LCD WINTREX WD-C2704M-1HNN (von Pollin) so funktioniert es '$regfile = "m16def.dat" 'definieren des verwendeten Chips $regfile = "m32def.dat" '------------------------------------------------------------------ ' demo shows 4 bit LCD mode with 2 E lines '------------------------------------------------------------------ $crystal = 8000000 $baud = 4800 ' NMEA Schnittstelle Dim ___lcdno as Bit Config Lcdpin = Pin , Db4 = Portc.3 , Db5 = Portc.4 , Db6 = Portc.5 , Db7 = Portc.6 , E = Portc.1 , E2 = Portc.2 , Rs = Portc.0 Config Lcd = 40*4 Initlcd Cursor Off Do ___lcdno = 0 Initlcd Cls Cursor Off Home Locate 1 , 1 Lcd "dein Text1" 'Text in Zeile 1 Locate 2 , 1 Lcd "Text1" 'Text in Zeile 2 Wait 1 ___lcdno = 1 Initlcd Cls Cursor Off Home Locate 1 , 1 Lcd "dein Text2" 'Text in Zeile 3 Locate 2 , 1 Lcd "Text2" 'Text in Zeile 4 Waitms 1 Wait 1 Loop End
> LCD WINTREX WD-C2704M-1HNN (von Pollin) > so funktioniert es Schön... - So funktioniert(e) es auch: http://www.mikrocontroller.net/forum/read-1-164017.html#164026 http://www.mikrocontroller.net/forum/forum.php?query=%2Blcd+%2B4x27&forums%5B%5D=1&number=100&action=sendsearch ...
