EmbDev.net
Forum: FPGA, VHDL & Verilog fixed point precision
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Abdallah  . (Company: Home) (my_name)
Rate this post
useful
not useful
Peace!
I want ask about the number of bits shoud I use in an fixed_point number
to obtein the good precision, precision of distance eclidean.
some detail:
I want to determine an vector of foor element VECT[MOY1,MOY2,MOY3,MOY4],
each element is the moyen of one quart of matrix of (64*64), the matrix'
element value varies (0-255)'''it's pixel valor'''
--> the result of division (MOY1=SUM/Nbits) has 8 bits in the integer
part;
Question: how many bits of fractional part shout I use to get the good
result (result of euclidean distance between two vector
VECT1[MOY11,MOY12,MOY13,MOY14] and VECT[MOY21,MOY22,MOY23,MOY24])..
thank you....peace:
von Duke Scarring (Guest)
Rate this post
useful
not useful
You have to define the precision. Independed if you use fixed point or
integer number format.
The number of bits depends on your dynamic range:
http://en.wikipedia.org/wiki/Dynamic_range
Roughly: NoBs = SNR / 6
eg.: 16 Bit = 96 dB / 6
Duke
von Michael W. (Guest)
Rate this post
useful
not useful
Why would you consider to be the DR at 16 Bits not to be 96dB but
96dB/6?
von ... (Guest)
Rate this post
useful
not useful
You wanted a GOOD precission in the result, right? then divide it by 6
Rate this post
useful
not useful
> 96dB/6?
Read carefully:
 number of bits * 6 dB = dynamic range
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
