1 | #include <Wire.h>
2 |
3 | #define Mcp_Reg_IODIRA 0x00 // IO direction (0 = output, 1 = input (Default))
4 | #define Mcp_Reg_IODIRB 0x01
5 | #define Mcp_Reg_IOPOLA 0x02 // IO polarity (0 = normal, 1 = inverse)
6 | #define Mcp_Reg_IOPOLB 0x03
7 | #define Mcp_Reg_GPINTENA 0x04 // Interrupt on change (0 = disable, 1 = enable)
8 | #define Mcp_Reg_GPINTENB 0x05
9 | #define Mcp_Reg_DEFVALA 0x06 // Default comparison for interrupt on change (interrupts on opposite)
10 | #define Mcp_Reg_DEFVALB 0x07
11 | #define Mcp_Reg_INTCONA 0x08 // Interrupt control (0 = interrupt on change from previous, 1 = interrupt on change from DEFVAL)
12 | #define Mcp_Reg_INTCONB 0x09
13 | #define Mcp_Reg_IOCON 0x0A // IO Configuration: bank/mirror/seqop/disslw/haen/odr/intpol/notimp
14 | //#define Mcp_Reg_IOCON 0x0B // same as 0x0A
15 | #define Mcp_Reg_GPPUA 0x0C // Pull-up resistor (0 = disabled, 1 = enabled)
16 | #define Mcp_Reg_GPPUB 0x0D
17 | #define Mcp_Reg_INFTFA 0x0E // Interrupt flag (read only) : (0 = no interrupt, 1 = pin caused interrupt)
18 | #define Mcp_Reg_INFTFB 0x0F
19 | #define Mcp_Reg_INTCAPA 0x10 // Interrupt capture (read only) : value of GPIO at time of last interrupt
20 | #define Mcp_Reg_INTCAPB 0x11
21 | #define Mcp_Reg_GPIOA 0x12 // Port value. Write to change, read to obtain value
22 | #define Mcp_Reg_GPIOB 0x13
23 | #define Mcp_Reg_OLLATA 0x14 // Output latch. Write to latch output.
24 | #define Mcp_Reg_OLLATB 0x15
25 |
26 | #define mcp 0x21
27 |
28 | #define MCPResetPin 4 // hier hängt der MCP mit seinem Reset-Pin dran
29 | #define MCPInterruptA 0 // hier hängt der MCP mit seinem Interrupt-Pin 19 dran
30 | #define MCPInterruptB 1 // hier hängt der MCP mit seinem Interrupt-Pin 19 dran
31 | #define LEDOnBoard 13 // pin 13, LED aufm Arduino-Board
32 |
33 | byte WireTransmitResult = 0;
34 | boolean SwitchPressed = false;
35 | boolean isInInit = false;
36 | byte inputStateA = 0;
37 | byte inputStateB = 0;
38 |
39 |
40 | void setup()
41 | {
42 | Serial.begin(9600);
43 | Serial.println("Start");
44 | Wire.begin();
45 | initiic();
46 | pinMode (LEDOnBoard, OUTPUT);
47 | digitalWrite (LEDOnBoard, LOW);
48 | attachInterrupt(MCPInterruptA, ISRSwitchPressed, FALLING);
49 | // attachInterrupt(MCPInterruptB, ISRSwitchPressed, FALLING);
50 | Serial.println("Bereit");
51 | }
52 |
53 |
54 |
55 | void loop()
56 | {
57 | if (SwitchPressed)
58 | {
59 | inputStateA = readiicbyte(mcp, Mcp_Reg_INTCAPA);
60 | inputStateB = readiicbyte(mcp, Mcp_Reg_INTCAPB);
61 |
62 | Serial.print("LOOP inputStateA: ");
63 | Serial.println(inputStateA, BIN);
64 | Serial.print("LOOP inputStateB: ");
65 | Serial.println(inputStateB, BIN);
66 |
67 | digitalWrite (LEDOnBoard, LOW);
68 | SwitchPressed = false;
69 | }
70 | }
71 |
72 |
73 |
74 | void ISRSwitchPressed ()
75 | {
76 | Serial.println("ISRSwitchPressed");
77 | digitalWrite (LEDOnBoard, HIGH);
78 |
79 | inputStateA = readiicbyte(mcp, Mcp_Reg_INTCAPA);
80 | inputStateB = readiicbyte(mcp, Mcp_Reg_INTCAPB);
81 |
82 | Serial.print("ISR inputStateA: ");
83 | Serial.println(inputStateA, BIN);
84 | Serial.print("ISR inputStateB: ");
85 | Serial.println(inputStateB, BIN);
86 |
87 | if (SwitchPressed || isInInit)
88 | {
89 | /*
90 | Serial.println(inputState, BIN);
91 | Serial.print("ISR SP: ");
92 | Serial.println((String)isInInit);
93 | Serial.print("ISR iI: ");
94 | Serial.println((String)SwitchPressed);
95 | Serial.println("ISR returned");
96 | */
97 | digitalWrite (LEDOnBoard, LOW);
98 | }
99 | else
100 | {
101 | SwitchPressed = true;
102 | }
103 | }
104 |
105 |
106 |
107 | void writeiic(uint8_t adr, uint8_t port, byte value)
108 | {
109 | Wire.beginTransmission( adr );
110 | Wire.write( port );
111 | Wire.write( value );
112 | WireTransmitResult = Wire.endTransmission();
113 |
114 | // String t = "writeiic: ";
115 | // t += " Adr: " + String(adr) + " Port: " + String(port) + " Value: " + String(value);
116 | // Serial.println(t);
117 | }
118 |
119 |
120 |
121 | byte readiicbyte(uint8_t adr, uint8_t port)
122 | {
123 | Serial.println("IIC Lesen");
124 | byte returnword = 0x00;
125 |
126 | Wire.beginTransmission(adr);
127 | Wire.write(port);
128 | Wire.endTransmission();
129 | Wire.requestFrom((int)adr, 1);
130 |
131 | int c = 0;
132 |
133 | if (Wire.available())
134 | {
135 | returnword = Wire.read();
136 | }
137 | return returnword;
138 | }
139 |
140 |
141 |
142 | void initiic()
143 | {
144 | Serial.println("Init Wire");
145 | isInInit = true;
146 | SwitchPressed = false;
147 |
148 | pinMode(MCPResetPin, OUTPUT);
149 | digitalWrite(MCPResetPin, LOW);
150 | delay(5);
151 | digitalWrite(MCPResetPin, HIGH);
152 |
153 | writeiic(mcp, Mcp_Reg_IODIRA, 0x00); // Alles auf Output setzen
154 | writeiic(mcp, Mcp_Reg_GPIOA, 0x00); // Alle Pins auf 0 setzen
155 | writeiic(mcp, Mcp_Reg_IODIRB, 0x00); // Alles auf Output setzen
156 | writeiic(mcp, Mcp_Reg_GPIOB, 0x00); // alle Pins auf 0 setzen
157 |
158 | byte inputMaskA = 0xFF;
159 | byte inputMaskB = 0xFF;
160 | byte polA = 0xFF;
161 | byte polB = 0xFF;
162 |
163 | writeiic(mcp, Mcp_Reg_IODIRA, inputMaskA); // Richtung (Ein-/Ausgang) einstellen
164 | writeiic(mcp, Mcp_Reg_IODIRB, inputMaskB); // Richtung (Ein-/Ausgang) einstellen
165 |
166 | writeiic(mcp, Mcp_Reg_GPPUA, inputMaskA); // Pull-Up Widerstände einrichten
167 | writeiic(mcp, Mcp_Reg_GPPUB, inputMaskB); // Pull-Up Widerstände einrichten
168 |
169 | writeiic(mcp, Mcp_Reg_IOPOLA, polA); // Polarität einstellen (für Eingänge 0 oder 1)
170 | writeiic(mcp, Mcp_Reg_IOPOLB, polB); // Polarität einstellen (für Eingänge 0 oder 1)
171 |
172 | writeiic(mcp, Mcp_Reg_GPINTENA, inputMaskA); // Interrupt aktivieren
173 | writeiic(mcp, Mcp_Reg_GPINTENB, inputMaskB); // Interrupt aktivieren
174 |
175 | writeiic(mcp, Mcp_Reg_DEFVALA, inputMaskA); // Interrupt Default-Wert festlegen
176 | writeiic(mcp, Mcp_Reg_DEFVALB, inputMaskB); // Interrupt Default-Wert festlegen
177 |
178 | writeiic(mcp, Mcp_Reg_INTCONA, inputMaskA); // Interrupt Vergleich einstellen, 0 = Änderung zum Vorgänger, 1 = Änderung zum DEFVAL-Wert
179 | writeiic(mcp, Mcp_Reg_INTCONB, inputMaskB); // Interrupt Vergleich einstellen, 0 = Änderung zum Vorgänger, 1 = Änderung zum DEFVAL-Wert
180 |
181 | readiicbyte(mcp, Mcp_Reg_INTCAPA); // Interrupts lesen und dadurch löschen
182 | readiicbyte(mcp, Mcp_Reg_INTCAPB); // Interrupts lesen und dadurch löschen
183 |
184 | Serial.println("Init Fertig");
185 | isInInit = false;
186 | }
