Forum: Mikrocontroller und Digitale Elektronik AVR311 implementieren, aber wie
von Christian S. (mueke)
ich versuche jetzt sdchon seit längerem die AppNote AVR311 zu
implementiern (I2C), aber es will einfach nicht laufen. Hier mal mein
Quelltext:
#include <avr/io.h>
#include <avr/iom16.h>
#include <avr/interrupt.h>
#include "TWI_slave.h"
#include "LTC1257.h"
// Variablendeklaration
struct conf{
  uint8_t motorcontroll;
  uint16_t steps, motorcurrent, frequency;
}config;
uint16_t counter=0;
int main ( void )
  uint8_t TWI_slaveAddress, messageBuf[9], temp1=1, temp2=1;
  // Initialisierung des MCU
  DDRA = 0xF0;
  DDRB = DDRC = DDRD =0xFF;
  TCCR1A = 0x40;
23
24
  TWI_slaveAddress = 0x40 | (PINA & 0x0F);
25
26
  // Slaveadresse setzen und TWI-Initialisieren
27
  TWI_Slave_Initialise( TWI_slaveAddress );
28
29
  // Globale Interrupts zulassen
30
  sei();
31
32
  // Transceiver auf Bereitschaft setzen
33
  TWI_Start_Transceiver();
34
35
  while(1)
36
37
    if( ! TWI_Transceiver_Busy() )
38
39
      if( TWI_statusReg.lastTransOK )
40
41
        if( TWI_statusReg.RxDataInBuf )
42
43
          TWI_Get_Data_From_Transceiver(messageBuf, 7);
44
45
          temp2 = temp1 = 1;
46
          switch(messageBuf[0])
47
48
            case 0x00:
49
              temp1=0;
50
51
            case 0x10:
52
              config.motorcontroll   = (messageBuf[temp2] & 0xE0);
53
              temp2++;
54
              PORTC &= 0x1F;
55
              PORTC |= config.motorcontroll;
56
              if(temp1)
57
                break;
58
59
            case 0x20:
60
              config.steps       = (messageBuf[temp2] << 8);
61
              temp2++;
62
              config.steps       |= messageBuf[temp2];
63
              temp2++;
64
              if(temp1)
65
                break;
66
67
            case 0x30:
68
              config.motorcurrent   = ((messageBuf[temp2] & 0x0F) << 8);
69
              temp2++;
70
              config.motorcurrent    |= messageBuf[temp2];
71
              temp2++;
72
              LTC_Set_DA(config.motorcurrent);
73
              if(temp1)
74
                break;
75
76
            case 0x40:
77
              config.frequency    = (messageBuf[temp2] << 8);
78
              temp2++;
79
              config.frequency    |= messageBuf[temp2];
80
              temp2++;
81
              if(config.frequency == 0)
82
                config.frequency = 1;
83
              if(temp1)
84
                break;
85
86
            case 0x50:
87
              TCCR1B = 0;
88
              TCNT1 = 0;
89
90
              if(config.steps <= 100 && config.steps > 0)
91
92
                OCR1A = 31250 / config.frequency;
93
                TCCR1B = 0x0B;
94
95
              else if(config.steps > 100 && config.steps <= 255)
96
97
                OCR1A = 250E3 / config.frequency;
98
                TCCR1B = 0x0A;
99
100
              else if(config.steps > 255)
101
102
                OCR1A = 2E6 / config.frequency;
103
                TCCR1B = 0x09;
104
105
              break;
106
107
            case 0x60:
108
              TCCR1B = 0x00;
109
              break;
110
111
112
        else
113
114
115
116
117
118
119
120
121
122
123
ISR ( TIMER1_CAPT_vect )
124
125
  if(PIND & (1 << PIND5))
126
    counter++;
127
128
  if(counter > 0 && counter == config.steps)
129
    TCCR1B = 0x00;
130
Kurze Funktionsbeschreibung:
Mein Slave soll Daten empfangen für einen Schrittmotorsteuerung. Das
untere Adressnibble lässt sich per DIP-Schalter einstellen, also auch
der GEN-Call. Im ersten übertragenen Datenbyte steht ein Code, der mir
sagt, was übertragen wird (switch(messageBuf[0])), dann folgenden die
eigentlichen Nutzdaten...
Ich bekomme keine Daten an meinem uC... Oder kann es daran liegen, dass
meine Pull-Up-Wdst's nur 1k1 und nicht 4k7 groß sind?
Oder muss ich vielleicht das DDRX der SCL und SDA auf einen bestimmten
Wert setzen???
Vielleicht kann es ja auch am Master leigen..., oder seht hier im
Quelltext nen Fehler?
Muecke
von Jörg X. (Gast)
Kannst du ein bisschen genauer beschreiben, WAS nicht geht, bzw. nicht
so geht wie erwartet?
Ich blick nicht ganz durch wieviel Bytes da übertragen werden. Hast du
die "#define TWI_BUFFER_SIZE 4 " (aus der "TWI_slave.h") angepasst,
falls da mehr als 4 Bytes kommen? (das config-struct ist schon 7Bytes
groß + 1 "headerbyte" wenn ich das richtig lese).
Der Code wird etwas übersichtlicher, wenn du die Auswertung (switch
....) in eine Funktion auslagerst, dann könnte ggf den Puffer vorher
kopieren ( z.B. mit memcpy)
hth. Jörg
