Forum: Markt Verkaufe MSP430-Entwicklungsset
von Greeni .. (greenland)
ich biete wegen Zeitmangels folgendes MSP430-Entwicklungsset an:
- Das große MSP430 Praxisbuch (Gebundene Ausgabe, 441 Seiten, Franzis
Februar 2004, ISBN: 377234299X)
- MSP430 14 Pin Package Board and JTAG USB Programmer:
Overview
The MSP-FET430U14 is a powerful tool that includes the hardware and
software required to complete much of your application development
work.
The flash memory can be erased and programmed in seconds with only a
few keystrokes, and since the MSP430 flash is extremely low power, no
external power supply is required.
The tool has an integrated software environment and connects directly
to the USB port of a PC which greatly simplifies the set-up and use of
the tool. The flash development tool supports development with the
MSP430 flash parts in 14 pin TSSOP packages (TI package code: PW).
Features
FET development board with a ZIF socket fitting MSP430 derivatives in
14 pin TSSOP packages, LED indicator, USB to JTAG adapter, cables and
header pinouts for prototyping Two MSP430F2013IPW flash devices
Integrated IAR Kickstart user interface which includes an assembler,
linker, simulator, source-level debugger and limited C-compiler Full
documentation on CD-ROM.
- ez430 MSP430 USB Stick Development Tool
Overview
The eZ430-F2013 is a powerful development tool that provides both the
USB based programmer and F2013 development board in a small USB stick
package. The flash memory can be erased and programmed in seconds with
only a few keystrokes, and since the MSP430 flash is extremely low
power, no external power supply is required. The tool has an integrated
software environment and connects directly to the USB port of a PC which
greatly simplifies the set-up and use of the tool. The flash development
tool supports development with the MSP430F20xx devices.
Tool Contains:
    * USB Programmer with a Spy-Bi-Wire interface to an F2013
development board.
    * Integrated IAR Kickstart user interface which includes an
assembler, linker, simulator, source-level debugger and limited
C-compiler.
    * Full documentation on CD-ROM
Die Tools sind kaum benutzt, Neupreis zusammen rund 230 EUR, Angebote
bitte per Email an greenland [ät] gmx de.
Da sich hier leider niemand gemeldet hat, ist das Angebot nun hier zu
finden:
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=260031262583
von Tobias (Gast)
> Da sich hier leider niemand gemeldet hat [...]
LOL, dein Beitrag steht hier ja auch schon mehrere Wochen!
von amoc (Gast)
...wäre im Forum "Markt" ja vielleicht auch besser aufgehoben...
von arsch (Gast)
also sosdf
Sorry, hatte die entsprechende Rubrik übersehen.
Bitte verschieben, danke!
Vielen Dank fürs Verschieben. Das Angebot läuft noch bis:
23.09.06 - 19:49:19 MESZ
Die Auktion läuft heute abend um 19:49 Uhr aus. Bitte löscht morgen den
Thread.
Momentan beobachten 11 Personen die Auktion, die Seite wurde 177 mal
besucht.
ich habe jetzt nochmal neu eingestellt, weil die Auktion nicht
erfolgreich war. Ich hatte wohl nicht klar genug darauf hingewiesen,
daß unter anderem ein SMD-ZIF-Adapter mit enthalten ist, der alleine
normalerweise schon recht teuer ist. Die Auktion läuft nochmal für 3
Tage hier:
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=260034972880
Ein besseres Bild findet sich im Anhang.
Grüße
Michael
Ich biete wegen Zeitmangels folgendes MSP430-Entwicklungsset an:
- Das große MSP430 Praxisbuch (Gebundene Ausgabe, 441 Seiten, ISBN:
377234299X) - NP: EUR 49,95
- MSP-FET430U14: 14 Pin Package Board + JTAG USB Programmer - NP: rund
USD 200 (inkl. Zoll und MwSt.)
Enthalten ist u.a. ein sonst sehr teuerer SMD-ZIF-Adapter zum
kontaktieren & programmieren der Bauteile (siehe vergrößerten
Ausschnitt auf dem Foto). Ausserdem ist ein hochwertiges
USB-JTAG-Interface enthalten.
Beschreibung: The MSP-FET430U14 is a powerful tool that includes the
hardware and software required to complete much of your application
development work. The flash memory can be erased and programmed in
seconds with only a few keystrokes, and since the MSP430 flash is
extremely low power, no external power supply is required.
- ez430 MSP430 USB Stick Development Tool - NP bei Conrad Elektronik
knapp 30 EUR
Enthält u.a. einen USB-Programmer inkl. einem MSP430F2013, IAR
Kickstart IDE mit Assembler, Linker, Simulator, Debugger und
limitiertem C-Compiler und Dokumentation auf CD-ROM
Beschreibung: The eZ430-F2013 is a powerful development tool that
provides both the USB based programmer and F2013 development board in a
small USB stick package. The flash memory can be erased and programmed
in seconds with only a few keystrokes, and since the MSP430 flash is
extremely low power, no external power supply is required. The tool has
an integrated software environment and connects directly to the USB port
of a PC which greatly simplifies the set-up and use of the tool. The
flash development tool supports development with the MSP430F20xx
devices.
