Forum: Compiler & IDEs Compiler optimizations disabled
von Newbie ..... (Gast)
Build started 8.7.2007 at 13:58:58
avr-gcc.exe  -mmcu=atmega8 -Wall -gdwarf-2 -DF_CPU=3686400UL -O0
-fsigned-char -MD -MP -MT lcd-routines.o -MF dep/lcd-routines.o.d  -c
../lcd-routines.c
In file included from ../lcd-routines.c:2:
c:/winavr-20070525/bin/../avr/include/util/delay.h:89:3: warning:
#warning
"Compiler optimizations disabled; functions from <util/delay.h> won't work as designed"
../lcd-routines.c:124:1: warning: "DELAY50US" redefined
../lcd-routines.c:8:1: warning: this is the location of the previous
definition
../lcd-routines.c:142: error: redefinition of 'lcd_data'
../lcd-routines.c:17: error: previous definition of 'lcd_data' was here
../lcd-routines.c:162: error: redefinition of 'lcd_command'
../lcd-routines.c:35: error: previous definition of 'lcd_command' was
here
../lcd-routines.c:181: error: redefinition of 'lcd_enable'
../lcd-routines.c:52: error: previous definition of 'lcd_enable' was
here
../lcd-routines.c: In function 'lcd_enable':
../lcd-routines.c:182: error: 'LCD_EN' undeclared (first use in this
function)
../lcd-routines.c:182: error: (Each undeclared identifier is reported
only once
../lcd-routines.c:182: error: for each function it appears in.)
../lcd-routines.c: At top level:
../lcd-routines.c:193: error: redefinition of 'lcd_init'
../lcd-routines.c:64: error: previous definition of 'lcd_init' was here
../lcd-routines.c:228: error: redefinition of 'lcd_clear'
../lcd-routines.c:98: error: previous definition of 'lcd_clear' was here
../lcd-routines.c:235: error: redefinition of 'lcd_home'
../lcd-routines.c:105: error: previous definition of 'lcd_home' was here
make: *** [lcd-routines.o] Error 1
Build failed with 15 errors and 3 warnings...
Wie kann ich diese Optimierung einschalten?
von Andreas K. (a-k)
Alles andere als -O0 hilft dir weiter. Üblich ist -Os.
OK, jetzt ist zwar "Compiler optimizations disabled; functions from
<util/delay.h> won't work as designed" weg, aber der Rest ist
gleichgeblieben.
Was mache ich für einen Fehler?
von Johannes M. (johnny-m)
> gleichgeblieben.
Du glaubst, Du machst nur einen Fehler? Dein erster Fehler ist schon
mal, dass Du denkst, die Leute hier im Forum hätten hellseherische
Fähigkeiten und könnten aus einer Latte Fehlermeldungen das Programm
rekonstruieren. Der zweite Fehler ist, dass Du wahrscheinlich eine ganze
Menge Syntaxfehler bei Funktionsaufrufen machst. Der dritte Fehler ist,
dass Du einen undefiniertes Symbol mit der Bezeichnung LCD_EN
verwendest....
1. sorry hab jetzt erst gesehen das der Anhang nicht funktioniert hat
   wenn der Anhang wieder nicht geht kann ich den code eh nur posten.
2. Das kann schon sein, da ich einfach mal die lcd-routine vom
LCD-tutorial
   kopiert hab zum testen meines lcd.
3. LCD_EN ist glaub ich die bezeichnung für den enable-pin also pin 3
tut mir leid ich wollt euch echt nicht ärgern mit meinem tread :(
Bist Du sicher, dass der Compiler von der Datei lcd_routines.c weiß? Das
sieht mir nämlich fast so aus, als ob Du die gar nicht im Makefile
angegeben hast und der Compiler deshalb die Definitionen der ganzen
Funktionen nicht kennt. Es reicht nicht, nur die Headerdatei
einzubinden. Die .c-Datei muss im Makefile bei den Sources angegeben
werden!
Das hier heißt "thread". "tread" ist was anderes...
"Die .c-Datei muss im Makefile bei den Sources angegeben
werden!"
die Dateien lcd-routines.c und lcd-routines.h hab icm im avr studio bei
source-files und header-files eingefügt.
Oder meinst du mit Makefile was anderes?
Hatte grad nicht gesehen, dass die Fehlermeldungen alle aus der
lcd_routines.c stammen... Was hast Du mit der lcd_routines.c gemacht?
Das sieht fast so aus, als hättest Du die ganze Datei kopiert und unten
noch mal drangehängt! Dann ist klar, dass der Compiler bei allen
Funktionen meckert. Die sind ja auch alle zweimal definiert. Das geht so
nicht.
BOOAAH!! Hab ich wohl aus Versehen 2x in den editor kopiert ;)
Es geht jetzt. Juhu :) , 1000dank
Beitrag #5277627 wurde von einem Moderator gelöscht.
Beitrag #5277628 wurde von einem Moderator gelöscht.
