Forum: FPGA, VHDL & Co. StartUp - chinesischer FPGA, Open Source Synthese
von Franz N. (abnoname)
http://www.gowinsemi.com. cn /en/newsshow.aspx?n_id=319 (Leerzeichen um
cn entfernen)
"Let me guess, you've never heard of Gowin Semiconductor? You have a lot
of company. Gowin, based in Guangdong, China, has been operating quietly
for only the past 20 months. Now, they are announcing their - wait,
what? SECOND FPGA family? Wow, that's fast. Most FPGA startups take
years to announce their first attempts."
"This week, Gowin is announcing their new GW1N family - a two-device
lineup, with 1K and 9K LUTs - of non-volatile FPGAs fabricated with
TSMC's 55nm embedded flash process. These devices probably line up
competitively most closely with Lattice Semiconductor's MachXO3 family
(640 to 6.9K LUT non-volatile FPGAs) and with Altera's MAX 10 (2K to 50K
LUT non-volatile FPGAs). Gowin claims the new devices are targeting the
consumer, industrial, and automotive markets, among others.
Let's take a look at the datasheets and see how GW1N compares with the
most likely competition: The LUT counts weigh in at 1,152 and 8,640 LUTs
(vs 640-6,900 for Lattice, and 2K-50K for Altera). Block RAM at 72K-198K
(vs 64K-240K for Lattice and 108K-1,638K for Altera). User flash
non-volatile memory (NVM) at 96K-1,792K. NOTE: Gowin claims that one
innovation in the GW1N family is this random-access on-chip user flash
memory that can be accessed “just as normal NOR flash memory.” (Lattice
provides up to 256Kb of user-flash, but not random access, and Altera
provides 12K-736K, also not random access.) For many applications, this
on-chip, random access NVM could be a game-changer. GW1N also provides
0-20 18x18 hardware multiplier blocks (vs none for Lattice and 16-144
for Altera). Max user I/O is 120-272 pins (28-335 for Lattice, and
27-500 for Altera)."
Respektabel? Es zeigt wo es lang geht!
Vermutlich auch eine Lücke, in die folgendes stößt:
- http://www.clifford.at/yosys/
- http://www.clifford.at/icestorm/
- https://github.com/cseed/arachne-pnr
Zitat: "We have written many times about the challenges of starting a
new FPGA company. The attempts and failures lists have almost exactly a
1:1 correlation, with Achronix, and now Gowin, being the only current
FPGA startups still alive and kicking, and a handful of other startups
such as SiliconBlue with technology still in use by those who acquired
them. The reasons for failure are almost always the same - immature tool
flows, lack of IP, and weak technical marketing support contributing to
a lack of customer confidence in designing-in devices."
Erleben wir nach baldigem Auslaufen von Patenten neue FPGA Vielfalt mit
Open Source Tools? Mit yosys habe ich selber Designs auf einem Lattice
ICE40 synthetisiert. Nicht zu vergessen: GCC hat die Controllervielfalt
erst ermöglicht, wie sie heute existiert.
VG
Franz
Franz N. schrieb:
> Nicht zu vergessen: GCC hat die Controllervielfalt erst ermöglicht, wie
Weit vor dem GCC gab es doch auch schon alles Mögliche vom 4 Bit uC bis
zum 32 Bitter...
von Michael B. (laberkopp)
FPGAs konnten sich halten und hohe Preise erzielen, weil die NSA fast
die ganzen Fertigungsmengen aufgekauft hat um Daten- und
Telefonüberwachung konfigurierbar und mit den Datenraten mithaltend zu
bauen. Da wird schliesslich on the fly das Ethernet-Protokoll entpackt,
das ZIP Archiv entzippt, die eMail entschlüsselt und nach Schlagworten
durchforstet, bei sich ständig ändernden Standards und Kryptohacks.
Für reale Anwendungen, ausser dem berühmten Kernspintomographen, waren
sie immer zu teuer, das ändert sich auch von GoWin nicht, es kostet
einfach erheblich mehr Siliziumfläche.
von Fitzebutze (Gast)
Auch das ändert sich allmählich. Die kleinen Lattice-Käfer sind billiger
als manche CPU. Mit der Masse an billigen kleinen FPGAs macht Lattice
auch v.a. ihr/sein Geld. Wenn LLVM/OpenSource-Synthesetools da noch
Schule machen, bricht definitiv eine neue Ära an.
von Peter (Gast)
Ich glaube es war schon vor 20 Jahren als man verstanden hat, dass COTS
Teile erheblich billiger zu beziehen sind als sowas spezialisiertes wie
ein FPGA. Auch heute nimmt man für "Supercomputer" lieber eine günstige
Standard CPU als irgendwas spezialisiertes. Wenn man Crypto Aufgaben
hat, dann verwendet man GPUs. Die haben um mehrere Größenordnungen
leistungsfähigere Rechenwerke als die die man mit einem FPGA
implementieren würde. Dazu sind sie auch um ein vielfaches günstiger.
Wenn man sich die Verkaufszahlen von Altera, Xilinx, Lattice und
Konsorten anschaut und sich überlegt wie viele MRTs es gibt dann dürfte
einem vermutlich der Faktor 10^5 fehlen. Es gibt einfach einen
dezidierten Anwendungsbereich für FPGAs und der findet sich definitiv
nicht nur bei MRTs. Es wird immer Bereiche geben in denen FPGAs benötigt
werden und nur schwerlich ersetzt werden können.
von britzl (Gast)
> laberkopp
Der Name ist Programm, gell?
Ansonsten zeig mal Quellen.
Lattice z.B. gutes Beispiel: verkauft wohl kaum was an die NSA weil die
zu schwach dafür sind, aber hat 250 Millionen ICE FPGAs verkauft - ohne
die anderen Serien (MachXO und ECPx).
Mit allen kleinen FPGAs der anderen Hersteller wird die NSA auch kaum
was anfangen können - also alle Spartan, Artix und Cyclone Serien.
Die Preise für FPGAs fangen heutzutage so bei ca. 1 Euro/Stück an, in
größeren Stückzahlen auch weniger.
Genau das ist auch mein Gedankengang. Ich glaube auch an eine neue Ära.
von Seppel (Gast)
in China werden mehr und mehr Chip-Designs entstehen, ich denke dass in
20 Jahren 10-20% der Chips, Analog wie auch Digital, die wir in
Industrie-Produkten einsetzen, chinesische Designs sein werden.
Grüße
Seppel
von Antti L. (xilant)
IceStorm ist wirklich super, vom verilog zu bitstream in weniger
sekunden ohne vendor toools, ohne lizenz auftrag, und so weiter.
https://hackaday.io/project/6636-iced-an-arduino-style-board-with-ice-fpga
auf dieser arduino ist das HX1K drauf, und socket für DIPSY wo man den 1
USD FPGA programmieren kann.
IceStorm bekommt diesen board geschenkt, sobald wir mehr davon haben, zZ
warten wir auf komponentent liferung um den nächsten batch zu fertigen.
hoffentlich wird IceStorm auch den UL1 unterstützen eines tages.
von Lars R. (lrs)
Lieber nicht. Der Lattice UL zielt mit seinen Packages nicht auf einen
Markt, bei dem OpenSource eine besondere Bedeutung hätte. Er zielt
vielmehr auf große Firmen, die große Stückzahlen abnehmen, wo die
Entwicklungskosten prozentuell geringer sind und die Zusatzkosten für
zusätzliche Lagen oder Highend-Prozesse aufgrund hoher Stückzahlen
gering sind. Er zielt auf Produkte, wo jeder einzelne Cent am FPGA-Preis
gezählt wird. Vielleicht steckt er in ein paar Smartphones (Foto-LED)
und Hintergrundbeleuchtungen.
Besonders interessant werden Opensource-Toolchains beispielsweise bei
großen FPGAs, wo die Hersteller der Synthese-Tools noch viel Geld sehen
wollen.
Bei Opensource-FPGAs oder kleinen FPGA-Firmen sind/waren wiederrum auch
die "kleinen Beträge", die für "kleine" FPGAs aufgrund der Synthesetools
abzuführen sind, eine Kostenkomponente.
Ein weiterer Aspekt ist Security. Im FPGA-Bereich herrscht noch security
by obscurity vor und die Probleme wurden/werden unterdrückt und
totgeschwiegen. Die Verschlüsselung eines von außerhalb geladenen
Bitstreams nützt hierbei gar nichts, solang die Entschlüsselung gut
beobachtet werden kann, weil sie nicht massiv parallel abläuft.
Opensource-Tools ermöglichen Reverse Engineering einem größeren
Anwendungskreis. Aber das bedeutet ja nicht, dass es bisher nicht
möglich ist.
Lattice und Altera haben den Flash im FPGA, nutzen aber genau wie Xilinx
SRAM-Konfigurationen. Man muss aber, um an Stream zu kommen, zumeist
wenigstens das Package öffnen, so wie man es bei jedem uC für 50Cent
auch tun muss.
Die aufgeführten Beschreibungen des chinesischen Gowin (instant-on,
random access flash-Zugriff,...) deuten darauf hin, dass dort das Design
nicht aus einem, im FPGA-package befindlichen, Flashspeicher geladen
wird, sondern dass jede Konfigurationszelle ihren eigenen Flash hat.
Solche Technologie bietet derzeit lediglich Microsemi (Actel) mit
entsprechendem Preiszuschlag. Dort ist der Aufwand für das Auslesen sehr
hoch, insofern nicht doch irgendein Backdoor/Fehler von der
Konfigurations-Chain genutzt werden kann. Diese Technologie ist auch
besonders für Avionics geeignet, weil die Flash-Zelle viel später kippt,
als die SRAM-Zelle. Das Thema hatten wir hier im Forum kürzlich schon
einmal. Andererseits ist der eingebaute, kontinuierliche Check der
SRAM-Konfiguration über eine CRC-Prüfsumme, beispielsweise Altera MAX10,
für manche ohnehin redundant ausgeführte Systeme vielleicht auch
ausreichend.
> Teile erheblich billiger zu beziehen sind als soetwas spezialisiertes wie
Dies hat vor allem damit zu tun, dass die Entwicklungskosten für ein
FPGA-Design höher sind, als die Entwicklungskosten für Software mit der
gleichen Funktionalität.
IceStorm unterstützt
HX1K
und HX1K ist von resourcen KLEINER als UL1K, da sehe ich keinen grund
warum es nicht macht das IceStorm auch den UL1K unterstützen würde.
ICE software von Lattice ist natürlich auch KOSTENLOS, muss kein geld
ausgeben.
von Weltbester FPGA Pongo (Gast)
Ich korrigiere mal ein wenig: FPGAs sind durchaus so ziemlich überall
drin, wo ein bischen mehr gemacht wird, als I2C-ADC.
- Anbindung an high Speed ADCs
- Präprozessierung durch GOC, AGC, FFT
- Anbindung von Bildsensoren
- Präprozessierung Defektoixelkorrekturen, Binning,
- GigaEthernet-Cores
- USB 3.0
- fiber optic GBT
Geräte:
- Radare
- Magentresonanz-Tomographen
- Ultraschall
- Röntgentechnik
- Infraschall
- Infrarotdetektoren
- Gammastrahler
- Geigerzähler
- Hochpräzisionstimer
- Video-Prozessor-Geräte
- Audio-Prozessor-Geräte
Neuerdings auch TV-Geräte, Audiomonitore
Auch das hat sich kräftig geändert, seit es effektive Tools wie MyHDL
und einige OpenSource Co-Simulations-Lösungen gibt. Mit entsprechenden
SoCs ist man u.U. schneller bei einer robusten Lösung als mit einem
COTS-uC, da das komplette System von A-Z durchsimuliert werden kann. Das
zahlt sich dann aus, wenn man irgendwelche non-standard-Interfaces mit
einem spezielle Timing ansteuern muss.
Na, ich bin mal gespannt, wie die Chinesen das hinkriegen und wann die
ersten Distis drauf aufspringen.
von Lars R. (lrs)
> SoCs ist man u.U. schneller...
Daran wird sich meiner Ansicht nie etwas ändern, weil auch die
Entwicklungskosten für Software sinken. Ob die SW dann auf COTS-uC oder
der Embedded CPU des SoC läuft, sei dahin gestellt....
Meine Ausage war, dass nicht nur die Materialbezugskosten, sondern auch
die Entwicklungskosten entscheidend sind. Du schreibst, dass für
bestimmte Aufgaben (die inzwischen verfügbaren) SoCs besser geeignet
sind, als COTS-uC. Ich sehe kein Gegenargument, sondern Zustimmung.
Die Westlichen nie.
