Forum: FPGA, VHDL & Co. Multisource
Autor: frager (Gast)
leider habe ich ein Problem mit der CPLD Programmierung. Ständig bekomme
ich die Fehlermeldung
"ERROR:Xst:528 - Multi-source in Unit <shift> on signal <PO<17>>
ERROR:Xst:528 - Multi-source in Unit <shift> on signal <PO<16>>
ERROR:Xst:528 - Multi-source in Unit <shift> on signal <PO<15>>
ERROR:Xst:528 - Multi-source in Unit <shift> on signal <PO<14>>
ERROR:Xst:528 - Multi-source in Unit <shift> on signal <PO<13>>
ERROR:Xst:528 - Multi-source in Unit <shift> on signal <PO<12>>
ERROR:Xst:528 - Multi-source in Unit <shift> on signal <PO<11>>
ERROR:Xst:528 - Multi-source in Unit <shift> on signal <PO<10>>
ERROR:Xst:528 - Multi-source in Unit <shift> on signal <PO<9>>
ERROR:Xst:528 - Multi-source in Unit <shift> on signal <PO<8>>
ERROR:Xst:528 - Multi-source in Unit <shift> on signal <PO<7>>
ERROR:Xst:528 - Multi-source in Unit <shift> on signal <PO<6>>
ERROR:Xst:528 - Multi-source in Unit <shift> on signal <PO<5>>
ERROR:Xst:528 - Multi-source in Unit <shift> on signal <PO<4>>
ERROR:Xst:528 - Multi-source in Unit <shift> on signal <PO<3>>
ERROR:Xst:528 - Multi-source in Unit <shift> on signal <PO<2>>
ERROR:Xst:528 - Multi-source in Unit <shift> on signal <PO<1>>
ERROR:Xst:528 - Multi-source in Unit <shift> on signal <PO<0>>"
wie kann ich diese verhindern? Manchmal half die after Syntax, leider
klappt das nicht. Ich hoffe ihr könnt mir helfen!
entity shift is
  port(C, SI, inc : in  std_logic;
        PO : out std_logic_vector(17 downto 0));
end shift;
architecture archi of shift is
  signal tmp: std_logic_vector(17 downto 0);
  signal ct: std_logic_vector(4 downto 0):="00000";
  begin
  process (C)
  begin
    if (C'event and C='1') then
    ct<=ct+1;
    if(ct<18 AND ct>0) then
      tmp <= tmp(16 downto 0)& SI; --Das verursacht die Fehlermeldung
    else
       ct<="00000";
     end if;
   end if;
  end process;
  process (inc)
  begin
    if (inc'event and inc='1') then
       if(ct=0) then
         tmp<=tmp+5 after 100 ms;
      end if;
    end if;
  end process;
   PO <= tmp;
end archi;
Autor: Klaus Falser (Gast)
Du darfst das Signal tmp (= P0) nur in EINEM Prozess zuweisen, nicht
aber in zwei.
Du mußt die Increntierung um 5 in den ersten Prozess hineinziehen.
Ist C das Taktsignal?
Klaus
hi,
ja wie könnte ich das denn reinziehen?
c ist clk... und ist das Tacktsignal, das hast du richtig erkannt...
Grüße
Vielleicht so ähnlich:
process (C)
  begin
    if rising_edge(C) then
       ct<=ct+1;
       if ct = 0 then
          if inc = '1' then
             tmp <= tmp + 5;
          end if;
       elsif ct<18 then
       else
          ct<="00000";
       end if;
    end if;
end process;
vielen dank für Deine Hilfe.
Jedoch soll inc unabhängig von C laufen. Und so bräuchte man den Tackt
von C.
Hat jemand ein Wunderheilmittel gegen Multisource? Das ist immer mein
Kälberstrick.
Viele Grüße
Autor: Jörn Kaipf (joern)
Multisource läßt sich mit Tristatetreiber bzw. Multiplexern erschlagen.
Wobei die Tristatevariante vom Synthesewerkzeug durch Multiplexer
ersetzt wird.
> Kälberstrick.
Ein paar Hardware-Kenntnisse wirken da Wunder.
Vielleicht solltest ein bischen lernen was da im FPGA/CPLD passiert und
wie es aufgebaut ist.
Dann verstehst Du vielleicht auch warum bei synthetisierbaren Designs
ein Signal nur von einem Prozess getrieben werden kann (naja, sollte).
Klaus
  • [vhdl]VHDL-Code[/vhdl]
