Forum: Mikrocontroller und Digitale Elektronik Externes flashen mit OpenOCD+wiggler+arm7
von Eduard F. (edddy)
ich hab einen arm7 von sharp "LH75401"
(http://www.sharpsma.com/Page.aspx/americas/en/part/LH75401/)
und möchte ein externes Flash "MX29LV320C T/B" von Macronix
(http://www.macronix.com/QuickPlace/hq/PageLibrary48256F55002C90A5.nsf/h_Toc/75d338438656550a48256f5500408bf7/?OpenDocument)
mit Openocd und dem wiggler flashen.
Ich habe momentan folgendes config-file:
#daemon configuration
telnet_port 4444
gdb_port 3333
#interface
interface parport
parport_port 0x378
parport_cable wiggler
jtag_speed 0
#use combined on interfaces or targets that can't set TRST/SRST separately
reset_config trst_and_srst srst_pulls_trst
#jtag scan chain
#format L IRC IRCM IDCODE (Length, IR Capture, IR Capture Mask, IDCODE)
jtag_device 4 0x1 0xf 0xe
#target configuration
daemon_startup reset
#target <type> <startup mode>
#target arm7tdmi <reset mode> <chainpos> <endianness> <variant>
target arm7tdmi little run_and_halt 0 arm7tdmi-s_r4
target_script 0 reset h2294_init.script
23
run_and_halt_time 0 30
24
working_area 0 0x40000000 0x40000 nobackup
25
26
#flash configuration
27
flash bank lpc2000 0x0 0x40000 0 0 lpc2000_v1 0 14765 calc_checksum
28
flash bank cfi 0x80000000 0x400000 2 2 0
OpenOCD via telnet bringt folgende Meldung:
Open On-Chip Debugger
> flash info 0
#1: lpc2000 at 0x00000000, size 0x00040000, buswidth 0, chipwidth
        #0: 0x00000000 (0x2000kB) erase state unknown, protected
        #1: 0x00002000 (0x2000kB) erase state unknown, protected
        #2: 0x00004000 (0x2000kB) erase state unknown, protected
        #3: 0x00006000 (0x2000kB) erase state unknown, protected
        #4: 0x00008000 (0x2000kB) erase state unknown, protected
        #5: 0x0000a000 (0x2000kB) erase state unknown, protected
        #6: 0x0000c000 (0x2000kB) erase state unknown, protected
        #7: 0x0000e000 (0x2000kB) erase state unknown, protected
        #8: 0x00010000 (0x10000kB) erase state unknown, protected
        #9: 0x00020000 (0x10000kB) erase state unknown, protected
        #10: 0x00030000 (0x2000kB) erase state unknown, protected
        #11: 0x00032000 (0x2000kB) erase state unknown, protected
        #12: 0x00034000 (0x2000kB) erase state unknown, protected
        #13: 0x00036000 (0x2000kB) erase state unknown, protected
        #14: 0x00038000 (0x2000kB) erase state unknown, protected
        #15: 0x0003a000 (0x2000kB) erase state unknown, protected
        #16: 0x0003c000 (0x2000kB) erase state unknown, protected
        #17: 0x0003e000 (0x2000kB) erase state unknown, protected
lpc2000 flash driver variant: 1, clk: 14765
23
> flash write 0 boot.bin 0
24
failed writing file boot.bin to flash bank 0 at offset 0x00000000
25
flash program error
26
Hat jemand vielleicht einen Tip bzw. Vorschlag wie das config- File
auf die oben genannte Hardware zu ändern ist?
Wäre euch für eure Hilfe sehr dankbar
Gruß Edi
von Dominic R. (dominic)
Dein .cfg File listet zwei Flashes - das erste (Index 0) ist ein Philips
LPC2000 internes Flash (ich denke nicht, dass der Sharp Controller ein
solches besitzt ;))
Das zweite (Index 1) ist das CFI kompatible externe Flash. Das muss
zuerst geprobed werden:
flash probe 1
Wenn es dann richtig erkannt wurde (OpenOCD kennt nur Intel kompatible
CFI flashes, Patches für andere gibt's im Forum auf sparkfun.com, aber
keiner davon ist wirklcih "sauber") können die Flash Funktionen
aufgerufen werden.
Also:
- Die erste "flash bank" entfernen
- OpenOCD starten, Telnet
- flash probe 0 (da es jetzt nur noch ein Flash gibt)
- flash info 0
- flash write ...
Gruss,
Dominic
Hi Dominic,
Nach entfernen der "ersten flash bank"
und der Eingabe bei telnet folgende Meldung bei Openpcd:
Info:    openocd.c:84 main(): Open On-Chip Debugger (2006-01-26 13:30 CET)
Warning: arm7_9_common.c:683 arm7_9_assert_reset(): srst resets test logic, to
Info:    server.c:67 add_connection(): accepted 'telnet' connection from 0
Error:   cfi.c:1061 cfi_probe(): cfi primary command set 2 unsupported
Ich nimm mal an, dass ich mich jetzt um ein "unsauberes Patch" bei
sparkfun.com kümmern muss.
Vielen Dank erstmal
Gruss
Edi
Hallo Edi,
genau, command set 2 ist der AMD/Spansion/etc. Algorithmus, der aktuell
noch nicht unterstützt ist.
Das Problem für mich ist dabei, dass dieser Algorithmus von sehr vielen
Herstellern benutzt wird, allerdings nicht immer ganz identisch. Die
Gemeinsamkeiten aus einer Unmenge von Datenblättern herauszufiltern, und
das ganze dann möglichst auf mehreren Varianten zu testen, ist sehr viel
Arbeit, die bisher noch niemand auf sich genommen hat. Ich selbst habe
nur Boards mit Intel kompatiblen Flashes.
Gruss,
Dominic
