EmbDev.net
Forum: FPGA, VHDL & Verilog Memory issues
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Compstomp (Guest)
Rate this post
useful
not useful
Altera forum is dead as ever on this issue.. I have a DDR3 controller,
but in order to test it i have to get the Quartus to interface to my
DDR3 stick. As in connect the physical pins to my project. This it does
not do for some reason I cant really put my finger on. But I get "those"
warnings. Could this be due to termination IE can be ignored or?
Error (14566): Could not place 2 periphery component(s) due to conflicts
with existing constraints (2 pin(s))
  Error (175020): Illegal constraint of pin to the region (89, 69) to
(89, 80): no valid locations in region
    Info (14596): Information about the failing component:
      Info (175028): The pin name: WE // Write enable
    Info (14597): No legal location could be found for this component
out of 1 considered location(s).  Reasons why each location could not be
used are summarized below:
      Error (184016): There were not enough single-ended output pin
locations available (1 location affected)
        Info (175029): C28 // Exists
      Info (175015): The I/O pad WE is constrained to the location
PIN_C28 due to: User Location Constraints (PIN_C28)
        Info (14709): The constrained I/O pad is contained within this
pin
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
