Hallo, ich beschaeftige mich jetzt mit der Umwandlung von BCD in Bin. ich komme klar wie man Bin in Bcd umwandlen kann, aber umgekehrt habe ich keine Ahnung. es waere schoen, wenn ihr da mal reinschauen koenntet um mit Tipps zu geben. hier ist das Programm , die umwandlung bin in BCD : library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity BinzuBCD is Port ( Clk : in STD_LOGIC; Init : in STD_LOGIC; Rst: in STD_LOGIC; ModIn : in STD_LOGIC; ModOut : out STD_LOGIC; Q : out STD_LOGIC_VECTOR (3 downto 0)); end BinzuBCD; architecture Behavioral of BinzuBCD is signal Bcd: STD_LOGIC_VECTOR (3 downto 0); begin process( Clk,Init) begin if rising_edge( Clk) then if Init='1' then Bcd <= "0000"; elsif Rst='0' then case Bcd is when "0000" => Bcd <= "000" & ModIn; -- 0*2 + ModIn when "0001" => Bcd <= "001" & ModIn; -- 1*2 + ModIn when "0010" => Bcd <= "010" & ModIn; -- 2*2 + ModIn when "0011" => Bcd <= "011" & ModIn; -- 3*2 + ModIn when "0100" => Bcd <= "100" & ModIn; -- 4*2 + ModIn when "0101" => Bcd <= "000" & ModIn; -- 5*2 + ModIn (ModOut=1) when "0110" => Bcd <= "001" & ModIn; -- 6*2 + ModIn (ModOut=1) when "0111" => Bcd <= "010" & ModIn; -- 7*2 + ModIn (ModOut=1) when "1000" => Bcd <= "011" & ModIn; -- 8*2 + ModIn (ModOut=1) when "1001" => Bcd <= "100" & ModIn; -- 9*2 + ModIn (ModOut=1) when others => Bcd <= "0000"; end case; end if; end if; end process; ModOut <= '1' when Bcd>=5 else '0'; Q <= Bcd; end Behavioral; library IEEE; use IEEE.std_logic_1164.all; entity BCDwandler is generic (N : integer :=3); port (Clk : in std_logic; Rst : in std_logic; Init : in std_logic; -- initialisierung ModIn : in std_logic; -- carry in ModOut : out std_logic; -- carry out Q : out std_logic_vector(4*N -1 downto 0) -- BCD Ergebnis ); end; architecture arch of BCDwandler is component BinzuBCD is port (Clk : in std_logic; Rst : in std_logic; Init : in std_logic; ModIn : in std_logic; ModOut : out std_logic; Q : out std_logic_vector(3 downto 0) ); end component; signal ModBreite : std_logic_vector(1 to N+1); begin BCDAnzahl : for i in 1 to N generate Rgs: BinzuBCD port map (Clk => Clk, Rst => Rst, Init => Init, ModIn => ModBreite(I+1), ModOut => ModBreite(I), Q => Q(I*4-1 downto I*4-4)); end generate; ModOut <= ModBreite(1); ModBreite(N+1) <= ModIn; end;
Alex Alex schrieb: > ich komme klar wie man Bin in Bcd umwandlen kann, aber umgekehrt habe > ich keine Ahnung. Die Richtung BCD nach Bin ist eigentlich viel einfacher. Z.B. für 4 BCD-Stellen:
1 | use numeric_std.all |
2 | :
3 | port ( |
4 | bcd : in std_logic_vector(15 downto 0); |
5 | bin : out std_logic_vector(15 downto 0) |
6 | );
7 | :
8 | process (bcd) |
9 | variable h : integer; |
10 | begin
11 | h := to_integer(unsigned(bcd_vect(3 downto 0)); |
12 | h := h + to_integer(unsigned(bcd_vect(7 downto 4))*10; |
13 | h := h + to_integer(unsigned(bcd_vect(11 downto 8))*100; |
14 | h := h + to_integer(unsigned(bcd_vect(15 downto 12))*1000; |
15 | result <= std_logic_vector(to_unsigned(h,16)); |
16 | end process; |
> use IEEE.STD_LOGIC_ARITH.ALL; > use IEEE.STD_LOGIC_UNSIGNED.ALL; Vergiss die alten obsoleten Synopsys-Libs am besten schnell wieder, oder fang besser gleich gar nicht damit an. Nimm statt dessen (nicht zusätzlich!!!) die genormte numeric_std.
Du kannst die Berechnung natürlich auch herumdrehen und mit der Tausenderstelle anfangen:
2 | :
3 | port ( |
6 | );
7 | :
8 | process (bcd) |
10 | begin
11 | h := to_integer(unsigned(bcd_vect(15 downto 12)); |
12 | h := h*10 + to_integer(unsigned(bcd_vect(11 downto 8)); |
13 | h := h*10 + to_integer(unsigned(bcd_vect(7 downto 4)); |
14 | h := h*10 + to_integer(unsigned(bcd_vect(3 downto 0)); |
16 | end process; |
Hallo Alex, Fragen, die auch andere irgendwann interessieren könnten, bitte nicht als PM, sondern einfach hier im Thread stellen. Nimms mir nicht übel, wenn ich die Fragen hier beantworte... ;-) > Z.B. für die BCD-Zahl 3927 (Eingabe von 0011 1001 0010 0111)es wurde > erst einer-stelle 0111 mit Hilfe to_integer in 7 umgewandelt und H mit 7 > zugewiesen wurde. 10er-stelle 0010 wurde in 20 (am Ende mal 10) > umgewandelt, H bekommt den wert 20+7. u.w. H bekommt den wert 3927, > wurde dann mit Hilfe to_unsigned in 16bit lang vector umgewandelt. > result ist die umgewandelte binär-Zahl. > habe ich richtig verstanden? Richtig, fast: > es wurde erst einer-stelle 0111 mit Hilfe to_integer in 7 umgewandelt Da wird im FPGA nicht wirklich etwas umgewandelt, es ist eine reine VHDL-Typkonvertierung. Ich könnte das z.B. auch so schreiben:
2 | :
3 | port ( |
6 | );
7 | :
8 | process (bcd) |
9 | variable h : unsigned(15 downto 0); |
10 | begin
11 | h := unsigned(bcd_vect(3 downto 0)); |
12 | h := h + unsigned(bcd_vect(7 downto 4))*10; |
13 | h := h + unsigned(bcd_vect(11 downto 8))*100; |
14 | h := h + unsigned(bcd_vect(15 downto 12))*1000; |
15 | result <= std_logic_vector(h); |
16 | end process; |
Oder sogar so:
2 | :
3 | port ( |
4 | bcd : in unsigned(15 downto 0); |
5 | bin : out unsigned(15 downto 0) |
6 | );
7 | :
8 | process (bcd) |
10 | begin
11 | h := bcd_vect(3 downto 0); |
12 | h := h + bcd_vect(7 downto 4)*10; |
13 | h := h + bcd_vect(11 downto 8)*100; |
14 | h := h + bcd_vect(15 downto 12)*1000; |
15 | result <= h; |
16 | end process; |
Alle diese Lösungen geben genau die selbe Hardware...
> fehlt es doch noch Entity und architecture oder?
Korrekt. Dafür sind die Platzhalter (Doppelpunkte) da.
