1 | #include <avr/io.h>
2 | #include <inttypes.h>
3 | #include <avr/interrupt.h>
4 | #include <avr/sleep.h>
5 | #include <util/delay.h>
6 |
7 | #undef F_CPU
8 | #define F_CPU 8000000
9 | // Berechnungen
10 | #define BAUD 9600
11 |
12 | // --------------------------------------------------------
13 | // Timer0 ist 8 Bit
14 | // Wir berechnen den optimalen Prescale-Faktor
15 | // --------------------------------------------------------
16 |
17 | #define T0_MAX_COUNTER 256UL
18 |
19 | // --------------------------------------------------------
20 | // 8-Bit Timer - Timer0
21 | // --------------------------------------------------------
22 | #define _T0_PRESCALE_0 (0)
23 | #define _T0_PRESCALE_1 (1<<CS00)
24 | #define _T0_PRESCALE_8 (1<<CS01)
25 | #define _T0_PRESCALE_64 (1<<CS01 | 1<<CS00)
26 | #define _T0_PRESCALE_256 (1<<CS02)
27 | #define _T0_PRESCALE_1024 (1<<CS02 | 1<<CS00)
28 |
29 | // --------------------------------------------------------
30 | // Timer0 Vorteiler für Baudrate berechnen
31 | // --------------------------------------------------------
32 | #if (F_CPU / BAUD ) < T0_MAX_COUNTER
33 | # define T0_PRESCALE 1UL // prescaler :1
34 | # define T0_PRESCALE_VALUE _T0_PRESCALE_1
35 |
36 | #elif (F_CPU / (BAUD * 8UL )) < T0_MAX_COUNTER
37 | # define T0_PRESCALE 8UL // prescaler :8
38 | # define T0_PRESCALE_VALUE _T0_PRESCALE_8
39 |
40 | #elif (F_CPU / (BAUD * 64UL )) < T0_MAX_COUNTER
41 | # define T0_PRESCALE 64UL // prescaler :64
42 | # define T0_PRESCALE_VALUE _T0_PRESCALE_64
43 |
44 | #elif (F_CPU / (BAUD * 256UL )) < T0_MAX_COUNTER
45 | # define T0_PRESCALE 256UL // prescaler :256
46 | # define T0_PRESCALE_VALUE _T0_PRESCALE_256
47 |
48 | #elif (F_CPU / (BAUD * 1024UL)) < T0_MAX_COUNTER
49 | # define T0_PRESCALE 1024UL // prescaler :1024
50 | # define T0_PRESCALE_VALUE _T0_PRESCALE_1024
51 |
52 | #else
53 | # error "T0_FREQUENCE"
54 | #endif
55 |
56 | #define T0_COUNTER (uint16_t) ((1.0 * F_CPU / (( T0_PRESCALE * BAUD ) + 0.5)))
57 | // in T0_PRESCALE_VALUE stehen dann Bit-Werte für den Prescaler.
58 | //#define TEST1 ( T0_COUNTER / 2 )
59 |
60 | // Berechnungen
61 | #define UBRR_VAL ((F_CPU+BAUD*8)/(BAUD*16)-1) // clever runden
62 | #define BIT_TIME UBRR_VAL * 2
63 | #define BIT_TIME_ALT (int) (1000000.0/((float) BAUD)+0.5)
64 | #define BAUD_REAL (F_CPU/(16*(UBRR_VAL+1))) // Reale Baudrate
65 | #define BAUD_REAL_ALT (F_CPU/(16*(UBRR_VAL+1))) // Reale Baudrate
66 | #define BAUD_REAL_NEW (F_CPU/(T0_PRESCALE * (( T0_COUNTER / 2 )+1))) // Reale Baudrate
67 |
68 | #define BAUD_ERROR ((BAUD_REAL*1000)/BAUD) // Fehler in Promille, 1000 = kein Fehler.
69 | #define BAUD_ERROR_ALT ((BAUD_REAL*1000)/BAUD) // Fehler in Promille, 1000 = kein Fehler.
70 |
71 | #define BAUD_ERROR_NEW ((BAUD_REAL_NEW*1000)/BAUD)
72 |
73 | #if ((BAUD_ERROR<990) || (BAUD_ERROR>1010))
74 | #error Systematischer Fehler der Baudrate grösser 1% und damit zu hoch!
75 | #endif
76 | #if 1
77 | #if ((BAUD_ERROR_NEW <990) || (BAUD_ERROR_NEW >1010))
78 | #error Systematischer Fehler der Baudrate grösser 1% und damit zu hoch!
79 | #endif
80 | #endif
81 | int main() { //Wayne ?
82 | }
