Forum: Compiler & IDEs AVRStudio stürzt bei ext makefile ab
von Robert Liebner (Gast)
Guten Abend,
ich versuche mein Projekt in AVRStudio zu debuggen, was bisher
allerdings misslingt, da der Build in AVRStudio immer fehlschlägt.
Ich verwende Funktionen aus der Procyon AVRlib, schätzungsweise hakt es
deshalb...
Wenn ich das makefile von AVRStudio erzeugen lassen, erhalte ich
folgende Fehlermeldung:
make: *** No rule to make target `..//C/dev/AVRlib/buffer.c', needed by `buffer.o'. Stop.
Kann mich jemand aufklären? Ich habe alle avrlib-sourcen eingebunden,
include-pfade gesetzt usw. (von AVRStudio generiertes makefile im
Anhang)
Wenn ich das Projekt über das ursprüngliche makefile "von Hand"
erstelle, klappt alles wunderbar.
AVRStudio allerdings stürzt ab, wenn ich das makefile einbinde (ext.
makefile verwenden)
Ursprüngliches makefile:
# Makefile for AVR function library development and examples
# Author: Pascal Stang
# For those who have never heard of makefiles: a makefile is essentially a
# script for compiling your code.  Most C/C++ compilers in the world are
# command line programs and this is even true of programming environments
# which appear to be windows-based (like Microsoft Visual C++).  Although
# you could use AVR-GCC directly from the command line and try to remember
# the compiler options each time, using a makefile keeps you free of this
# tedious task and automates the process.
# For those just starting with AVR-GCC and not used to using makefiles,
# I've added some extra comments above several of the makefile fields which
# you will have to deal with.
########### change this lines according to your project ##################
#put the name of the target mcu here (at90s8515, at90s8535, attiny22, atmega603 etc.)
#  MCU = atmega163
#  MCU = atmega161
#  MCU = atmega323
#  MCU = atmega128
  MCU = atmega8
23
24
#put the name of the target file here (without extension)
25
#  Your "target" file is your C source file that is at the top level of your code.
26
#  In other words, this is the file which contains your main() function.
27
28
  TRG = test
29
30
#put your C sourcefiles here
31
#  Here you must list any C source files which are used by your target file.
32
#  They will be compiled in the order you list them, so it's probably best
33
#  to list $(TRG).c, your top-level target file, last.
34
35
  SRC =  $(TRG).c $(AVRLIB)/rprintf.c $(AVRLIB)/uart.c $(AVRLIB)/buffer.c  pckb.c $(AVRLIB)/i2c.c $(AVRLIB)/i2ceeprom.c
36
37
#put additional assembler source file here
38
#  The ASRC line allows you to list files which contain assembly code/routines that
39
#  you would like to use from within your C programs.  The assembly code must be
40
#  written in a special way to be usable as a function from your C code.
41
42
  ASRC =
43
44
#additional libraries and object files to link
45
#  Libraries and object files are collections of functions which have already been
46
#  compiled.  If you have such files, list them here, and you will be able to use
47
#  use the functions they contain in your target program.
48
49
  LIB  =
50
51
#additional includes to compile
52
  INC  =
53
54
#assembler flags
55
  ASFLAGS = -Wa, -gstabs
56
57
#compiler flags
58
        CPFLAGS = -g -Os -Wall -Wstrict-prototypes -I$(AVRLIB) -Wa,-ahlms=$(<:.c=.lst)
59
60
61
#linker flags
62
  LDFLAGS = -Wl,-Map=$(TRG).map,--cref
63
  LDFLAGS += --no-channge-warnings
64
#  LDFLAGS = -Wl,-Map=$(TRG).map,--cref -lm
65
66
67
68
########### you should not need to change the following line #############
69
include $(AVRLIB)/make/avrproj_make
70
71
###### dependecies, add any dependencies you need here ###################
72
#  Dependencies tell the compiler which files in your code depend on which
73
#  other files.  When you change a piece of code, the dependencies allow
74
#  the compiler to intelligently figure out which files are affected and
75
#  need to be recompiled.  You should only list the dependencies of *.o
76
#  files.  For example: uart.o is the compiled output of uart.c and uart.h
77
#  and therefore, uart.o "depends" on uart.c and uart.h.  But the code in
78
#  uart.c also uses information from global.h, so that file should be listed
79
#  in the dependecies too.  That way, if you alter global.h, uart.o will be
80
#  recompiled to take into account the changes.
81
82
buffer.o    : buffer.c    buffer.h
83
uart.o    : uart.c      uart.h    global.h
84
uart2.o    : uart2.c    uart2.h    global.h
85
rprintf.o  : rprintf.c    rprintf.h
86
a2d.o      : a2d.c      a2d.h
87
timer.o    : timer.c    timer.h    global.h
88
pulse.o    : pulse.c    pulse.h    timer.h  global.h
89
lcd.o      : lcd.c      lcd.h      global.h
90
i2c.o      : i2c.c      i2c.h      global.h
91
spi.o      : spi.c      spi.h      global.h
92
swpwm.o    : swpwm.c    swpwm.h    global.h
93
servo.o    : servo.c    servo.h    global.h
94
swuart.o    : swuart.c    swuart.h    global.h
95
tsip.o    : tsip.c      tsip.h    global.h
96
nmea.o    : nmea.c      nmea.h    global.h
97
vt100.o    : vt100.c    vt100.h    global.h
98
gps.o      : gps.c      gps.h      global.h
99
$(TRG).o    : $(TRG).c            global.h
Wäre sehr dankbar für eine Erklärung...
