Nochmal eine Frage,
Kann es sein, dass wenn die Structs, die in der Union sind,
gleichnamige member haben, es Probleme geben kann?
Folgende Meldung spuckt der Compiler bei folgendem Code aus:
1 | //Header-page on disk
2 | struct t_diskheader
3 | {
4 | u08 diskname[64]; //Name of disk
5 | u32 p_root; //Pointer to root-dir
6 | u32 disksize; //size of disk in kb
7 | };
8 |
9 | //a headerpage is a page, which contains file-/dirheader-information
10 | only
11 | struct t_headerpage
12 | {
13 | u32 p_nextpage; //pointer to next page in chain
14 | u16 validbytes; //# of valid bytes in this page
15 | u16 hdrreserved; //2 bytes reserved
16 |
17 | u32 tcreate; //time of creation
18 | u32 tlastaccess; //time of last access
19 | u32 tlastchange; //time of last change
20 | u08 objname[256]; //256-char name of file/dir
21 | u32 p_parent; //pointer to parent dir
22 | u08 headertype; //0 = DIR, 1 = FILE
23 | u08 attribflags; //Atrribute of file/dir
24 | u32 filesize; //size of file (if dir, then filesize = 0!)
25 | u08 reserved[226]; //Reserved
26 | };
27 |
28 | //t_dirdata is a page, which contains 126 dir entrys
29 | struct t_dirdata
30 | {
31 | u32 p_nextpage; //pointer to next page in chain
32 | u16 validbytes; //# of valid bytes in this page
33 | u16 hdrreserved; //2 bytes reserved
34 |
35 | u32 dir_entry[126]; //holds pointer to linked dir/file. max 126
36 | };
37 |
38 | //t_filedata is a page, which holds 504b filedata
39 | struct t_filedata
40 | {
41 | u32 p_nextpage; //pointer to next page in chain
42 | u16 validbytes; //# of valid bytes in this page
43 | u16 hdrreserved; //2 bytes reserved
44 |
45 | u08 data[504]; //504b + 8 bytes header = 512byte
46 | };
47 |
48 | //Union of one page.
49 | union u_page
50 | {
51 | u08 raw[512];
52 | struct t_filedata;
53 | struct t_dirdata;
54 | struct t_headerpage;
55 | struct t_diskheader;
56 | };
error C2020: 'p_nextpage' : 'union' member redefinition
error C2020: 'validbytes' : 'union' member redefinition
error C2020: 'hdrreserved' : 'union' member redefinition
Ist es vielleicht sinnvoll, eine neue struct mit den jeweils 3 gleichen
membern zu machen und diese jeweils in die structs t_headerpage,
t_dirdata und t_filedata einzubeziehen?
