1? But what do you want to do, if theres more than one '1'?
thx for ur answers.. to Lothar Miller: - sorry ur right.. the row must start with 0. - and if there's more than one '1' --> do nothing. new row will not be saved in the matrix. i didnt check exactly the code u write. but thers is 2 for loops. that needs a lot of resources. this is my process: process(valid, write, data_in,row) if valid = '1' and row < 5 then if (write = '1') then matrix(row) <= data_in; end if; end if; end process;
no_name schrieb: > i didnt check exactly the code u write. but thers is 2 for loops. > that needs a lot of resources. How du you result in this conclusion? Did you test or try it? > this is my process: Hmmm... You describe a latch (gated by a bunch of signals). This is no good design practice... For writing in the array you should use a clock. Thats the way flipflops inside the FPGA are built: they use a clock to store data.
can this works? control : process(matrix) begin for i in 0 to 7 loop if unsigned(matrix(0 to 7)(i)) > 1 then matrix(0 to 7)(i) <= (others => '0'); end if; end loop; end process control;
I dont think so... Just as a hint: what type is this? matrix(0 to 7)(i) I'm not able to determine it just from the scratch... BTW Even if this process would work, you could trim it this way without any loss of funtionality:
1 | control : process(matrix) |
2 | begin
3 | for i in 0 to 7 loop |
4 | matrix(0 to 7)(i) <= (others => '0'); |
5 | end loop; |
6 | end process control; |
