Hallo ich bin VHDl Anfänger und moechte ein Filter bzw. CIC filter bauen . Ich habe vorher eine Mischung von der sinus/cosinus mit des ADC-Daten gemacht und möchte die Ergebnissen Filter. Ungefähr W= cos*ADC_DATEN; Z= Sin*ADC_DATEN; Eine CIC-Filter gibt es schon in Xilinx IP-Core aber wie Kann ich das machen? Hat jemand einen Tipp fuer mich? Danke Gruß. Auguste -- You must compile the wrapper file CICDecimator.vhd when simulating -- the core, CICDecimator. When compiling the wrapper file, be sure to -- reference the XilinxCoreLib VHDL simulation library. For detailed -- instructions, please refer to the "CORE Generator Help". -- The synthesis directives "translate_off/translate_on" specified -- below are supported by Xilinx, Mentor Graphics and Synplicity -- synthesis tools. Ensure they are correct for your synthesis tool(s). LIBRARY ieee; USE ieee.std_logic_1164.ALL; -- synthesis translate_off Library XilinxCoreLib; -- synthesis translate_on ENTITY CICDecimator IS port ( DIN: IN std_logic_VECTOR(9 downto 0); ND: IN std_logic; RFD: OUT std_logic; CLK: IN std_logic; DOUT: OUT std_logic_VECTOR(22 downto 0); RDY: OUT std_logic; LD_DIN: IN std_logic_VECTOR(13 downto 0); WE: IN std_logic); END CICDecimator; ARCHITECTURE CICDecimator_a OF CICDecimator IS -- synthesis translate_off component wrapped_CICDecimator port ( DIN: IN std_logic_VECTOR(9 downto 0); ND: IN std_logic; RFD: OUT std_logic; CLK: IN std_logic; DOUT: OUT std_logic_VECTOR(22 downto 0); RDY: OUT std_logic; LD_DIN: IN std_logic_VECTOR(13 downto 0); WE: IN std_logic); end component; -- Configuration specification for all : wrapped_CICDecimator use entity XilinxCoreLib.C_CIC_V3_0(behavioral) generic map( c_differential_delay => 1, c_sample_rate_change_max => 16383, c_number_channels => 1, c_filter_type => 2, c_result_width => 23, c_enable_rlocs => 0, c_sample_rate_change => 4, c_latency => 1, c_sample_rate_change_min => 4, c_sample_rate_change_type => 1, c_data_width => 10, c_stages => 1); -- synthesis translate_on BEGIN -- synthesis translate_off U0 : wrapped_CICDecimator port map ( DIN => DIN, ND => ND, RFD => RFD, CLK => CLK, DOUT => DOUT, RDY => RDY, LD_DIN => LD_DIN, WE => WE); -- synthesis translate_on END CICDecimator_a;
Du hast den CIC ja schon gefunden. Du musst im Xilin ISE dieses Wrapperfile einbinden (dazuladen) und im vorhandenen VHDl, wo es benutzt werden soll, als Componnente delarieren. Dann einmal / mehrfach instanzirien und anschliessen. Wie die Komponente heissen muss, steht im Wrapperfile. Nach der Synthese findet Xilinx ISE den core und baut in grafisch als Unterpunkt in deine VHDL ein. du brauchst dann nur noch eine state machine, die dieses Filter mit Daten füttert.
Danke für den Tipp Ich habe leider nicht den Wrapperfile gefunden . Wird das auch mit der CIC-Core generiert? Wie ich das verstanden habe muss ich jetzt eine Automat bauen ? Grüß Chindji
Das was Du gepostet hast, ist das Wrapperfile. Mehr VHDL wirst Du von dem Core nicht zu sehen bekommen. Rick
ISE gibt mittels des core Generators ein " *.xco " aus, das in das aktive Verzeichnis muss. Der wrapper muss ins Projekt. Eingebunden wird über HDL-Instanzierung oder Generation eines Symbols und Benutzung im SCH-Design.
