Forum: Mikrocontroller und Digitale Elektronik Ist der Snapdragon Prozessor eine Cortex A8 Architektur oder hat er ähnlichkeiten zu einem CortexA8?
Autor: ARM (Gast)
Die Wikipedia schreibt dazu:
> Der Prozessorkern des Snapdragon heißt Scorpion und ist vergleichbar mit dem
ARM-Cortex-A8-Kern
Quelle: http://de.wikipedia.org/wiki/Snapdragon_%28Prozessor%29
bzw. auf der englischen WP:
> It has many features similar to those of the ARM Cortex-A8 core and it is based
on the ARM v7 instruction set, but theoretically has much higher performance for
multimedia-related SIMD operations.[
Quelle: http://en.wikipedia.org/wiki/Snapdragon_%28System_on_Chip%29
Ist das überhaupt so richtig?
Ich dachte bisher, daß Cortex A8 die Architektur ist, und der Prozessor
nur eine Implementierung davon ist.
Was stimmt denn nun?
Autor: checksum (Gast)
Although Scorpion and Cortex-A8 have many similarities, based on the information
released by Qualcomm, the two cores differ in a number of interesting ways. For example,
while the Scorpion and Cortex-A8 NEON implementations execute the same SIMD-style
instructions, Scorpion’s implementation can process128 bits of data in parallel, compared to 64
bits on Cortex-A8. Half of Scorpion’s SIMD data path can be shut down to conserve power.
Scorpion’s pipeline is deeper: It has a 13-stage load/store pipeline and two integer pipelines—
one of which is 10 stages and can perform simple arithmetic operations (such as adds and
subtracts) while the other is 12 stages and can perform both simple and more complex
arithmetic, like MACs. Scorpion also has a 23-stage floating-point/SIMD pipeline, and unlike on
Cortex-A8, VFPv3 operations are pipelined. Scorpion uses a number of other microarchitectural
tweaks that are intended to either boost speed or reduce power consumption. (Scorpion’s
architects previously designed low-power, high-performance processors for IBM.)  The core
supports multiple clock and voltage domains to enable additional power savings.
und
Overall, Qualcomm has made a huge investment in creating a custom implementation of the
ARMv7 architecture.
Die haben den Core also abgeaendert / erweitert, sodass sie ihn wohl
nicht mehr A8 nennen wollen.
Quellen sind diese Seiten, da steht noch mehr ;-)
[*]http://www.bdti.com/InsideDSP/2007/11/14/Qualcomm
[*]http://www.eetimes.com/design/signal-processing-ds...
Autor: Marcus Harnisch (mharnisch) Benutzerseite
ARM schrieb im Beitrag #2047598:
Ja
Nein, die Architektur heißt v7-A. Cortex-A8 ist nur eine Implementierung
davon. Genau wie ARM Cortex-A9, ARM Cortex-A5, Marvell PJ4 und eben der
Qualcomm Scorpion core, der in den erwähnten Snapdragon SoC steckt.
Qualcomm hat keinen Cortex-A8 abgeändert, sondern einen eigenen
Prozessor entwickelt. Fachjournalisten bringen das alles aber gerne
durcheinander.
Marcus
