Hallo zusammen Ich baue einen kleinen/mittelgrossen Roboter und benütze für die Steuerung einen MAX II von Altera. Damit ich den Print fertigen kann, muss ich wissen wie ich den JTAG an den Chip anschliessen muss. Aus dem Beschrieb werde ich irgendwie nicht schlau:-( . Kann mir jemand mit einer Skizze oder link weiterhelfen, damit ich weiss, wo pull-up/down widerstände reinkommen? Den Chip habe ich noch nicht, aber ich verwende wahrscheinlich einen MAX II EPM240T100C5N. Zum programmieren benutze ich den Byteblaster von Altera.
Hallo, aus einem Lattice-Dokument. http://www.latticesemi.com/lit/docs/ispbs/ispguide.pdf?jsessionid=f0306f5fc75d9df7248c417135155c3a561f " Pin Connections After Programming After programming and testing has been completed, the question often arises, “What should be done with the ISP port signals?” One of the requirements in the IEEE1149.1 standard for the JTAG port is that both the TMS pin and the TDI pin have internal pull-up resistors. By ensuring that there is a ‘1’ on the TMS pin, inadvertent clocking of TCK will not cause the JTAG state machine to leave its reset state. During power-up, inadvertent clocking on TCK can cause the 1149.1 state machine and instruction register to come up in an undesirable state. To increase noise immunity during power-up, the following recommendation is made: • A 4.7KΩ pull-up resistor should be used on the TMS signal and a 4.7KΩ pull-down resistor on the TCK signal on a board. As the number of devices connected to the TCK/TMS signals increases, the pull-up and pull-down resistor values may need to be adjusted as more internal pull-up resistors are affecting those signals. For a chain with 10 devices, the pull-down resistor value on TCK should be 2KΩ. "
Wie wärs mit folgendem Board? http://www.mdfly.com/index.php?main_page=product_info&products_id=425 lg
