Forum: FPGA, VHDL & Co. Was ist das für eine HDL?
von Holm T. (Gast)
Ich möchte einen IDE Adapter an eine olle PDP11 basteln und habe hier
http://www.chdickman.com/qbus_ide/
das hier gefunden:
Name     QBus14 ;
PartNo   00 ;
Date     03/28/2008;
Revision 14 ;
Designer CHD ;
Company  ;
Assembly None ;
Location ;
Device   f1508ispplcc84 ;
/* revisions */
/*  14  Name changed to prevent confusion with previous version 13 series. */
/*    Removed all logic support for DMA. */
/*            Changed interrupt logic to more closely follow DC003 logic */
/*  13  Renewed development.
/*    The contents of the CPLD on the prototype board does not match the .jed file */
/*    generated when version 12 is compiled. The published version 12 has some */
/*    debugging changes that are not shown on a version 11 printout. Revision 13 is */
/*    an attempt to reconstruct the last reasonably functional version as a starting */
/*    point for further efforts. */
23
24
/*   pre 2002 */
25
/*  12  Published version including some debug hooks. */
26
/*  11  Buggy version used to write wd driver for 2.11BSD. */
27
28
29
30
/* PIO Mode Only Adapter */
31
32
/* $define JUMPERS */  /* include logic for address switches */
33
        /*   if not defined, address is hardwired */
34
35
/* editor font: Courier New, Regular, 10 */
36
37
38
39
                               BB
40
41
42
43
              QB  |     |<---+-+------|          |   CTL   |     |
44
              ----|TRANS|      |      |  CPLD    |---------| ATA |
45
                  |     |    TSBUF    |          |         |     |
46
47
48
49
                         BA                |
50
51
52
              QB  |     |                  |
53
              ----|TRANS|------------------+
54
55
56
57
58
59
60
/* Device Selection */
61
62
/* Q22 addressing */
63
64
/* 1   7   7   6   0   0   0   0 */
65
/* 1 111 111 11A AAA AAA BBR RR0 */
66
/*   where A is the variable base CSR address */
67
/*         B is the register bank */
68
/*         R is the register select */
69
70
/* 1 111 111 11A AAA AAA A00 000 CSR - base control register (including DMA address extension) */
71
/* 1 111 111 11A AAA AAA A00 010 CNT - DMA count register - NOT IMPLEMENTED (reserved) */
72
/* 1 111 111 11A AAA AAA A00 100 DMA - DMA address register - NOT IMPLEMENTED (reserved) */
73
/* 1 111 111 11A AAA AAA A00 110 VECT - interupt vector number */
74
/* 1 111 111 11A AAA AAA A01 000 (reserved) */
75
/* 1 111 111 11A AAA AAA A01 010 (reserved) */
76
/* 1 111 111 11A AAA AAA A01 100 CS1 disk controller register */
77
/* 1 111 111 11A AAA AAA A01 110 (reserved) */
78
/* 1 111 111 11A AAA AAA A1X XX0 CS0 disk controller registers */
79
80
/* clock rate: 32MHz *
81
/*                state1 state2 state3 state4 state5   */
82
/* minimum delay     1      2      3      4      5     */
83
/*                  31ns   63ns   94ns  125ns  156ns   */
84
/* maximum delay     2      3      4      5      6     */
85
/*                  63ns   94ns  125ns  156ns  188ns   */
86
87
$define TRUE  'b'1
88
$define FALSE 'b'0
89
90
/* DECLARATION */
91
92
/* Adapter Tri-State Bus */
93
pin [8, 9, 6, 5, 4, 37, 36, 35, 31, 30, 28, 29, 27, 11, 24, 10]
94
               = [DAB0..15];
95
96
field DAB      = [DAB0..15];    /* Full word width bus */
97
field DAB_HIGH = [DAB8..DAB15];  /*   Upper byte */
98
field DAB_LOW  = [DAB0..DAB7];  /*   Lower byte */
99
100
/* disk control signals */
101
pin [49, 48, 61]
102
       = [DA0..2];  /* disk register address */
103
pin 17 = !DCS1;    /* disk chip select 0 - pin */
104
node      CS1;    /* disk chip select 0 latch */
105
pin 34 = !DCS0;    /* disk chip select 1 - pin */
106
node      CS0;    /* disk chip select 1 latch */
107
pin 16 = !DIOR;    /* disk controller read operation */
108
pin 15 = !DIOW;    /* disk controller write operation */
109
pin 39 =  DIORDY;    /* disk controller ready for word transfer  */
110
pin 40 =  DINTRQ;    /* disk controller interrupt request */
111
pin 50 = !DIOCS16;    /* disk controller 16-bit transfer operation */
112
pin 60 = !DRESET;    /* disk controller hardware reset */
113
114
/* QBUS control signals */
115
pin  1 = INIT;    /* bus reset */
116
pin 58 = S7;      /* device page select */
117
pin 81 = SYNC;    /* bus address sync */
118
pin  2 = DIN;      /* data read cycle */
119
pin 45 = DOUT;    /* data write cycle */
120
pin 25 = RPLY;    /* bus cycle handshake */
121
pin 18 = IRQ4O;    /* interrupt request - level 4 - QBus out*/
122
pin 44 = IRQ5;    /* interrupt request - level 5 */
123
pin 46 = IRQ6;    /* interrupt request - level 6 */
124
pin 41 = IAKI;    /* interrupt acknowledge daisy chain in */
125
pin 12 = IAKO;    /* interrupt acknowledge daisy chain out */
126
127
pin 83 =  CLOCK32;    /* clock for delays */
128
pin 20 = !QB_DREN;    /* Qbus read - enable OC bus drivers */
129
        /*   This signal drives the qbus BDAL with the tristate bus contents. */
130
pin 21 = !QB_TSEN;    /* Qbus write - enable TS buffers between bus A and bus B */
131
        /*   This signal drives the tristate bus from the qbus. */
132
pin    =  SEL;    /* address match */
133
node      [RPLYD0..3];  /* state vector for RPLY delay */
134
node      [IOWD0..3];  /* state vector for IOW delay */
135
node      INT_ARB_WON;  /* internal signal indicating that adapter gets interrupt */
136
node      ATA_IRQ;    /* internal F/F to capture drive interrupt request */
137
138
$ifdef JUMPERS
139
/* Option Configuration */
140
pin    = [CSR_BASE0..7];  /* CSR base address jumpers */
141
field    CSR_BASE = [CSR_BASE0..7];
142
field    DAB_CSR = [DAB5..12];
143
$endif
144
145
/* TEST and misc signals */
146
pin 22 = SYNC_LITE;    /* light driver showing bus activity */
147
148
/* CSR - Control and Status Register */
149
pin    = CS_COM;      /* internal select */
150
151
pin =    INT_ENABLE;    /*      6: interrupt enable from disk controller to QBus */
152
node     IORDY_ENABLE;    /*      5: use IORDY signal from disk controller */
153
154
/* VECTOR - Interrupt Vector Number Register */
155
pin    = CS_VECT;      /* internal select */
156
157
node     [VECTOR0..6];    /* Interrupt vector number */
158
field VECTOR = [VECTOR0..6];
159
field DAB_VECT = [DAB2..8];
160
161
/* reserved space */
162
node RSRVD;
163
164
field REG_ADDR = [DAB0..4];
165
166
/* LOGIC */
167
168
/* QBUS Reset */
169
DRESET = INIT;
170
171
/* QBUS Addressing */
172
173
174
/*                1  7  7  7  1  0  0  0 */
175
$ifndef JUMPERS
176
SEL = S7 & DAB:'b'xxxxxxxxx10010000xxxxx;
177
$endif
178
179
$ifdef JUMPERS
180
field MATCH = [MATCH0..7];
181
MATCH = !(CSR_BASE $ DAB_CSR);
182
SEL = S7 & MATCH:&;
183
$endif
184
185
CS_COM.L     = SEL & REG_ADDR:'b'00000;  /* BASE + 0 */
186
CS_COM.LE    = !SYNC;
187
188
CS_VECT.L    = SEL & REG_ADDR:'b'00110;  /* BASE + 6 */
189
CS_VECT.LE   = !SYNC;
190
191
RSRVD.L      = SEL & REG_ADDR:'b'00010  /* BASE + 2 */
192
     # SEL & REG_ADDR:'b'00100  /* BASE + 4 */
193
             # SEL & REG_ADDR:'b'01000  /* BASE + 8 */
194
             # SEL & REG_ADDR:'b'01010  /* BASE + 10 */
195
     # SEL & REG_ADDR:'b'01110;  /* BASE + 14 */
196
RSRVD.LE     = !SYNC;
197
198
CS1.L        = SEL & REG_ADDR:'b'01100;  /* BASE + 12 */
199
CS1.LE       = !SYNC;
200
DCS1 = CS1 & SYNC;
201
202
CS0.L        = SEL & REG_ADDR:'b'1XXX0;  /* BASE + 16 */
203
CS0.LE       = !SYNC;
204
DCS0 = CS0 & SYNC;
205
206
[DA0..2].L   = [DAB1..3];           /* save for disk register select */
207
[DA0..2].LE  = !SYNC;
208
209
DISK_SEL = CS0 # CS1;
210
ADPTR_SEL = CS_COM # CS_VECT # RSRVD;
211
FAST_CYCLE = CS0 & [DA0..2]:'b'000;    /* data register */
212
DIOCS16 = FAST_CYCLE;
213
214
/* I/O Control - QBUS read */
215
IOR = DISK_SEL & DIN;        /* disk controller read */
216
DIOR = IOR;            /*   pin */
217
QBR = (DISK_SEL # ADPTR_SEL) & DIN;    /* enable QBUS drivers */
218
QB_DREN = QBR # IAKI & INT_ARB_WON;
219
220
/* Reply */
221
/* Reply from DIN = 91ns for byte transfers */
222
/*                = 30ns for word transfers */
223
append RPLY = DIN & ADPTR_SEL
224
            # DIN & !FAST_CYCLE & RPLYD3 & (IORDY_ENABLE & DIORDY # !IORDY_ENABLE)
225
            # DIN &  FAST_CYCLE & RPLYD1 & (IORDY_ENABLE & DIORDY # !IORDY_ENABLE);
226
227
/* I/O Control - QBUS write */
228
IOW = DISK_SEL & DOUT & SYNC & !IOWD3;    /* disk controller write */
229
DIOW = IOW;              /*   pin */
230
QBW = (DISK_SEL # ADPTR_SEL) & DOUT;    /* connect bus A to bus B */
231
QB_TSEN = QBW # !SYNC & !(IAKI & INT_ARB_WON);  /* let the Qbus address pass thru */
232
233
/* Reply */
234
/* Reply from DOUT = 91ns for byte transfers */
235
236
append RPLY = DOUT & ADPTR_SEL
237
            # DOUT & IOWD1;
238
239
RPLYD0.D = DISK_SEL & (DIN # DOUT);  /* synchronizer */
240
RPLYD1.D = RPLYD0;        /* 31ns */
241
RPLYD2.D = RPLYD0 & RPLYD1;      /* 62ns */
242
RPLYD3.D = RPLYD0 & RPLYD2;      /* 94ns */
243
[RPLYD0..3].CK = CLOCK32;
244
245
IOWD0.D = DOUT        /* synchonizer */
246
   & (!FAST_CYCLE & RPLYD3 # FAST_CYCLE & RPLYD1)
247
248
IOWD1.D = IOWD0;          /* 31ns  63ns 125ns */
249
IOWD2.D = IOWD0 & IOWD1;      /* 63ns  94ns 156ns */
250
IOWD3.D = IOWD0 & IOWD2;      /* 94ns 125ns 188ns */
251
[IOWD0..3].CK = CLOCK32;      /*      word  byte  */
252
253
append DAB = 'b'0000000000000000;
254
255
append DAB.OE = ADPTR_SEL & DIN & SYNC;
256
257
/* QBus Interrupt Cycle - Modeled after DC003 logic */
258
ATA_IRQ.D = TRUE;
259
ATA_IRQ.CK = INT_ENABLE & DINTRQ;    /* interrupt is triggered on leading edge of DINTRQ */
260
ATA_IRQ.AR = IAKI & INT_ARB_WON;    /* clear interrupt on acknowledge or reset */
261
ATA_IRQ.AP = INIT;
262
263
IRQ4O = DINTRQ & INT_ENABLE & ATA_IRQ;  /* QBus signal to processor */
264
265
INT_ARB_WON.D = DINTRQ & INT_ENABLE & ATA_IRQ & !IRQ5 & !IRQ6;  /* perform arbitration */
266
INT_ARB_WON.CK = DIN;
267
INT_ARB_WON.AR = INIT;
268
269
IAKO = IAKI & !INT_ARB_WON;      /* pass on if not for us */
270
271
append DAB_VECT = IAKI & INT_ARB_WON & VECTOR;  /* place vector on TS bus */
272
append DAB.OE = IAKI & INT_ARB_WON;
273
append RPLY = IAKI & INT_ARB_WON;      /* reply to acknowledge */
274
  /* does RPLY need to be lengthened? Qbus docs say 125ns from RPLY to vector clocked */
275
276
277
/*   read cycle */
278
append DAB7 = QBR & CS_COM & DINTRQ;    /* disk interrupt request line */
279
append DAB6 = QBR & CS_COM & INT_ENABLE;    /* interrupt enable */
280
append DAB5 = QBR & CS_COM & IORDY_ENABLE;  /* disk IORDY control enable */
281
append DAB4 = QBR & CS_COM & ATA_IRQ;    /* disk interrupt pending */
282
append DAB0 = QBR & CS_COM;        /* LSB always reads as 1 */
283
284
/*   write cycle */
285
INT_ENABLE.D = DAB6;
286
INT_ENABLE.CK = !(CS_COM & DOUT);
287
INT_ENABLE.AR = INIT;
288
IORDY_ENABLE.D = DAB5;
289
IORDY_ENABLE.CK = !(CS_COM & DOUT);
290
IORDY_ENABLE.AR = INIT;
291
292
/* Vector Register */
293
/*   read cycle */
294
append DAB_VECT = QBR & CS_VECT & VECTOR;
295
296
/*   write cycle */
297
VECTOR.D = DAB_VECT;
298
VECTOR.CK = !(CS_VECT & DOUT);
299
300
/* Miscellaneous logic */
301
SYNC_LITE = !SYNC;
Ich würde das gerne auf ein XC9572 umwursteln, habe aber von der ganzen
ISE noch keine Ahnung, kann ich das in die Xilinx ISE direkt
importieren?
Gruß,
Holm
von lkmiller (Gast)
Such mal nach ABEL ...
Mit der ISE geht da aber nichts.
von Xenu (Gast)
Das ist nicht ABEL sondern CUPL, ursprünglich von der Firma Logical
Devices:
http://en.wikipedia.org/wiki/Programmable_Array_Logic#CUPL
Atmel hat CUPL für ihre CPLDs benutzt:
http://www.atmel.com/tools/WINCUPL.aspx
von DD (Gast)
Sieht ein bissl aus wie das alte GHDL von Genrad
von Holm T. (Gast)
hmm... dieses CPLD besteht wohl in D haupstächlich aus Unobtanium, ich
habe mal ein Bissel gegoogelt, da gibts höchstens Treffer bei Ebay aus
China...
Die hier angesagte Sprache ist wohl VHDL (und nicht Verilog). Da ich
weder das Eine noch das Andere kenne wäre der Plan wohl sich da mal
einzuarbeiten.
Für mich sah das oben auch nach Abel aus, damit habe ich früher mal
einige wenige GALs gemacht, aber es sieht nur teilweise so aus.
Kennt sich hier Jemand ausreichend damit aus um das zu dechiffrieren und
mir bei der Umsetzung nach VHDL unter die Arme zu greifen?
Gruß,
Holm
von Weltbester FPGA-Pongo (Gast)
Ohne dieses ABEL oder CUPL je genutzt zu haben, kann ich sagen, dass
sich mir der Code sofort erschliesst.
Die Signalzuweisungen sind derart ausdrücklich, dass man es in VDSL
sofort hinschreiben kann, wobei der Weg zu Verilog noch direkter zu sein
scheint.
Sobald Du VHDL ein bischen kennst, kriegst Du das locker ohne Hilfe hin.
von Georg A. (georga)
Das ist aber schon ein ziemliches Gewürge von zig Takten, asynchronen
Pre- und Resets und Latches. Also ein typisches Design der 80er ;) Kann
man ohne viel Nachdenken sicher nach VHDL umsetzen, aber ob sich das
bequem in ein XC95* mappen lässt und dann auch noch vom Timing her
sauber läuft? Gelegenheiten für Glitches gibt es sicher genug...
von Holm T. (Gast)
Ich glauube kaum, das das aus den 80ern stammt, da gab es noch keine IDE
Disks. Das ist der Versuch eine "modernere" Disk an Technik der 80er zu
betreiben. Ich sehe da nur einen 32Mhz Takt, der auf seltsame Weise
mehrere Verzögerungen generiert..
..wie funktioniert das?
Dann das hier z.B.:
CS_VECT.LE   = !SYNC;
S_VECT.L ist wohl ein gelatchtes Signal und was macht .LE?
BTW das hier:
>"Sobald Du VHDL ein bischen kennst, kriegst Du das locker ohne Hilfe hin."
ist nicht wirklich hilfreich.
Gruß,
Holm
Sieht nach Schieberegister aus:
32Mhz = 31,25ns
2 * 31,25ns = 62,5ns
3 * 31,25ns = 93,75ns
Na, klingelts?
E = Enable?
Holm Tiffe schrieb:
> BTW das hier:
>>"Sobald Du VHDL ein bischen kennst, kriegst Du das locker ... hin."
Richtig, denn das Problem hier hat vorrangig nichts mit VHDL, sondern
erst mal nur mit traditioneller Digitaltechnik zu tun: erst muss mal das
Verhalten der Beschreibung und der Schaltung verstanden sein.
von Holm T. (Gast)
>32Mhz = 31,25ns
>Na, klingelts?
Da gibts nicht viel zu klingeln.
Wenn ich mir ansehe wie das oben vereinbart ist  komme ich ins Grüblen.
Was genau bewirkt das ".D" an dem Signal? Handelt es sich um ein Latch
das mit ".CLK" die Daten übernimmt? Ein D-Flipflop?
E = Enable?
Klar doch. Und was enabled das? Den Takt oder den Ausgang...?
Genau deswegen fragte ich auch ob sich Jemand so damit auskennt das er
das dechiffrieren kann. Den Q-Bus Abhängigen Teil kann ich sicherlich
beisteuern. Das ist dokumentiert.
Problematischer ist halt dieses WinCUPL, ich hoffte hier Jemanden zu
finden der das erklären kann, so komme ich nicht umhin gleich 2
Hardwarebeschreibungssprachen lernen zu müssen..
Gruß,
Holm
von berndl (Gast)
Moin,
das ganze beschreibt doch den PIO mode (evtl. noch mit MWDMA). Das
Protokoll ist doch im Web ganz gut beschrieben, damit sollte auch die
Funktion klar werden.
Ausserdem gibt es sicher fertige (nicht UDMA faehige) IDE-Controller
Beschreibungen in VHDL oder Verilog (oder sogar fuer uC via GIO-Pins)...
von Holm T. (Gast)
Du meinst ich soll das Fahrrad neu erfinden?
Ich würde lieber das erwiesenermaßen funktionierende Produkt oben
verwenden, da da auch die passenden Treiber existieren.
Es muß doch möglich sein das obige passend umzusetzen. Wenn es ein
XC9572 nichts schafft muß ich halt den XC95108 nehmen.
Gruß,
Holm
Nein, du sollst dir nur anschauen, wie andere ein Fahrrad gebaut haben,
und das mit deinen Mitteln nachvollziehen.
Klar, aber dazu muss man es vorher verstehen (mögen)...
> E = Enable?
Innerhalb eines programmierbaren Bausteins wird immer der Eingang
validiert. Da macht es keinen Sinn, einen Ausgang hochohmig zu schalten.
CS_COM.LE    = !SYNC;
So wie ich diese Beschreibung ansehe, wird im Latch bei low-aktivem SYNC
eine 0 oder eine 1 gespeichert, abhängig davon, wie SEL steht und vom
Wert von REG_ADDR.
D ist wohl der Dateneingang eines D-Flipflops, davon würde ich auch
ausgehen. Und AR heißt dann vermutlich asynchroner Reset, mit AP dürfte
asynchroner Preset gemeint sein.
von Holm T. (Gast)
Ok, das hilft wirtschaften :-)
Gruß,
Holm
> Ich glaube kaum, das das aus den 80ern stammt,
Aber der QBUS...
Der "[RPLYD0..3].CK = CLOCK32;"? Das ist fast das einzig synchrone an
der Schaltung ;)
Aber was ist mit
ATA_IRQ.CK = INT_ENABLE & DINTRQ; (+asynchronen Pre/Reset)
von berndl (Gast)
Hallo, IDE bzw. PATA ist doch gerade mal ein paar Jahre her. Und in dem
Code oben ist definitiv nix von UDMA zu sehen. Also bleibt nur PIO und
MDMA (oder hiess es MWDMA? Steht auf jeden Fall fuer Multiword-DMA...).
Und das ist ein 'source-synchronous' Interface, im Gegensatz zu UDMA
also trivial einfach. Geh halt mal googeln nach IDE/PATA und PIO bzw.
MDMA. Wenn du dann halbwegs verstanden hast, wie diese Protokolle
funktionieren, dann verstehst du auch den Code weiter oben.
Es gab doch schon 'ne Menge guter Tipps:
* irgendwas.D koennte ein FF-Eingang sein
* irgendwas.Q muesste eigentlich ein Ausgang sein
* irgendwas.E deutet auf ein Enable hin
Und der Rest scheint mir nur noch Boolsche Algebra zu sein...
PS: Ich kenne diese HDL oben auch nicht, aber ich hab' mal was mit
IDE/PATA gemacht...
von Holger (Gast)
@Holm Tiffe
Hallo !
Ich kann doch noch ABEL mit XILINX machen.
 XC2C64A XC9572XL XC2C32A XC9536 oder ???
Tolle Homepage, und Project.
Erst mal das Datenblatt analysieren.
Hier das ist der Hersteller: MMI, wie auf den Bildern sehen ist.
also ein PAL Derivat. pal16l8bcnl.pdf
 Für POWER ON Reset Output LOW(default),
 mit Preset…Term- für „User-Config-Boot-Strap”
 CLK Logic ist also hoffentlich Rising-Edge-aktiv, /OE und Thristate.
########################## 16L8       16R8 #########################
Aufpassen Unterschiede als Latch Typ, oder REGister Typ.
Siehe Datenblatt „Note…“
Eine schöne Fundgrube ist das mit Bildern Source.code.
Das ist noch vor der Lattice GAL 16V8 Hardware.
Das war ein guter Hint, für die Fein-Analyse, sowie das lernen der
guten „alten“ EMV Robust Kuchenblech Technik.
Für mein LMD18245
3,3 V Z-Diode an 5V Pull-Up.
12Bit I/O Karte mit 2*Dioden und R47Ohm-R470Ohm..ist halt robust.
Die TTY Schnittstelle mit BREAK Sync und Feeder Run.
Hint:
http://flipprojets.free.fr/AlvinBSMT_E.html
Adress Decoder in Vector Schreibwiese….mit CUPEL
Keyword Node: ist kombinations via Register ?? reg
Keyword field    DAB_CSR = [DAB5..12];
http://www.transputer.net/tn/14/tn14.html#x1-100004.1
Viel Erfolg.
Gruss Holger.
Ich find eigentlich alles selbsterklärend (syntaktisch zumindest...) bis
auf das komische append... Es gibt mehrere Zuweisungen auf ein Signal
damit. Soll das ein implizites OR sein, damit man verschiedene Minterme
auf unterschiedliche Orte (Text)Positionen verteilen kann?
von Lattice User (Gast)
Ja, siehe:
http://ee.sharif.edu/~logic_circuits_t/readings/CUPL_Reference.pdf
The expression that results from multiple APPEND statements is the
logical OR of all the APPEND statements. If an expression has not
already been assigned to the variable, the first APPEND statement is
treated as the first assignment.
