1 | ** Error:.../VectorToBCD.vhd(30): Integer literal 8 is not of type ieee.NUMERIC_STD.UNSIGNED.
2 | ** Error:.../VectorToBCD.vhd(37): near "90000000000000": (vcom-119) Integer value exceeds INTEGER'high.
3 | ** Error:.../VectorToBCD.vhd(37): near "90000000000000": (vcom-119) Integer value exceeds INTEGER'high.
4 | ** Error:.../VectorToBCD.vhd(37): Range type ieee.NUMERIC_STD.UNRESOLVED_UNSIGNED is not a scalar type.
5 | ** Error:.../VectorToBCD.vhd(37): Range expression is type ieee.NUMERIC_STD.UNRESOLVED_UNSIGNED; expecting type std.STANDARD.NATURAL.
6 | ** Error:.../VectorToBCD.vhd(38): near "80000000000000": (vcom-119) Integer value exceeds INTEGER'high.
7 | ** Error:.../VectorToBCD.vhd(38): near "80000000000000": (vcom-119) Integer value exceeds INTEGER'high.
8 | ** Error:.../VectorToBCD.vhd(38): Range type ieee.NUMERIC_STD.UNRESOLVED_UNSIGNED is not a scalar type.
9 | ** Error:.../VectorToBCD.vhd(38): Range expression is type ieee.NUMERIC_STD.UNRESOLVED_UNSIGNED; expecting type std.STANDARD.NATURAL.
10 | ** Error:.../VectorToBCD.vhd(39): near "70000000000000": (vcom-119) Integer value exceeds INTEGER'high.
11 | ** Error:.../VectorToBCD.vhd(39): near "70000000000000": (vcom-119) Integer value exceeds INTEGER'high.
12 | ** Error:.../VectorToBCD.vhd(39): Range type ieee.NUMERIC_STD.UNRESOLVED_UNSIGNED is not a scalar type.
13 | ** Error:.../VectorToBCD.vhd(39): Range expression is type ieee.NUMERIC_STD.UNRESOLVED_UNSIGNED; expecting type std.STANDARD.NATURAL.
14 | ** Error:.../VectorToBCD.vhd(40): near "60000000000000": (vcom-119) Integer value exceeds INTEGER'high.
15 | ** Error:.../VectorToBCD.vhd(40): near "60000000000000": (vcom-119) Integer value exceeds INTEGER'high.
16 | ** Error:.../VectorToBCD.vhd(40): Range type ieee.NUMERIC_STD.UNRESOLVED_UNSIGNED is not a scalar type.
17 | ** Error:.../VectorToBCD.vhd(40): Range expression is type ieee.NUMERIC_STD.UNRESOLVED_UNSIGNED; expecting type std.STANDARD.NATURAL.
18 | ** Error:.../VectorToBCD.vhd(41): near "50000000000000": (vcom-119) Integer value exceeds INTEGER'high.
19 | ** Error:.../VectorToBCD.vhd(41): near "50000000000000": (vcom-119) Integer value exceeds INTEGER'high.
20 | ** Error:.../VectorToBCD.vhd(41): Range type ieee.NUMERIC_STD.UNRESOLVED_UNSIGNED is not a scalar type.
21 | ** Error:.../VectorToBCD.vhd(41): Range expression is type ieee.NUMERIC_STD.UNRESOLVED_UNSIGNED; expecting type std.STANDARD.NATURAL.
22 | ** Error:.../VectorToBCD.vhd(42): near "40000000000000": (vcom-119) Integer value exceeds INTEGER'high.
23 | ** Error:.../VectorToBCD.vhd(42): near "40000000000000": (vcom-119) Integer value exceeds INTEGER'high.
24 | ** Error:.../VectorToBCD.vhd(42): Range type ieee.NUMERIC_STD.UNRESOLVED_UNSIGNED is not a scalar type.
25 | ** Error:.../VectorToBCD.vhd(42): Range expression is type ieee.NUMERIC_STD.UNRESOLVED_UNSIGNED; expecting type std.STANDARD.NATURAL.
26 | ** Error:.../VectorToBCD.vhd(43): near "30000000000000": (vcom-119) Integer value exceeds INTEGER'high.
27 | ** Error:.../VectorToBCD.vhd(43): near "30000000000000": (vcom-119) Integer value exceeds INTEGER'high.
28 | ** Error:.../VectorToBCD.vhd(43): Range type ieee.NUMERIC_STD.UNRESOLVED_UNSIGNED is not a scalar type.
29 | ** Error:.../VectorToBCD.vhd(43): Range expression is type ieee.NUMERIC_STD.UNRESOLVED_UNSIGNED; expecting type std.STANDARD.NATURAL.
30 | ** Error:.../VectorToBCD.vhd(44): near "20000000000000": (vcom-119) Integer value exceeds INTEGER'high.
31 | ** Error:.../VectorToBCD.vhd(44): near "20000000000000": (vcom-119) Integer value exceeds INTEGER'high.
32 | ** Error:.../VectorToBCD.vhd(44): Range type ieee.NUMERIC_STD.UNRESOLVED_UNSIGNED is not a scalar type.
33 | ** Error:.../VectorToBCD.vhd(44): Range expression is type ieee.NUMERIC_STD.UNRESOLVED_UNSIGNED; expecting type std.STANDARD.NATURAL.
34 | ** Error:.../VectorToBCD.vhd(45): near "10000000000000": (vcom-119) Integer value exceeds INTEGER'high.
35 | ** Error:.../VectorToBCD.vhd(45): near "10000000000000": (vcom-119) Integer value exceeds INTEGER'high.
36 | ** Error:.../VectorToBCD.vhd(45): Range type ieee.NUMERIC_STD.UNRESOLVED_UNSIGNED is not a scalar type.
37 | ** Error:.../VectorToBCD.vhd(45): Range expression is type ieee.NUMERIC_STD.UNRESOLVED_UNSIGNED; expecting type std.STANDARD.NATURAL.
38 | ** Error:.../VectorToBCD.vhd(46): Range type ieee.NUMERIC_STD.UNRESOLVED_UNSIGNED is not a scalar type.
39 | ** Error:.../VectorToBCD.vhd(46): Range expression is type ieee.NUMERIC_STD.UNRESOLVED_UNSIGNED; expecting type std.STANDARD.NATURAL.
40 | ** Warning: [14].../VectorToBCD.vhd(28): (vcom-1272) Length of expected is 48; length of actual is 44.
41 |
42 | ** Warning: [14].../VectorToBCD.vhd(38): (vcom-1144) Value -589934592 (of type std.STANDARD.NATURAL) is out of range 0 to 2147483647.
43 |
44 | ** Warning: [14].../VectorToBCD.vhd(38): (vcom-1144) Value -589934592 (of type std.STANDARD.NATURAL) is out of range 0 to 2147483647.
45 |
46 | ** Warning: [14].../VectorToBCD.vhd(39): (vcom-1144) Value -1589934592 (of type std.STANDARD.NATURAL) is out of range 0 to 2147483647.
47 |
48 | ** Warning: [14].../VectorToBCD.vhd(39): (vcom-1144) Value -1589934592 (of type std.STANDARD.NATURAL) is out of range 0 to 2147483647.
49 |
50 | ** Warning: [14].../VectorToBCD.vhd(42): (vcom-1144) Value -294967296 (of type std.STANDARD.NATURAL) is out of range 0 to 2147483647.
51 |
52 | ** Warning: [14].../VectorToBCD.vhd(42): (vcom-1144) Value -294967296 (of type std.STANDARD.NATURAL) is out of range 0 to 2147483647.
53 |
54 | ** Warning: [14].../VectorToBCD.vhd(43): (vcom-1144) Value -1294967296 (of type std.STANDARD.NATURAL) is out of range 0 to 2147483647.
55 |
56 | ** Warning: [14].../VectorToBCD.vhd(43): (vcom-1144) Value -1294967296 (of type std.STANDARD.NATURAL) is out of range 0 to 2147483647.
57 |
58 | ** Warning: [14].../VectorToBCD.vhd(44): (vcom-1144) Value -1474836480 (of type std.STANDARD.NATURAL) is out of range 0 to 2147483647.
59 |
60 | ** Warning: [14].../VectorToBCD.vhd(44): (vcom-1144) Value -1474836480 (of type std.STANDARD.NATURAL) is out of range 0 to 2147483647.
61 |
62 | ** Warning: [14].../VectorToBCD.vhd(48): (vcom-1272) Length of expected is 48; length of actual is 96.
63 |
64 | ** Error:.../VectorToBCD.vhd(60): VHDL Compiler exiting
