EmbDev.net
Forum: FPGA, VHDL & Verilog Xilinx 8.1 & Xilinx 14.7 Version will not compile my design
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Lewis M. (Company: Scientech Technologies) (loumbut5)
Rate this post
useful
not useful
Hi.
I designed the processor DorQ which is attached. It compiles fine in
Quartus 2 but my business partners use Xilinx 8.1 & Xilinx 14.7 Version
and on these software, it shows errors which are also attached to this
thread.
Could someone please provide a solution to this problem. Is there a
setting we can change on Xilinx 8.1 & Xilinx 14.7 Version that will do
away with the error messages.
Thanks for your reply.
von Duke Scarring (Guest)
Rate this post
useful
not useful
The message say, that there are two outputs are connected:
ac923: acff port map (wire1(2500 downto 2500), wire1(2501 downto 2501), wire0(2501 downto 2501), wire0(2500 downto 2500));
bc1579: bcff port map (wire0(2501 downto 2501), wire0(2502 downto 2502), wire1(2502 downto 2502), wire1(2501 downto 2501));
But your provided code is not human readable. Sorry, I can't help.
Did the error also occur, if you try to generate a bitfile?
Duke
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
Lewis Mbuthia wrote:
> It compiles fine in Quartus 2
What target?
You use extensively inout ports inside a FPGA. But FPGAs don't have
bidirectional ports in them anymore. Thes also don't have a 'Z' inside.
So every bidirectional connection must be resolved at compile time to a
unidirectional mux-solution. That looks fairly tricky in the supplied
code...
> it shows errors which are also attached to this thread.
Errors messages in PNG format? Why not as raw text as they are
displayed in your computer?
1.png: the syntax check just tells, that theres no semicolon or comma
missing. Nearly useless...
2.png: "Synthesize failed" is NOT a error message, its just a final
result. Absolutely useless...
3.png: A multi-source means just: you connected two outputs together. Or
in more sophisticated words: you have more than one driver on this
signal.
I don't see a solution for your problem. The design looks incredibly
tricky. And it looks like it is not a design built for a FPGA.
: Edited by Moderator
von ElKo (Guest)
Rate this post
useful
not useful
WOW - That's what I call massive Crossposting. I thought, that the
people nowadays know, not to crosspost?
http://www.alteraforum.com/forum/showthread.php?t=46551
http://forums.xilinx.com/t5/New-Users-Forum/Xilinx-8-1-amp-Xilinx-14-7-Version-wiil-not-compile-my-design/td-p/535083
http://forums.xilinx.com/t5/General-Technical-Discussion/Xilinx-8-1-amp-Xilinx-14-7-Version-will-not-compile-my-design/td-p/536943
www.stackoverflow.com/questions/26563019/xilinx-8-1-xilinx-14-7-version-
embdev.net/topic/347939
Only the entry in edaboard I'm missing? [edit: found it, but as another
question. See below.]
And what the hack is DorQ??? I can find only these interesting articles
with naming such thing. Definitly worth the reading! Regarding to the
crossposting and the mail-address, I asume that this is also from you,
Lewis Mbuthia?
http://www.edaboard.co.uk/partnership-request-t527308.html
http://www.fpgarelated.com/comp.arch.fpga/thread/110054/partnership-request.php
The code looks like a prank to me. But definitly not as a accelerating
USB-Coprocessor. No explanation, what it is supposed to do. Whether it's
complete. Nor the explanation of existing and running configurations...
(I asume, there is no running configuration on a FPGA, and if there is,
it isn't doing, what the descriptions says.)
But it's also funny, to look further. Only one example of the
company-page scientechworld.com/careers.php : "At Scientech we have a
vision of where we want to go, and it's really exciting. [...]" :-)
Thanks for the funny workbreak!
Btw, it is often worth, to read the entries of embdev.net. ;-) (I'm
impressed about your patiance, Lothar, to answer many of those
questions! Good Job!)
 - ElKo
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
