Forum: Compiler & IDEs sed1335 AVR Studio Fehler
von Andreas S. (andreas_s64)
Hallo habe folgendes Problem:
bei dem Quellcode des sed1335 kommt der Fehler ../sed1335.c:14:
undefined reference to `GLCD_InitializePorts'
Woran liegt das?
#include "sed1335.h"
#include <util/delay.h>
extern void GLCD_InitializePorts(void);
// Funkcja inicjalizacji wyœwietlacza
void GLCD_Initialize(void)
GLCD_InitializePorts();
GLCD_WriteCommand(SED1335_SYSTEM_SET);
GLCD_WriteData(SED1335_SYS_P1);
GLCD_WriteData(SED1335_SYS_P2);
GLCD_WriteData(SED1335_FY);
GLCD_WriteData(SED1335_CR);
GLCD_WriteData(SED1335_TCR);
GLCD_WriteData(SED1335_LF);
23
GLCD_WriteData(SED1335_APL);
24
GLCD_WriteData(SED1335_APH);
25
26
GLCD_WriteCommand(SED1335_SCROLL);
27
GLCD_WriteData(SED1335_SAD1L);
28
GLCD_WriteData(SED1335_SAD1H);
29
GLCD_WriteData(SED1335_SL1);
30
GLCD_WriteData(SED1335_SAD2L);
31
GLCD_WriteData(SED1335_SAD2H);
32
GLCD_WriteData(SED1335_SL2);
33
GLCD_WriteData(SED1335_SAD3L);
34
GLCD_WriteData(SED1335_SAD3H);
35
GLCD_WriteData(SED1335_SAD4L);
36
GLCD_WriteData(SED1335_SAD4H);
37
38
GLCD_WriteCommand(SED1335_CSRFORM);
39
GLCD_WriteData(SED1335_CRX);
40
GLCD_WriteData(SED1335_CSRF_P2);
41
42
GLCD_WriteCommand(SED1335_CGRAM_ADR);
43
GLCD_WriteData(SED1335_SAGL);
44
GLCD_WriteData(SED1335_SAGH);
45
46
GLCD_WriteCommand(SED1335_CSRDIR_R);
47
48
GLCD_WriteCommand(SED1335_HDOT_SCR);
49
GLCD_WriteData(SED1335_SCRD);
50
51
GLCD_WriteCommand(SED1335_OVLAY);
52
GLCD_WriteData(SED1335_OVLAY_P1);
53
54
GLCD_WriteCommand(SED1335_DISP_ON);
55
GLCD_WriteData(SED1335_FLASH);
56
57
58
// Funkcja zapalaj¹ca piksel
59
60
void GLCD_SetPixel(unsigned int x,unsigned int y, int color)
61
62
unsigned char tmp = 0;
63
unsigned int address = SED1335_GRAPHICSTART + (40 * y) + (x/8);
64
GLCD_SetCursorAddress(address);
65
66
GLCD_WriteCommand(SED1335_MREAD);
67
tmp = GLCD_ReadData();
68
69
if(color)
70
  tmp |= (1 << (SED1335_FX - (x % 8)));
71
else
72
  tmp &= ~(1 << (SED1335_FX - (x % 8)));
73
74
75
GLCD_WriteCommand(SED1335_MWRITE);
76
GLCD_WriteData(tmp);
77
78
79
// Funkcja wyswietlajaca tekst
80
81
void GLCD_WriteText(char * tekst)
82
83
84
while(*tekst)
85
  GLCD_WriteData(*tekst++);
86
87
88
// Funkcja wyœwietlaj¹ca tekst z pamiêci programu (AVR)
89
90
void GLCD_WriteTextP(char * tekst)
91
92
93
while(GLCD_ReadByteFromROMMemory(tekst))
94
  GLCD_WriteData(GLCD_ReadByteFromROMMemory(tekst++));
95
96
97
// Funkcja ustawiaj¹ca adres kursora
98
99
void GLCD_SetCursorAddress(unsigned int address)
100
101
GLCD_WriteCommand(SED1335_CSRW);
102
GLCD_WriteData((unsigned char)(address & 0xFF));
103
GLCD_WriteData((unsigned char)(address >> 8));
104
105
106
107
void GLCD_TextGoTo(unsigned char x, unsigned char y)
108
109
GLCD_SetCursorAddress((y * 40) + x);
110
111
112
113
void GLCD_GraphicGoTo(unsigned int x, unsigned int y)
114
115
GLCD_SetCursorAddress(SED1335_GRAPHICSTART + (y * 40) + x/8);
116
117
118
119
void GLCD_ClearText(void)
120
121
int i;
122
GLCD_TextGoTo(0,0);
123
124
for(i = 0; i < 1200; i++)
125
  GLCD_WriteData(' ');
126
127
128
129
void GLCD_ClearGraphic(void)
130
131
unsigned int i;
132
GLCD_SetCursorAddress(SED1335_GRAPHICSTART);
133
134
for(i = 0; i < (40 * 240); i++)
135
  GLCD_WriteData(0x00);
136
137
138
139
void GLCD_Bitmap(char * bmp, int x, int y, int width, int height)
140
141
unsigned int i, j;
142
for(i = 0; i < height ; i++)
143
144
  GLCD_GraphicGoTo(x, y+i);
145
146
  for(j = 0; j < width/8; j++)
147
    GLCD_WriteData(GLCD_ReadByteFromROMMemory(bmp+j+(40*i)));
148
149
150
151
Kennt sich damit wirklich keiner aus? Ich habe die sed1335 library von
der seite http://en.radzio.dxp.pl/sed1335/ heruntergeladen und in avr
studio 4 eingebunden und dann kommt dieser Fehler raus.
von NurEinGast (Gast)
Der Compiler sagt ja :
Also findet er die GLCD_InitializePorts nicht.
Schau mal in die entsprechende Datei für Deinen Controller.
Welche das ist kann ich nicht sagen, weil Du vergessen hast uns das
mitzuteilen.
Zumindest in der Datei für den AVR hat der Hersteller der Lib die
Finktion nicht GLCD_InitializePorts sonder als GLCD_InitPorts genannt.
Das müsste man umbenennen.
von Oliver (Gast)
Derjenige, der die Software geschrieben hat.
Deine Fehlermeldung besagt, daß in deine Programm zwar
GLCD_InitializePorts() aufgerufen wird, es die Funktion aber nirgends
gibt. Warum, wissen nur du und ie Götter. Vielleicht hast du nicht alle
benötigten Programmteile installert, vielleicht musst du die Funktion,
passend zu deiner Hardware, selber schreiben, keine Ahnung.
Mit an Sicherheit grenzender Wahrscheinlichkeit steht aber dazu was in
der Doku zu der lib. Also: RTFM.
Oliver
von Frank W. (Firma: DB1FW) (frankw) Benutzerseite
Na ja - das wurde im Posting eins weiter oben bereits - sogar schon
etwas genauer - beantwortet.
Aber wahrscheilich hat der Threadersteller eh keine Lust mehr. Hat sich
zumindest nicht mehr gemeldet.
Danke für die antworten. habe die Funktion in GLCD_InitializePorts
umbenannt.
