1 | // during an alarm the INT pin of the RTC is pulled low
2 | //
3 | // this is handy for minimizing power consumption for sensor-like devices,
4 | // since they can be started up by this pin on given time intervals.
5 |
6 | #include <Wire.h>
7 | #include "ds3231.h"
8 |
9 | #define BUFF_MAX 256
10 |
11 | // time when to wake up
12 | uint8_t wake_HOUR = 15;
13 | uint8_t wake_MINUTE = 49;
14 | uint8_t wake_SECOND = 9;
15 |
16 | // how often to refresh the info on stdout (ms)
17 | unsigned long prev = 5000, interval = 5000;
18 |
19 | void set_alarm(void)
20 | {
21 |
22 | // flags define what calendar component to be checked against the current time in order
23 | // to trigger the alarm - see datasheet
24 | // A1M1 (seconds) (0 to enable, 1 to disable)
25 | // A1M2 (minutes) (0 to enable, 1 to disable)
26 | // A1M3 (hour) (0 to enable, 1 to disable)
27 | // A1M4 (day) (0 to enable, 1 to disable)
28 | // DY/DT (dayofweek == 1/dayofmonth == 0)
29 | uint8_t flags[5] = { 0, 0, 0, 1, 1 };
30 |
31 | // set Alarm1
32 | DS3231_set_a1(wake_SECOND, wake_MINUTE, wake_HOUR, 0, flags);
33 |
34 | // activate Alarm1
35 | DS3231_set_creg(DS3231_INTCN | DS3231_A1IE);
36 | }
37 |
38 | void setup()
39 | {
40 | Serial.begin(9600);
41 | Wire.begin();
42 | DS3231_init(DS3231_INTCN);
43 | DS3231_clear_a1f();
44 | set_alarm();
45 |
46 | }
47 |
48 | void loop()
49 | {
50 | char buff[BUFF_MAX];
51 | unsigned long now = millis();
52 | struct ts t;
53 |
54 | // once a while show what is going on
55 | if ((now - prev > interval) && (Serial.available() <= 0)) {
56 | DS3231_get(&t);
57 |
58 | // display current time
59 | snprintf(buff, BUFF_MAX, "%d.%02d.%02d %02d:%02d:%02d", t.year,
60 | t.mon, t.mday, t.hour, t.min, t.sec);
61 | Serial.println(buff);
62 |
63 | // display a1 debug info
64 | DS3231_get_a1(&buff[0], 59);
65 | Serial.println(buff);
66 |
67 | if (DS3231_triggered_a1()) {
68 | // INT has been pulled low
69 | Serial.println(" -> alarm1 has been triggered");
70 | // clear a1 alarm flag and let INT go into hi-z
71 | DS3231_clear_a1f();
72 | }
73 | prev = now;
74 | }
75 | }
