EmbDev.net
Forum: Analog Circuits underwater locator beacon: why not chirp?
Du wurdest von Mikrocontroller.net auf diese Seite weitergeleitet. Zurück zu Mikrocontroller.net
von apinger (Guest)
Rate this post
useful
not useful
Hi
in light of the recent aircraft accidents, i was wondering why the
locator beacons are fixed frequency at 37 kHz. Wouldn't it be better if
they emit a known time structure e.g. Chirp or the like. That would not
only make the range much better but also virtually remove the
possibility of spurious signals. Any ideas why they don't do that?
von Bernhard (Guest)
Rate this post
useful
not useful
The ultrasonic transducer is probably narrow band with a bandwidth of
around 1 kHz. That is why you can not transmit any broadband pulse like
a chirp.
von mscho (Guest)
Rate this post
useful
not useful
I guess its due to the fact that the overwhelming amount of the pingers
will never be used in all their lifetime - so they try to keep this as
cheap as possible but still functioning. Making the transducer resonant
to a single frequency keeps it loud but still energy efficient enough to
work for a month.
von Lurchi (Guest)
Rate this post
useful
not useful
Resonant emitters are usually more energy efficient. There could be
still a slow modulation like a pulse structure (e.g. 1 pulse of 0.5
seconds every 10 seconds) if the power is limited by the battery and not
by the transducer.
For me the question is a little why they choose such a high frequency.
Lower frequency sound has less damping and thus a longer range.
von mscho (Guest)
Rate this post
useful
not useful
Its still low enough to not be confused with echo transducers from
ships' depth measuring equipment in the 100-200kHz range and high enough
to be no natural sound. It also requires larger transducers to emit
deeper sounds efficently and both size and weigth is limited in aircraft
equipment.
von William (Guest)
Rate this post
useful
not useful
These are flat water echo sounders only.
For deep water echo sounders are using frequencies in the 50 kHz range.
Have a look to Raymarine or what ever.
Echosounder for fishery requirements use a broad range of transducer at
38 kHz and many other frequencies.
SimRad
https://www.simrad.com/www/01/nokbg0240.nsf/AllWeb/3E3ABDF14A22990DC12570AD0034AD3B?OpenDocument
von apinger (Guest)
Rate this post
useful
not useful
38 kHz seems like a bad choice for fish finders. one fishing vessel in
proximity and boom fake signal. The power of these sonars is immense and
sind can be guided over long distances between water layers.
von apinger (Guest)
Rate this post
useful
not useful
Newer ones come in sub 10 kHz also and are mandatory now.
Please log in before posting. Registration is free and takes only a minute.
Existing account
Do you have a Google/GoogleMail account? No registration required!
Log in with Google account
No account? Register here.
