Forum: Mikrocontroller und Digitale Elektronik PWM-Programm auf AT91SAM7S-EK
Autor: Mirko (Gast)
Moin.
Habe auf die schnelle PWM-Beispiel (sehe Anhang) auf AT91SAM7S-EK-Board
geflascht. Kann jedoch nirgendwo eine PWM entdecken. Laut Beispiel ist
der PWM-Ausgang am PA11, oder? Wieso ist da kein Signal?
Autor: Mirko (Gast)
Ich verwende folgenden Code(unten). Es sollte doch am PA11 4792Hz
anliegen, oder?
// Include Standard files
#include "Board.h"
/*  In this project we are assuming to have master clock equal to
47.9232 MHz
    on the AT91SAM7SEK.*/
/*    PWM Clock source Domain */
#define         MCKtoPWM      0
#define         MCK_2toPWM    1
#define         MCK_4toPWM    2
#define         MCK_8toPWM    3
#define         MCK_16toPWM   4
#define         MCK_32toPWM   5
#define         MCK_64toPWM   6
#define         MCK_128toPWM  7
#define         MCK_256toPWM  8
#define         MCK_512toPWM  9
#define         MCK_1024toPWM 10
#define         CLHAtoPWM     11
#define         CLHBtoPWM     12
#define         CALG_OFF       0
#define         CALG_ON       1<<8  // The period is center aligned
(OFF, left aligned)
#define         CPOL_OFF      0<<0  // The ouput waveform starts at a
high level (OFF, low level)
#define         CPOL_ON       1<<9  // The ouput waveform starts at a
#define         CPD_ON        1<<10 // The period will be modified at
the next period start event
#define         CPD_OFF       0<<10
/* Select the wanted frequency in hertz.
This choice has to be in accordance with the selected clock source */
#define   FREQUENCY    4792  // In Hertz
/* In our example, we are targetting to get out 100 Hertz frequency. In
this goal, we use MCK_256toPWM */
#define   PWM_PERIOD_VALUE            (MCK/(1*FREQUENCY))
//* Function Name       : Main
//* Object              : Software entry point
//* Input Parameters    : none.
//* Output Parameters   : none.
int main()
        /* Valid the PWM's Clock at PMC level */
        AT91F_PMC_EnablePeriphClock(AT91C_BASE_PMC,1<<AT91C_ID_PWMC);
        /* Disable the PWM the channel 0 */
        AT91C_BASE_PWMC->PWMC_DIS = 0x1;
        /* Enabling a PWM output through the PA11: PWM Channel 0*/
        AT91F_PIO_CfgPeriph(AT91C_BASE_PIOA, 0, AT91C_PA11_PWM0);
        /* Period Updating */
        AT91C_BASE_PWMC_CH0->PWMC_CMR = (CPD_ON | CPOL_OFF | CALG_OFF |
MCKtoPWM);
        AT91C_BASE_PWMC_CH0->PWMC_CPRDR=PWM_PERIOD_VALUE;
        /* Duty Cycle Updating */
        AT91C_BASE_PWMC_CH0->PWMC_CMR = (CPD_OFF | CPOL_OFF | CALG_OFF |
MCKtoPWM);
        AT91C_BASE_PWMC_CH0->PWMC_CDTYR = 0x01;
        /* Interrupt enabling at peripheral level only in order to have
synchronisation between
        Software and the UP-DATE Register (to avoid over writting) */
        AT91C_BASE_PWMC->PWMC_IER = 1;
        /* Enable the PWM the channel 0*/
        AT91C_BASE_PWMC->PWMC_ENA = 0x1;
        /* Infinit loop to avoid getting out */
        while (1) ;
//* End
