Forum: Markt PCI-1202H : 32-ch, 12-bit, 40KS/s PCIMesskarte, neu (ICPDAS
von Mario H. (djacme)
http://www.icpdas.com/products/DAQ/pc_based/pci_1200.htm
Habe noch eine neue PCI-12 Bit Messkarte in IPCDAS liegen die ich hier
ganz gerne Verkaufen würde. Der Neupreis beträgt 360 Euro, ich dachte
so an 100 Euro. Software ist dabei.
# 12-bit 110KHz A/D converter
# PCI-1202H, 32 single-ended/ 16 differential inputs, 1K word FIFO
buffer
# The sampling rates of single channel or multiple channels is 40K
samples/s
# Three different external trigger : post-trigger, pre-trigger, middle
trigger
# 16 digital input / 16 digital output channels
# PCI-1202H provides programmable high gain: 0.5, 1, 5, 10, 50, 100,
500, 1000.
# Internal / external trigger.
# Two 12-bit independent programmable DAC.; 2 MHz throughput per
channel (maxi)
# 2.7 M word /high speed data transfer rate.
