EmbDev.net
Forum: µC & Digital Electronics Single Master-Multiple slaves implementation of SPI
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von Aditya K. (stadkama)
Rate this post
useful
not useful
Hello,
Im trying to implement single master(atsam4e8c) and multiple
slave(sensors-all are same) Spi. I have few questions regarding this.
I have initialized the master in my code. I took reference of
initializing master in of the forums here.
1.However,Do I need to initialize the sensors(slaves) in my code?
2.How do I call 6 slaves one by one in the code?
Thank you for your inputs. Please let me know for any information do I
need to provide.
von Chriss (Guest)
Rate this post
useful
not useful
-CS (Chip Select) signals
OR
-Daisy Chain Slaves
Rate this post
useful
not useful
Hello Chriss
 It is based on chip select signals.
Rate this post
useful
not useful
I have seen the post from Jörg Wunsch regarding this. However I have few
questions.
von doppelschwarz (Guest)
Rate this post
useful
not useful
The slaves are all on the same MOSI line, but they listen only if their
SS is low. So you have to set the SS_Slave0 pin low and send the data,
read on MISO_Slave1 (or MISO if it is only one line). Then start slave1
and so on.
Initializing slaves is normally done by sending some messages to them, I
think displays work this way (send settings first, then data to show).
If your sensor needs it is shown in its datasheet. Don't mix it with SPI
slave initiliazing of your controller.
von Lothar M. (Company: Titel) (lkmiller) (Moderator)
Rate this post
useful
not useful
You can't.
SPI simply are 2 concatenated shift registers: one in the master and one
in the slave. So you cannot select 6 slaves at the same time. You must
select one after the other.
Or you must connect them in a daisy chain (if the sensors are able to
handle that).
> multiple slave(sensors-all are same)
Which ones? Type? Datasheet?
That information can be found in the sensors datasheet only...
Rate this post
useful
not useful
those are inertial sensors.I need to read the values from those
sensors.If i need to initialize all the 6 sensors, is it to be done when
I select the particular chip select?
: Edited by User
von karl heinz (Guest)
Rate this post
useful
not useful
As a guideline:
to communicate with one of the sensors you need to pull the chip select
wire for that sensor low. Otherwise the sensor will ignore everything
happening one the MOSI Line.
If you need to give some initialiszation to the sensor can be found in
the datasheet of that sensor. There is no difference between one sensor
and a bunch of them. Each sensor ignores the SPI bus unless its Chip
Select Input is pulled low.
You need to differntiate between the communication on a technical level
(the SPI bus) and what needs to be sent on that bus. The former is a
technical thing how the SPI bus works in principle. The later is
dependend on the client and can be found in its datasheet.
Rate this post
useful
not useful
bmi160 inertial sensors
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
