EmbDev.net
Forum: FPGA, VHDL & Verilog USB interface
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Lukas 1. (Company: Soundsystem Brabant) (forester)
Rate this post
useful
not useful
Hello,
I just got a SoC board, and I want to make some music with it.
The music making part I know very well from doing SIMD, and im confident
this will work out for me using VHDL.
But.. to get started I'm really having a hard time getting to
implementing a usb port. Also with the design aspect. This being around
the first thing intended to do on it, and it has a lot of odds and ends
that I was actually hoping would be sort of standard implement and go
type stuff.
So i have a couple of questions, I have like the USB251xb and
USB3300-EZK controllers. But it may be more valuable in the end to do
the bare wire aproach..Right?
Also I read that the power demand of devices is sent as a command at the
presence of a connected usb device. So is this doable via a live pin on
the FPGA, or as a space saver ultimately always better handled by the
controller?
Or is there a good piece of code to fit the controllers in place, that I
can make in a quartus module?
: Edited by User
von Lattice User (Guest)
Rate this post
useful
not useful
Wrong.
Since you asked here, i am assumimng you are looking for a FPGA based
implementation.
Bare wire is possible for low speed, but at full speed you will already
have trouble to recover the clock, not even speaking of high speed.
USB251xb is an USB hub. This doesn't isolate you from the bare wire.
USB3300 is an USB transceiver with ULPI interface, and can be easily
interfaced to a FPGA. But be aware that the USB3300 only implements the
lower physical layer. Higher parts like framing, is still needed to be
done in the FPGA.
You can buy IP Cores for that, or try to implement it your self, a huge
task even for someone with a lot of knowldege in FPGA design and USB
details.
Rate this post
useful
not useful
So, framing implies that the 10 bit signal gets passed but a lot of the
maintenance gets done by the controller itself?
I see now why this is left out..
Also I found this http://jorisvr.nl/usb/
It covers all layers right, "Only a bit to much foreign pins to find for
my experience level"..
Also I typed along with a tutorial, (I guess better suited to work with
a board) but I get a compiler error at page UART3 line 23.. Saying ""=""
Operator has no synthesizable outcome.
Rate this post
useful
not useful
Very nice :-)
But it only covers an UART implementation, USB Audio is a much tougher
beast.
Also it requires an UTMI Interface, the USB3300 tranceiver implements an
ULPI interface (ULPI stands for UTMI+ Low Pin Interface).
Main differenz boils down to UTMI using signals to control the
transceiver and ULPI using commands.
Rate this post
useful
not useful
It's MIDI mainly, and maybe some configuration via a dedicated ui.
Tho its cool to keep in mind, Roland Aria has got that bounce to disk
feature.
But how to get a basic implementation going, lets say an input? How to
make sense of it all? :|
: Edited by User
Rate this post
useful
not useful
> feature.
Start with reading
http://www.usb.org/developers/docs/devclass_docs/midi10.pdf
Next try to implment it on an µC with an USB interfaces, (i.e. AVR, PIC
If that is working you may think of redoing it on the FPGA.
Rate this post
useful
not useful
I actually know the MIDI protocol enough to map it out once I can get
the numbers in, and want to do it on the FPGA because that is my
objective..
The thing is USB.. From the attachment posted (not the link) I should be
able to get two or three quartus modules once I figure out the compiler
error. (10327 VHDL error at UART03.vhd(23): can't determine definition
of operator ""="" -- found 0 possible definitions) So it's yust to get
values in to a logic analizer.
Rate this post
useful
not useful
> objective..
The link i have provided, is not about the MIDI protocol, but about the
USB descriptors a MIDI device has to present to be recognised as such.
The USB Part from Joris implements a USB serial adapter using the CDC
device class.
RX_LINE is a vector, but you are comparing it to a single value.
Attach your code directly as .vhdl, or even when it is small place it
between
[vhdl] ... [/vhdl]
in the posting.
This way you get a faster response from the real VHDL experts here.
Rate this post
useful
not useful
Thanks for taking the time!
I see now it's comparing the vector to the symbol..Ill go and have a
read "probably the last thing ill get done today is to read the pdf"
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
