Forum: Mikrocontroller und Digitale Elektronik Selbstdef.Zeichen
Autor: Patrick Schnotalle (pepper)
Durch das Datenblatt hab ich das bis jetzt so verstanden,so
funktionierts aber leider noch nicht.Das ist nur die Definition-Habs dnn
wie ein normals ASCII Zeichen von Adresse 00 versucht aufzurufen,auf was
muss ich denn noch achten???(die hilfe wenns geht auch in assembler)
SELBSTDEF       mov       #1, R10
              mov       #004h, R11
              call      #SEND
              mov       #1, R10
              mov       #000h, R11
              call      #SEND
              bis.b           #BIT0, &P3OUT
              mov       #1, R10
              mov       #00h, R11
              call      #SEND
              mov       #1, R10
              mov       #004h, R11
              call      #SEND
              bic.b     #BIT0, &P3OUT
              mov       #1, R10
              mov       #004h, R11
              call      #SEND
              mov       #1, R10
              mov       #001h, R11
              call      #SEND
              bis.b           #BIT0, &P3OUT
              mov       #1, R10
              mov       #00h, R11
              call      #SEND
              mov       #1, R10
              mov       #004h, R11
              call      #SEND
              bic.b     #BIT0, &P3OUT
               mov       #1, R10
              mov       #004h, R11
              call      #SEND
              mov       #1, R10
              mov       #002h, R11
              call      #SEND
              bis.b           #BIT0, &P3OUT
              mov       #1, R10
              mov       #00h, R11
              call      #SEND
              mov       #1, R10
              mov       #004h, R11
              call      #SEND
              bic.b     #BIT0, &P3OUT
               mov       #1, R10
              mov       #004h, R11
              call      #SEND
              mov       #1, R10
              mov       #003h, R11
              call      #SEND
              bis.b           #BIT0, &P3OUT
              mov       #1, R10
              mov       #00h, R11
              call      #SEND
              mov       #1, R10
              mov       #004h, R11
              call      #SEND
              bic.b     #BIT0, &P3OUT
               mov       #1, R10
              mov       #004h, R11
              call      #SEND
              mov       #1, R10
              mov       #004h, R11
              call      #SEND
              bis.b           #BIT0, &P3OUT
              mov       #1, R10
              mov       #001h, R11
              call      #SEND
              mov       #1, R10
              mov       #005h, R11
              call      #SEND
              bic.b     #BIT0, &P3OUT
               mov       #1, R10
              mov       #004h, R11
              call      #SEND
              mov       #1, R10
              mov       #005h, R11
              call      #SEND
              bis.b           #BIT0, &P3OUT
              mov       #1, R10
              mov       #00h, R11
              call      #SEND
              mov       #1, R10
              mov       #00Eh, R11
              call      #SEND
              bic.b     #BIT0, &P3OUT
               mov       #1, R10
              mov       #004h, R11
              call      #SEND
              mov       #1, R10
              mov       #006h, R11
              call      #SEND
              bis.b           #BIT0, &P3OUT
              mov       #1, R10
              mov       #00h, R11
              call      #SEND
              mov       #1, R10
              mov       #004h, R11
              call      #SEND
              bic.b     #BIT0, &P3OUT
               mov       #1, R10
              mov       #004h, R11
              call      #SEND
              mov       #1, R10
              mov       #007h, R11
              call      #SEND
              bis.b           #BIT0, &P3OUT
              mov       #1, R10
              mov       #00h, R11
              call      #SEND
              mov       #1, R10
              mov       #00h, R11
              call      #SEND
              bic.b     #BIT0, &P3OUT
              ret
Würd gern wissen aus welchen Grund das nicht funktioniert stimmt
wenigstens das grundprinzip oder muss man sowas schon ganz anders
aufbauen???
Autor: Falk (Gast)
Du hast ein Problem. Deine Fragestellung ist vollkommen konfus!
Also erstmal tief durchatmen, nachdenken und dann das Problem
darstellen. Von Anfang an.
Welcher Controller?
Welches Display?
Welche Schaltung?
Was soll gemacht werden?
Etc.
MFG
Falk
Autor: johnny.m (Gast)
Wenn Du letztens den Hinweis auf das Datenblatt beherzigt hast, sollte
es ja eigentlich kein Problem sein, anhand des dort dargestellten
Beispiels ein selbstdefiniertes Zeichen zu erstellen. Hast Du das
Beispiel im Datenblatt auf der zweiten Seite denn mal ausprobiert? Du
musst immer erst die CG-RAM-Adresse setzen und im nächsten
Schreibvorgang die Display-Daten für die ausgewählte Pixelzeile
schreiben.
Ich will jetzt nicht versuchen, mich durch den Assembler-Code
durchzuwursteln, auch weil es nicht viel bringen dürfte, da er
unvollständig ist.
Wenn Du bei der Definition der Zeichen folgende Hinweise beachtest, dann
müsste es funktionieren:
1. Es wird für jede Pixelzeile inkl. Cursorzeile ein Schreibvorgang
benötigt, also insgesamt 8.
2. Die Adresse einer Pixelzeile im CG-RAM setzt sich aus der Adresse des
Zeichens (0x00...0x07) und der Nummer der Zeile (0..7, von oben gesehen)
zusammen. Insgesamt besteht die Adresse einer Zeile aus 6 Bit, wobei die
drei höherwertigen die Adresse des Zeichens sind und die niederwertigen
drei die Nummer der Zeile.
3. Beim Schreiben einer CG-RAM-Adresse müssen (wie beim Schreiben einer
DD-RAM-Adresse) das RS- und das R/W-Signal "0" sein.
4. Das Bit Nr. 7 im Adressbyte muss zum Setzen einer CG-RAM-Adresse "0"
und das Bit Nr. 6 "1" sein. Also wenn im Zeichen mit der Adresse "0x01"
die dritte Zeile geschrieben werden soll, dann lautet das Adressbyte
(mit Leerstellen, um die einzelnen Blöcke zu verdeutlichen) "01 001
010", wobei "01" die Bits darstellen, die dem Display-Controller
mitteilen, dass eine CG-RAM-Adresse geschrieben werden soll. Das
folgende "001" ist die Adresse des Zeichens, das definiert werden soll.
"010" ist die Nummer der Zeile, also 0x02 für die dritte Zeile (die
erste ist 0x00).
5. Nach dem Setzen der Adresse müssen im nächsten Schreibvorgang die
Daten für die Pixelzeile geschrieben werden (RS = "1" und R/W = "0"). Ob
CG-RAM- oder DD-RAM-Daten geschrieben werden, hängt nur davon ab, auf
welchen Speicher der letzte Adressierungsvorgang bezogen war.
6. Zum Schreiben der nächsten Pixelzeile muss wieder erst die Adresse
wie unter 3. und 4. beschrieben gesetzt werden. Dann wird die nächste
Pixelzeile geschrieben usw...
Das mit der Definition dieses Zeichens müsste ja hin hauen...hab deine
Anweisungsschritte soweit befolgt...
Aber der Aufruf funktioniert irgendwie nicht...
hab dann versucht das Zeichen mit:  darzustellen
                 call            #SELBSTDEF    ;aufruf der
definition(oben)
              bis.b     #BIT0, &P3OUT
              mov       #1, R10
              mov       #000h, R11
              call      #SEND
              mov       #1, R10
              mov       #000h, R11
              call      #SEND
              bic.b     #BIT0, &P3OUT
muss ich da noch was anderes beachten?
(aber auch andere normal ASCII zeichen stellts nach dem
Definitionsaufruf nicht dar...)
Du musst erst eine DDRAM-Adresse setzen, bevor Du ein Zeichen ausgibst.
Wenn Dein Programm das nicht tut, dann kommt auch nix vernünftiges raus,
weil der Display-Controller dann immer noch im CG-RAM rumeiert.
Danke... Funktioniert endlich...
