1 | Arduino: 1.0.6 (Windows Vista), Board: "Arduino Micro"
2 |
3 | C:\Program Files\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -MMD -DUSB_VID=0x2341 -DUSB_PID=0x8037 -DARDUINO=106 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\micro -IC:\Program Files\Arduino\libraries\LiquidCrystal -IC:\Program Files\Arduino\libraries\Wire -IC:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master -IC:\Program Files\Arduino\libraries\Adafruit_SSD1306 -IC:\Program Files\Arduino\libraries\SPI C:\Users\thomas\AppData\Local\Temp\build3060804281612396710.tmp\Firmware.cpp -o C:\Users\thomas\AppData\Local\Temp\build3060804281612396710.tmp\Firmware.cpp.o
4 | Firmware.ino: In function 'void loop()':
5 | Firmware.ino:95: warning: unused variable 'rpm'
6 | C:\Program Files\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -MMD -DUSB_VID=0x2341 -DUSB_PID=0x8037 -DARDUINO=106 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\micro -IC:\Program Files\Arduino\libraries\LiquidCrystal -IC:\Program Files\Arduino\libraries\Wire -IC:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master -IC:\Program Files\Arduino\libraries\Adafruit_SSD1306 -IC:\Program Files\Arduino\libraries\SPI -IC:\Program Files\Arduino\libraries\LiquidCrystal\utility C:\Program Files\Arduino\libraries\LiquidCrystal\LiquidCrystal.cpp -o C:\Users\thomas\AppData\Local\Temp\build3060804281612396710.tmp\LiquidCrystal\LiquidCrystal.cpp.o
7 | C:\Program Files\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -MMD -DUSB_VID=0x2341 -DUSB_PID=0x8037 -DARDUINO=106 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\micro -IC:\Program Files\Arduino\libraries\LiquidCrystal -IC:\Program Files\Arduino\libraries\Wire -IC:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master -IC:\Program Files\Arduino\libraries\Adafruit_SSD1306 -IC:\Program Files\Arduino\libraries\SPI -IC:\Program Files\Arduino\libraries\Wire\utility C:\Program Files\Arduino\libraries\Wire\Wire.cpp -o C:\Users\thomas\AppData\Local\Temp\build3060804281612396710.tmp\Wire\Wire.cpp.o
8 | C:\Program Files\Arduino\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -MMD -DUSB_VID=0x2341 -DUSB_PID=0x8037 -DARDUINO=106 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\micro -IC:\Program Files\Arduino\libraries\LiquidCrystal -IC:\Program Files\Arduino\libraries\Wire -IC:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master -IC:\Program Files\Arduino\libraries\Adafruit_SSD1306 -IC:\Program Files\Arduino\libraries\SPI -IC:\Program Files\Arduino\libraries\Wire\utility C:\Program Files\Arduino\libraries\Wire\utility\twi.c -o C:\Users\thomas\AppData\Local\Temp\build3060804281612396710.tmp\Wire\utility\twi.c.o
9 | C:\Program Files\Arduino\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -MMD -DUSB_VID=0x2341 -DUSB_PID=0x8037 -DARDUINO=106 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\micro -IC:\Program Files\Arduino\libraries\LiquidCrystal -IC:\Program Files\Arduino\libraries\Wire -IC:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master -IC:\Program Files\Arduino\libraries\Adafruit_SSD1306 -IC:\Program Files\Arduino\libraries\SPI -IC:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\utility C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\glcdfont.c -o C:\Users\thomas\AppData\Local\Temp\build3060804281612396710.tmp\Adafruit-GFX-Library-master\glcdfont.c.o
10 | C:\Program Files\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -MMD -DUSB_VID=0x2341 -DUSB_PID=0x8037 -DARDUINO=106 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\micro -IC:\Program Files\Arduino\libraries\LiquidCrystal -IC:\Program Files\Arduino\libraries\Wire -IC:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master -IC:\Program Files\Arduino\libraries\Adafruit_SSD1306 -IC:\Program Files\Arduino\libraries\SPI -IC:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\utility C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp -o C:\Users\thomas\AppData\Local\Temp\build3060804281612396710.tmp\Adafruit-GFX-Library-master\Adafruit_GFX.cpp.o
11 | In file included from C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp:35:
12 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\/glcdfont.c:18: warning: only initialized variables can be placed into program memory area
13 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp: In member function 'void Adafruit_GFX::drawChar(int16_t, int16_t, unsigned char, uint16_t, uint16_t, uint8_t)':
14 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp:549: warning: unused variable 'xa'
15 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp: In member function 'boolean Adafruit_GFX_Button::contains(int16_t, int16_t)':
16 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp:914: warning: comparison between signed and unsigned integer expressions
17 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp:914: warning: comparison between signed and unsigned integer expressions
18 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp:915: warning: comparison between signed and unsigned integer expressions
19 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp:915: warning: comparison between signed and unsigned integer expressions
20 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp: In member function 'virtual void GFXcanvas1::drawPixel(int16_t, int16_t, uint16_t)':
21 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp:963: warning: only initialized variables can be placed into program memory area
22 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp:964: warning: only initialized variables can be placed into program memory area
23 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp: In member function 'void Adafruit_GFX::drawBitmap(int16_t, int16_t, const uint8_t*, int16_t, int16_t, uint16_t)':
24 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp:371: warning: 'byte' may be used uninitialized in this function
25 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp: In member function 'void Adafruit_GFX::drawBitmap(int16_t, int16_t, const uint8_t*, int16_t, int16_t, uint16_t, uint16_t)':
26 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp:389: warning: 'byte' may be used uninitialized in this function
27 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp: In member function 'void Adafruit_GFX::drawBitmap(int16_t, int16_t, uint8_t*, int16_t, int16_t, uint16_t)':
28 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp:406: warning: 'byte' may be used uninitialized in this function
29 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp: In member function 'void Adafruit_GFX::drawBitmap(int16_t, int16_t, uint8_t*, int16_t, int16_t, uint16_t, uint16_t)':
30 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp:422: warning: 'byte' may be used uninitialized in this function
31 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp: In member function 'void Adafruit_GFX::drawXBitmap(int16_t, int16_t, const uint8_t*, int16_t, int16_t, uint16_t)':
32 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp:441: warning: 'byte' may be used uninitialized in this function
33 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp: In member function 'void Adafruit_GFX::drawChar(int16_t, int16_t, unsigned char, uint16_t, uint16_t, uint8_t)':
34 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp:553: warning: 'yo16' may be used uninitialized in this function
35 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp:553: warning: 'xo16' may be used uninitialized in this function
36 | C:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_GFX.cpp:552: warning: 'bits' may be used uninitialized in this function
37 | C:\Program Files\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega32u4 -DF_CPU=16000000L -MMD -DUSB_VID=0x2341 -DUSB_PID=0x8037 -DARDUINO=106 -IC:\Program Files\Arduino\hardware\arduino\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\variants\micro -IC:\Program Files\Arduino\libraries\LiquidCrystal -IC:\Program Files\Arduino\libraries\Wire -IC:\Program Files\Arduino\libraries\Adafruit-GFX-Library-master -IC:\Program Files\Arduino\libraries\Adafruit_SSD1306 -IC:\Program Files\Arduino\libraries\SPI -IC:\Program Files\Arduino\libraries\Adafruit_SSD1306\utility C:\Program Files\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp -o C:\Users\thomas\AppData\Local\Temp\build3060804281612396710.tmp\Adafruit_SSD1306\Adafruit_SSD1306.cpp.o
38 | C:\Program Files\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp: In member function 'virtual void Adafruit_SSD1306::drawPixel(int16_t, int16_t, uint16_t)':
39 | C:\Program Files\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp:111: error: 'swap' was not declared in this scope
40 | C:\Program Files\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp: In member function 'virtual void Adafruit_SSD1306::drawFastHLine(int16_t, int16_t, int16_t, uint16_t)':
41 | C:\Program Files\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp:513: error: 'swap' was not declared in this scope
42 | C:\Program Files\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp: In member function 'virtual void Adafruit_SSD1306::drawFastVLine(int16_t, int16_t, int16_t, uint16_t)':
43 | C:\Program Files\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp:581: error: 'swap' was not declared in this scope
